Ulefone T2 Pro - Helio P70 6" FHD+ ?
J
johndebur
Wird angeblich auf der MWC vorgestellt.
全球首款联发科P70全面屏手机宣布!19:9异形屏 mydrivers
The world's first MediaTek P70 full screen mobile phone announced! 19: 9 shaped screen
Advancing into the high-end market unfavorable, so MediaTek choose to avoid the edge, instead of investing in research and development of low-end products. According to previous news, MediaTek will be released in the first half of this year Helio P40, Helio P70 two new mid-range.
The opening of MWC 2018 is just around the corner, and Ulefone, a domestic handset maker in Shenzhen , recently announced the release of the world's first Helio P70 full screen mobile phone, the Unleon T2 Pro, to be held at MWC on February 26th.
From the foreign media release of the new machine renderings of view, Ulefone T2 Pro uses a "fringe" screen design similar to the iPhone X's (as a distinct aspect ratio, 19: 9), mobile phone screen size is about 6 inches with a resolution of 1080x2280 . At the same time, the new machine also uses a highlighted metal frame and glass body, equipped with rear dual camera.
The new aircraft will be the world's first Helio P70 processor, the latter manufactured using TSMC 12nm process (14nm optimized version), integrated four A73, four A53 CPU core, the frequency was 2.5GHz, 2.0GHz (higher than unicorn 970), at the same time Integrate Mali-G72 MP4 800MHz.
Memory support dual-channel LPDDR4-3733, the maximum capacity of 8GB, storage support eMMC 5.1, UFS 2.1, the baseband is supported to LTE Cat.12, there are specialized DSP AI acceleration.
Earlier exposure Helio P70 Ann Bunny run points show that its score has reached 156,906, the CPU part of not only more than ten core flagship Helio X30 (leading rate of 10%), but also significantly ahead of Qualcomm middling main Xiaolong 660 up to almost 50% , Of which the CPU part exceeded as much as 1.3 times the performance should not be underestimated.
Information on the sale of the new machine is unclear. However, since the Helio P70 has appeared, I believe there will be a lot of new follow-up terminal.
s_daf61c42c7a34b65ac09642ef38fb73d.jpg s_49aa1cf6671645f1be855ae2a3d249a8.jpg
