J
johndebur
soll so 116 € kosten.
http://www.blackview.hk/blackview-omega_pro/
3G运存/简约设计 Blackview Omega Pro面世 mtksj
3G memory on / minimalist design Blackview Omega Pro
In the case of the brand does not have a strong influence, with the introduction of high + low price and a lot of new products into the export of conventional means of warfare mobile phone brand, so fingerprints, 3G memory on dual screens have appeared in recent years, foreign electricity suppliers phones body.
The brand name will be listed BlackView recently adopted a 64 MTK latest 8-core LTE program new machine, full name Blackview Omega Pro, the machine has a simple and elegant appearance, but the basic specification is very mainstream, and the price just over a hundred dollars.
Blackview Omega Pro with a straight rectangular body design, the metal frame is very flat, plus the aircraft selected popular double mirror, the whole can bring people to a sense of simplicity, color matching is a simple route, only the classic black White color. In addition, the thickness of the machine thin, the main camera body is flush with the case, the phone did 7.8mm thick.
Basic Configuration part of the aircraft in addition to the built-in 1.5GHz main frequency MTK6753 Eight-core processor, the memory is also a bright spot where, BLACKVIEW OMEGA PRO has 3GB of memory to run internal storage space for conventional 16G, it can support up to 128G expansion. Modest screen size, 5 inches, with a resolution of HD level, with 2M + 13M camera and 2400mAh battery, the system is Android 5.1, support FDD / WCDMA / GSM network dual card dual standby.
Have 3G memory on, metal and glass body of Omega Pro price close to the people into the country belong to a class of aircraft in AliExpress other platforms as low as $ 129.9, or about 830 yuan.
