resist adware >> how Zopo Zp-980+ delete all and new flash ???
KitKat
How can I all delete and new flash on my Zopo Zp-980+ (4.4.2, root) ?
I think I have resistent adware on my phone.
Factory Reset > no help
Factory reset, complett wipe + new rom flashing > no help
At first start all is okay, after any houers install self this apps:
- Super Locker (make also a konto)
- Go Glock
- Go Launcher
and I think also:
- 2 Camera
- Ace Browser
I have only install apps what make no problems (this apps make on all my other phones long time no problems).
I have no receive any attachements.
Sorry for my bad english, you can also answer in german.
Thanks
Unbroken
salty
There are some custom roms for your phone model on Needrom.com, maybe you try one of this roms (Miui, cyanogenmod ect...)
http://www.needrom.com/category/zopo/zp980-zopo/
Cause if the stockrom is so much infectet like yours, it makes no sense to stay on this rom version.....
Or try to flash the firmware again (downloaded directly from the official zopo HP) because its possilble, that the rom on your phone is not the original zopo firmware.....
In the end you need another rom on your phone, the infectet rom will always do what it wants because the adware is too deep in the system!
No need to delete anything ;) just flashing a new rom.;)
KitKat
Many thanks for the answer. So if I install a Custom Rom and then the original Stockrom, then the problem is fixed?
Can not I format the mobile phone somehow and then install the Stockrom?
Unbroken
salty
No need to flash a custom rom and then the original stock! You can try to flash the original stock or a custom rom instead of the original rom. Ok!? ;)
No need to format your phone bevore flashing.
I dont know what zopo made with their erarlier stock roms, I just dont think that they really made a firmware with so much ad crab!
But please read the description about the flash process very good! ;) if you never flashed a phone bevore....
KitKat
This doing not help.
I have flash via upgrade 4.4.2 and install my apps (like on 6 other phones, clean apps), but after any houers / days is install same apps from self.
Unbroken
salty
Thats the problems of a pre rooted system! And thats the reason, why today no manufactor sales its models pre rooted!
So there's no other way as to flash a custom rom and not the pre rooted firmware from zopo itself, because you can flash the original firmware again and again, the ad ware will start every time! Cause the firmware is f*cking pre rooted....
Choose a custom from Needrom.com and flash ist! ;) good luck!
thor2001
Pre-rooted soft-/firmwares aren't the problem, because you can use the root access to your advantage.
SuperSU (or any other similar app) manages your root access.
I'd try a different approach by cleaning the (stock) ROM, which is already on the phone.
Flashing a stock ROM from official sources is a good starting point nevertheless.
I always use:
https://play.google.com/store/apps/details?id=com.eset.ems2.gp&hl=de
with the highest detection settings (deep scan, detect potential unwanted apps) to find possible mal-/adware.
If the found app(s) are system apps, eset can't uninstall them.
But that's where you can use other apps, with the ability to freeze or uninstall the malicious app due to granted root access from SuperSU.
Freezing:
https://play.google.com/store/apps/details?id=com.ramdroid.appquarantine&hl=de
Uninstalling:
https://play.google.com/store/apps/details?id=com.jumobile.manager.systemapp&hl=de
I'd try freezing the app, instead uninstalling, due to the fact,
that some functions may need the app and the system may become unstable without it.
If the (stock) launcher is one of the culprits, you may need to switch to a 3rd party launcher before freezing/uninstalling it.
Flashing another (custom) ROM is the last step, if all other options failed, imho.
All mentioned apps should be multilingual.
Regards
Unbroken
salty
@thor2001, in anderen Foren, habe ich dies gelesen, die alten pre rooted Roms diverser Hersteller, hatten öfters das Problem, dass sich nach einiger Zeit adware selbstständig installierte und auch durch diverse "Fummeleien" in den Systemapps etc nicht richtig entfernen ließen. Es wurde dann stets empfohlen eine alternative custom rom zu installieren!
Deshalb habe ich dass auch hier empfohlen, keine Ahnung was der Königsweg ist, aber ich denke saubere Alternativ Rom ist, besser als lange und umständlich im System herumzufummeln. ;)
2 Leute 3Meinungen und Ansichten... ;)
KitKat
Das Problem ist, es gibt keine funktionierenden custom roms für das Zopo Zp-980+
Irgendetwas funktioniert dann nicht, Treiberprobleme.
Es soll von den russischen Freunden etwas geben, ich kann mich zwar etwas auf russisch verständigen, aber so fit bin ich in der Sprache nun doch nicht un d Google Translater & Co. hilft nur, wenn man erkennt ob die Ausgabe Blödsinn ist, oder nicht - kann ICH nur für Englisch nutzen :)
holdi111
