help ciphone mp3 player
gpop969
Hi, I was charging my ciphone and at the same time looking at the songs I have on my play list I wanted to update but the mp3 player disappeared and now I do not have a Mp3 player can anyone help me out.........??????
Hi :)
What you need to do is to delete the hidden playlist file called:
audio_play_list.txt
from yor tf card. After that, the player should automatically generate a new playlist, if it doesn't, go to the settings of the player and make sure the "Auto List Gen" is set to ON.
Hope this helps :)
gpop969
Hi, thank you for the quick response but is it possible you can give me a step by step instruction.......????????? I really like my phone and do not want to mess it up again...
There is really not much too it.
Make sure your operating system (Windows?) is set to show you hidden files, then you delete the hidden playlist file and that's it.
After that you'll be able start the MP3 player again, it will automatically generate a new playlist, if it doesn't, you have to press the little arrow button on the top left corner of the player to get into it's settings. there should be a "refresh list" option, select it and you're all done :)
If you don't mind me asking, where are you from?? It's a little unusual to be writing in English here ;)
gpop969
I am from Florida USA, I do speak German but I do not think my writting is so good....smile. When I touch the mp3 player icon it turns the phone off and then comes back on I think the software is completely gone....Do I need to do a factory reset????
gpop969
Hi, can I download any software with the ciphone 1st generation??????? I see that it has some kind of Java program in it..............
If you have the JAVA version of the ciPhone, sure, why not?!? I really can't help you with that, my ciPhone doesn't support Java :(
You just have to make sure to look for games / apps that don't need any keyboard input, try to look for stuff that runs on touchscreen phones.
