Xiaomi Mi Band 2 in Q2 2016
Youngn
Xiaomi Smartwatch & Mi Band 2 in Q2 2016
Xiaomi does not personally manufacture these Mi Band wearables, instead, its partner company, Huami takes care of the process. Hence, although, we call it the Xiaomi Mi Band, it’s actually made by Huami. Now, Huami’s CEO Wang has revealed a few details about the second generation model of the Xiaomi Mi Band as well as Xiaomi smartwatch. It looks like, once again, Huami is manufacturing these two devices.
First up, CEO Wang confirmed that both, the Mi Band 2 and the Xiaomi smartwatch will debut in the next two months, within Q2 2016. The major selling point of the new Band version will be the small display on board. So, it looks like the Mi Band 2 will be able to show you a lot more information than its previous generation, reducing reliance on the connected smartphone.
As for the price, the new Band will be slightly costlier than the previous generation model. To recap, the Mi Band 1S with heart rate sensor retails for 99 Yuan (~$16) in China. Another important information revealed by him was that the new version will abandon the “Mi” branding. It will be called as the Band 2, but we are not sure of the exact name.
Now, coming to the most interesting part of the interview, CEO Wang confirmed that Xiaomi smartwatch with a display exists and will meet us in Q2 2016. The watch will feature a larger screen than the Band 2, and focus on a particular function. Smartwatch manufacturers are particularly keen on health-related functions, so we may see the smartwatch boast of suchfeatures. But, apart from the existence of the device as well as the release timing, nothing else is confirmed.
http://www.gizmochina.com/2016/04/05/xiaomi-smartwatch-almost-confirmed-coming-q2-2016/
Andycat
Ich werde das Band und die Smartwatch kaufen.....macht hinne jungs :up:
Youngn
Da ist sie so langsam! :)
When it comes to leaks there is nothing better than a CEO just cutting through the marketing and showing us what’s coming next, a move that Li Jun has recently taken with the next gen Mi Band.
In a photo posted by Lei Jun, the new Mi Band has a simple LCD display, and also looks much wider than the current model, hopefully meaning a larger battery and an equally long battery life.
The Mi Band unit appears to come in a pod that sits inside a simple strap like the current (and previous versions of the wearable) and it also looks like a simple single physical button is part of the design too.
http://www.gizchina.com/2016/04/24/li-jun-shows-off-mi-band-screen/
Hmm, dem Designer hätte man nicht so viele Science Fiction Filme zeigen dürfen.
Sieht eher aus wie ein Communicator, oder eine "Fußfessel". ;)
Andycat
Das Original sieht jetzt auch nicht so pralle aus.....aber ich freu mich das sich überhaupt was bei Xiaomi bewegt....
Band oder Smartwatch....ich kaufe beide..........:):)
Andycat
Neee den Reiskocher habe ich nicht.....Nur das miband ohne pulsmesser und ein Redmi Note 2.........
esverkehrt
Wo kann man den Kocher kaufen, ich meine mit funktionierender Lieferung nach Europa und Strom-kompatibel?
Youngn
Andycat
Der fette Schwarze rand von der Smartwatch ist ja hässlich.....
Habe mir ersteinmal die No.1 d5 bestellt....läuft mit Android 4.4.2 hat gps,wlan,bluetooth,simslot,4gb speicher,barometer,
mal sehen wenn sie da ist...:Mauridia:
Tobee
Born to buy from China
Klingt interessant aber irgendwie traue ich No.1 nicht so. Bin mal gespannt was du zu berichten hast.
Andycat
Leider gibt es nicht viele chinauhren die mit Android als Betriebssystem.....
Da funktioniert ja der Playstore drauf.....
