Pinphone - Problem with SIM
blade84
Hello!
I'm an italian users and i just bought the Pinphone 3GS.
I have a big problem and i hope someone can help me!!
I inserted the SIM in the Pinphone, but after it search for network, it shows "Invalid SIM".
I tried with different SIM but the result is the same.
What can I do?!?
Thanks in advance!!
Hello!
I'm an italian user and i just bought the Pinphone 3GS.
What can I do?!? Maybe I have to change any parameters in engineering/factory mode?!?
Help me please!!
Thanks in advance!!
Does the phone at least recognize any of those sim cards? Can you access the phonebook entries from your sim cards?
blade84
Yes, the phone recognize the SIM, i can access the phonebook. if i click "safari" icon i can view "Vodafone SIM"
The problem seems to be a network problem, i can't make any call.
Maybe the phone is locked?!? Strange...
deSouza
this phone can't be locked...but why shows the phone "Invalid SIM", when you have an access to your phonebook on your SIM?.... maybe a connection error between the pinphone and the SIM.....
What is your setting under:
Settings - General - Network setup
What's your preferred mode there?
And do you know if they might block IMEI numbers in Italy?
blade84
No, it says "IMEI:"
And nothing else...
If this can help, firmware version of my Pinphone is:
[VERSION]
I835S_FN_CA_W_V1_1_1
[BRANCH]: 08B I835D
BUILD: SVN_2331
SERIAL#:
MT012345678901234567
[BUILD TIME]
2009/12/05 13:02
If I type *#06# on my Ciphone C5 the result is "0000000000", but the phone work correctly.
I don't know what I have to do....
This is VERY strange, the phone should display the IMEI, even without a sim card inserted!
Have you tried a factory reset? Code should be 1122 for it.
blade84
Yes, i tried a factory reset with the 1122 code but nothing....
Also i tried the hard reset how is shown in this picture
but, in my opinion, this is a "soft reset", because after that i powered on the pinphone and the settings were the same that were before the procedure.
Is this really the procedure of hard reset?
Is there any parameter to set the radio band in engineering/factory mode?
Thanks.
No, there is nothing regarding this to be found in the Engineer or Factory Mode :(
I simply don't understand why your phone won't show you an IMEI??? Without an IMEI there is no way the phone could ever register to GSM network :(
The only idea I have left is to open the phone, take out the batterie and HOPE it'll work after that? You'll probably lose the warrenty if you screw open the phone, so it's up to you whether or not you want to go for it.
deSouza
irgendwie hat die 1_1_1 firmware einige bugs...diese hier mit der SIM und IMEI, andere berichten von JAVA problemen.. schon merkwürdig...
Scotsman828
That SIM card may be locked to another phone, here in the States, we have Prepay Service Providers that have phones with Proprietary OS and the SIM is locked to that specific phone. Cannot even be swapped to another phone of same make and model with same OS. I hate those phones.
misoja
PINPHONE SCREEN DEAD when calling
Hello.
I have a very strange problem with my brand new PINPHONE. Everything works fine, am still adjusting all settings and playing around.
BUT once I do CALL or receive a CALL I cannot hang up, or use the screen in any way (the different options that appear).
Have done HARDWARE reset and RESET by code 1122!!!!!!!
NOTHING ............ the screen is DEAD while call is active.
I do not know what the reason could be, as the screen works perfectly with the rest of menus and no problems up to now except while calling like mentioned.
Hope somebody has a BRILLIANT idea.
MJD
...already tried to move the blue circle which appears during calls with your finger to the "button" you want to push?
brendjnes69
