Coolpad K1 - Snapdragon 400 5,5" qHD LTE dual sim 1GB Ram 4GB Rom 2/ 8MP Cams 2500mah
J
johndebur
Neues dual sim Handy mit LTE support von Coolpad. Kostet 1399 yuans (162€)
全球首款四核千元双卡4G酷派K1发布 ZOL
The world's first quad-core 4G Dual Card Cool K1 thousand Yuan release
The world's first dual SIM 4G smartphone thousands Cool K1 in common witness and Cool Unicom senior official release , Cool K1 is fully compatible with TD-LTE, FDD-LTE, WCDA, GSM network standard , can achieve 4 9 frequency mode , the maximum support speed downlink rate of 150Mbps and uplink speeds of 50Mbps . In addition, it also enables dual sim dual standby dual -pass feature for business users with very useful features . In addition, its 5.5- inch touch screen, and joined with the full IPS lamination technology enables fast screen response , but also has the characteristics of high-definition display.
In the photo , the machine uses a combination of two million pixel front camera and rear 8 -megapixel camera , and supports a variety of camera modes that can be set according to the actual demand. Another Cool K1 built beauty mode , you can easily shoot more perfect picture , smile Smile Capture mode on Cool K1 can still be found , for the love of self is very convenient and practical female friends .
Cool K1 also has a 8.1 mm thin body , can facilitate the upcoming summer carry, rear fuselage has a delicate striae provides the user with a good feel . In the core aspects of the use of the 1.2GHz frequency Qualcomm quad-core processor and 1GB of memory to run with a combination of body and 4GB storage , in order to meet the 4G mobile Internet users more practical needs , equipped with a 2500mAh removable battery , provides a good power guarantee.
Sehr hübsch :)
http://www.pcpop.com/doc/0/993/993360.shtml
ceaubFE0A5g.jpg ced5p8aAsCSM.jpg cedBdydEOPpvg.jpg cejIV4xOKMX9E.jpg cesOikgCcmznc.jpgceUO4F0aB7Fig.jpg cevDvcooKfBk.jpg003073555.jpg 003073562.jpg 003073563.jpg 003073564.jpg 003073565.jpg
Kurzer Überblick von PConline:
千元双4G双卡双待 酷派K1现场试玩报告 pconline
Übersetzung
Thousand Yuan 4G Dual SIM Dual Cool K1 live demo report
Cool K1 configuration parameters |
CPU | Qualcomm MSM8926-2 quad-core 1.2GHz
GPU | Adreno 305
RAM | 1GB
ROM | 4GB support up to 32GB memory card expansion
Screen| 5.5 inches qHD resolution IPS screen full fit
Camera| 8 megapixel main camera 2.0 megapixel front camera
System | Customized based on Android 4.3
Battery capacity| 2500mAh
Price | 1399
4463879_6926_11190450_thumb.jpg 4463879_10478_11086928_thumb.jpg 4463879_16736_11173212_thumb.jpg 4463879_22132_11130281_thumb.jpg 4463879_28830_11136505_thumb.jpg
Summary trial
Cool K1 in both hardware and design work continues the consistent style Cool maintain a high standard. In terms of fluency system there is no problem, the basic functions readily available, more than enough to cope with ordinary users. As the first to support dual-4G's dual card dual standby $ level, this is not the whole mobile phone industry has little impact. At the same time there appeared a phone called the 7610, as with K1, also a thousand 4G dual sim dual standby dual. The difference is that 7610 narrowed 0.5 inches screen, more suitable for one-handed operation. Screen size reduction will inevitably lead to the fuselage interior space narrowing, so the 7610 uses a relatively small 2000mAh battery to ensure the basic life.
Cool product line according to plan, its 4G mobile phone will always adhere to the needs of dual card dual standby done, mainly in the initial 4G, 4G likely most users will use the card online, before the old card to the phone, in fact, have such the user needs to be substantial. December 5, 2013 4G licenses issued, the Ministry announced 14 models for 4G mobile phone network license, Cool phone 4, the largest number of all brands. So Cool's experience accumulated in 4G is quite rich, but they are very valued $ level of the 4G market, if Cool operating properly, the future of the domestic low-end non-4G market will cool perfectly.
closebor
