Pinphone battery problem
Eev
The stand-by time of my pinphone is less than 12 hours .. is this normal ? Is there any way I can change the battery? I can only use the phone (internet, music, calling etc) for a few hours with this battery :(
If you open the phone, the battery can pretty easily be removed. Question is, where to find a stronger one? :(
I set the LCD backlight brightness to 3, I have the feeling that increased the standby time enormously. Also, make sure to have bluetooth off if not in use, it also helps a lot to save some energy.
Eev
Thanks for the fast response!
I have set brightness to 1 and WiFi/Bluetooth etc is off.. so that's not the problem. There are pinphones with 2000 mah out there (I have the 1100 mah battery..), still haven't find a battery seller though..
Adistan
