ZUK Z2 Pro - Snapd 820 5,2" Super Amoled FHD 6GB Ram 128GB Rom 3100mah 8/13MP Cam OIS Band 20
J
johndebur
Neues ZUK Handy. Wird anscheinend am 21. 4. vorgestellt
ZUK Z2 Pro定于4月21日发布:骁龙820大电池 mydrivers
ZUK Z2 Pro is scheduled for April 21 release: Xiao Long 820 large battery
Early in the morning, ZUK CEO often ride on the confirmation of the new machine Z2 Pro news, Chen Xudong, president of Lenovo Mobile now microblogging published,Z2 Pro release date is April 21 .
It is worth mentioning that Chen Xudong apparently spend Lenovo ZUK Z2 Pro phone .
According to previous leaks, ZUK Z2 Pro will be equipped with Snapdragon 820 processor, came earlier renderings also show its equipped with a rotating camera, double glass .
In addition, from the name of our judgment, ZUK Z2 should have at least two versions, PRO may be high with, had spread over the 4.7-inch small-screen mobile phones, positioning in the end.
ZUK Z1 has said in the beginning of the publication of the collection of user pain points, and therefore choose 4100mAh large battery, the entire network, the standard 3G / 64GB, the Z2 Pro is likely to continue the family tradition.
J
johndebur
Angebliches Poster Bild vom Z2
ZUK Z2 PRO规格/设计解封 屏幕曲面感人 mtksj
ZUK Z2 PRO specification / design unseal touching the screen surface
Gossip spread for a long time, Zuk finally obtained for the first time officially confirmed, recently, Zuk officially disclosed on the 21st of this month will be released Zuk Z2 pro, remove always fans in looking forward to Z2, the machine is also subject to the industry's attention, because without it, Z2 Pro is Zuk return to the association after the first products!
Confirmed the identity of the new machine and the release time to market, ZUK build on the progress of local design ZUK Z2 PRO officially revealed to the world, at the same time, the first time a third party Z2 PRO exposure of the core specification, a relatively complete Z2 PRO show everyone before. Chang Cheng ZUK CEO again today released new information, Z2 PRO renderings surfaced for the first time, to "return to early heart" as the theme of the poster, ZUK Z2 PRO still holds partly concealed appearance. From the entire design, the shape will be worried Peter Z2 PRO VIBE Z2 PRO users can rest assured, ZUK Z2 PRO did not like VIBE Z2 PRO / K920 as all-metal body, after the shell material is unknown, or glass, and or if Z1 as the standard version with plastic, the follow-up will be introduced after the other materials shell version, but the metal frame is necessary.
focus on areas of concern, there are two, the first is the front of the screen, rendering the edge of the screen Z2 PRO obvious surface marks, can not help but speculate whether such Z2 PRO Xplay5 applied as curved screen? Another person, Z2 PRO back part of the main subject have a clue, in addition to huge hint camera lens is good and can also see the lights and color Wen Shuangguang a mysterious oval area, which is expected to be popular laser focus module.
Lenovo ZUK Z2 PRO core specification also get exposure parameter Z2 PRO suspected of security Bunny release show, Z2 PRO confirm equipped Xiaolong 820 processor, continue to use the 1080P screen, 8M + 13M camera, running Android 6.0 system. People doubt that the memory part, Z2 PRO there are two kinds of 3G RAM and 4G RAM memory on the version, but the storage space is actually more stingy than some Z1, starting to 32G.
Polished several months, this product will bring some new surprises no suspense in terms of functionality, interactivity, etc., however, believe that the majority ZUK powder is more concerned about is whether --Z2 PRO PFP will continue to follow the pricing of traditional Z1 it?
blur
Ich habe meiner Frau schon das ZUK Z1 geholt und warte für mich eigentlich nur noch ob das Z2 Band 20 bekommt.
Allerdings wären mir 32GB etwas zu wenig, ob da noch ein SD-Slot kommt?
Brooklyn701
Also selbst mit 64GB ist ein SD slot immer gut. 32GB und SD slot wäre aber kein k.o.
Selbst ohne Band 20 würde es für mich noch gehen. Wobei mir die Entscheidung natürlich viel viel leichter fällt. Beim ZuK 1 hat mich nur das 32bit gestört. Zwar nicht soooo sinnig aber bei dem Preis erwarte ich ein SOC der 64bit kann (und OS dazu)
Gesendet von meinem Xtouch mit Tapatalk
SnowyNight
ich muss sagen ich hatte schon beides..und der 801 hatte immernoch jeden super 64bit 616 usw. weggesteckt. und auf jedenfall gleich mit dem x10
Brooklyn701
Aha also auch ein XTouch :p Nein ich weiß das schon, aber ich möchte, so gut sie ist, nicht auf einer alten Architektur rum reiten wenn ich 200 EUR oder mehr ausgegeben habe
muhamed
Würde es nur noch bei Amazon kaufen und erst dann wenn es CyanogenMod gibt. Auf den Hersteller braucht man sich nicht verlassen.
blur
Würde es nur noch bei Amazon kaufen ..
Auch da kann der Händler in Shenzhen sitzen. Oder in Italien / Frankreich / GB etc., ob das tendenziell besser ist für nen möglichen Support?
