pinphone 3gs 4gb problems
markb
hi, first post .great site some good stuff on here, i have had my pinphone 3gs for one month now and opera mini google maps and facebook apps do not work . i had figured out that i had files missing ,also i had made all my hidden files available before joining this site.when i downloaded the hidden java file from here,i noticed that i only had three files on my sd card / appdb /appdb_sd /lib . so i coppied the app file to my sd card java with the other three .still my three apps fail to open ? is this the same for all pinphones, the three apps do not work . will flashing the phone with updated firmware solve this problem or will my three apps only ever work from a java instalation . thanks mark
Did you put the "app" folder inside the hidden "Java" folder or in the root directory? It needs to be inside the Java folder.
markb
yes put the app folder inside the hidden java file there are three others in there appdb / appdb_sd and a lib file . i thought i would have a few problems with this phone as its a clone but not this many lol , my safari connection to the internet is a waste of time keep on getting unsupported scripts then internal error ,connects through java mini opera very well version 5.0.18635 . just thinking if those files were missing how many more are missing ...
closebor
