J
johndebur
ein iphone Klon. nun ja
shanzhaiben
shanzhaiben
Ultra-high imitation 1:1 perfect screen, cottage iPhone 4S smartphones
First brief appearance is completely 1:1, weight 114g, slightly lighter 140g than the iPhone 4S, 4S resolution of screen and the iPhone 960 * 640, the display is also very close to, the system is naturally Android the program is the Qualcomm 7227-T-enhanced version of the not cottage origin MTK chip, the performance will be higher than a length, memory 512M, 8G storage, no memory card slot, front and rear dual cameras, supports WCDMA 3G standard.
From the packaging to the accessories and the iPhone 4S.
Parts section.
The protagonist played, the appearance of the iPhone 4S, iOS interface.
This part of 4S compared to the most obvious change.
Stainless steel metal frame.
Round Home key, the a 30Pin data interface, data cable and Apple original universal.
Front camera for video calls.
The back part, can not find a different place.
SIM cards do not need to cut card, using the standard Cato, this is more convenient for changing the card's users.
iPhone 4S a new feature is the inclusion of the the Siri intelligent assistant can also find similar applications on Android.
The iPhone built-4S cottage is Vlingo voice assistants, and the Siri as to achieve a variety of voice control.