Ich habe mitbekommen, dass es vermehrt Probleme gibt mit dem Homebutton / Fingerprintsensor beim ZUK Z1.
Das würde ich bei dem Z2 erst Mal abwarten.
Zooka
Bin auch eher skeptisch. Habe das Zuk Z1 jetzt schon seit Monaten, eigentlich ist es ein recht gutes Smartphone, allerdings wie blur bereits angemerkt hat scheint er der Fingerprintsensor gerne mal den Geist aufzugeben, ist auch bei mir passiert. Was ich so mitbekommen habe, ist der Support von ZUK auch nicht vorhanden, außerdem ist die Cyanogen Version auch nicht das Gelbe vom Ei. Es gibt immer noch kein offizielles Android 6, außerdem hat es Cyanogen seit Monaten nicht geschafft, nervige Bugs zu entfernen bzw. gefühlt kommen mit jedem Update neue Bugs hinzu.
blur
Es ist wohl kein Zufall, dass Du das mit dem Fingerprint gleich bestätigst.
Ja die Updateversorgung ist wirklich etwas enttäuschend, aber für das Z2 wird es dann auch eine CM Community-Version geben, so es mit Cyanogen OS kommt.
Ich habe bei meiner Frau die inoffzielle CM13 installiert, bei der muss man, im Gegensatz zur offiziellen CM13, den Homebutton nicht drücken, um zu entsperren.
Vielleicht hält er dadurch etwas länger.
muhamed
Ich hab das Zuk Z1 6 mal gekauft. 2 mal für mich und 4 mal für Freunde. Schwarz hatte ein "gelbes Display", beim weißen waren Teile vom Lack ab (um das Display drumherum), bei einem hat der USB Port Probleme bereitet, beim anderen auch und bei meinem selbst hat die Kamera Probleme mit dem Fokus gehabt.
Am Ende haben die großen China Shops das Zubehör entfernt und CyanogenMod wurde nur schlechter (sinnvolle Feature entfernt und Bugs).
Bei Amazon kann ich es dann ohne großen Aufwand zurücksenden.
Das Zuk Z2 kann aber ein riesen Erfolg werden. So blöd wie Zuk ist werden die aber die guten Sachen sicherlich entfernen (Cyanogen, Akku, Speicher, usw.)
J
johndebur
Das Handy soll in CHina 2699 yuans (370€) kosten . Ausserdem werden mehr als 80 Länder unterstützt, sollte also auch Band 20 haben :grin: Allerdings ist die ZUK Seite noch nicht aktuell.
Es gibt auch eine 4GB Ram /64GB Rom Version, da ist aber der Preis auch noch nicht bekannt. Das HAndy kann auch die Herzfrequenz, UV Strahlung und lauter so Gedöhns messen.
It supports more than 80 countries Roaming
6GB+128GB只卖2699元!联想ZUK Z2 Pro震撼报价 mydrivers
6GB + 128GB selling only 2699 yuan! Lenovo ZUK Z2 Pro shocking
Lenovo has just released a new generation flagship phone ZUK Z2 Pro, which is the first innovation workshop ZUK return to work after the association.
Z2 Pro boasts nine black science and technology , including true 3D glass back of the body, the heart can take pictures, use wet hands fingerprint to unlock, 7 die in the frequency of 23 fastest speeds, can no online shopping overseas roaming outside the service, energy and iCloud synchronization can be side heart rate, oxygen, ultraviolet, 10 professional integrated sensors, 100% play Xiaolong 820 properties, etc., known as redefining flagship.
Memory and storage Z2 Pro is also very generous, Exclusive Edition offers 6GB of RAM, 128GB storage, the standard version is 4GB RAM, 64GB storage.
6GB + 128GB version as long as 2699 yuan enjoy! It will open at 10:00 on April 22 thousand public test, but the release date were not disclosed.
4GB + 64GB Ultimate price not disclosed.
20591643_1461230082207_500.jpg 20591696_1461230143891_500.jpg 20591698_1461230187326_500.jpg 20591818_1461230487810_500.jpg 20591982_1461230532089_500.jpg
J
johndebur
Youngn
@johndebur
Irgendwelche Infos über das OS??
Cyanogen, Vanilla, ...?!
Und seh ich das richtig, nur 4,6mm dünn??
Bin grad unterwegs, aber es beschleicht mich so ein starkes "haben-will-Gefühl". :grin:
SnowyNight
@johndebur
die haben die zuk os version drauf in china..keine informationen zum "internationalen" os
und 4.6~7.45 mm
also 4,6mm wohl and er "dünssten" stelle am rand mit dem "3d glass" und 7,45mm halt insgesammt an der dicksten stelle.
J
johndebur
naja die CHinesische Version hat erstmal dieses ZUK UI oder so
http://www.zui.com/
Von einer internationalen Version ist noch nicht die Rede. Denke mal da muß man erstmal abwarten :)
naja an bestimmtem Stellen :) Vermutlich, da wo die KAmera sitzt ist es dicker
http://www.zuk.com/z2pro/specs/index.html
Height: 145.4 mm
Width: 70.5 mm
Thickness: 4.6 ~ 7.45 mm
Weight: Ultimate Edition / Exclusive Edition of about 145 g
