Huawei OPPLE LED Candle Night Lamp Blowing Control für 16,28€
Gearvita
Preis: 16,28€
Coupon: LEDCNL
https://gearvita.com/huawei-opple-candle-night-lamp.html
Product Description:
● Blowing Sensor: Blow-on/off is a great option for this flameless portable candle light.
● Dimmable&Memorable: The wineglass-like LED candle holds for 3 brightness levels to fit your eyes in different places, and it does deliver a smooth, steady, comfortable natural light, even on the lowest brightness setting. And the brightness will remain on your previous setting.
● Wireless&Rechargeable: Built-in battery, no need of to replace the battery frequently.
● Portable: New design, wineglass-like night lamp, no worry if causing a fire or blowing out. It is deal for home decor.
● Environment Frirndly: ABS Plastic, non-toxic, no smell, anti-flaming, heat and corrosion resistance.
