J
johndebur
LoL , komisches Teil. Naja laut Shanzhaiji kommt es mit einer wireless kamera, die mit ausgezogener Antenne des phones bedient wird oder so.
Und für diejenigen , die ungerne das Touchscreen berühren ist eine versteckte Tastatur unterhalb des Displays integriert.
Kostet angeblich 600 yuan ohne kamera?
http://www.shanzhaiji.cn/mobile/20090809/12418.html
[Reference price]: iPhone 780 firms with no cameras of $ 600 yuan
With the real evil of unique accessories package inside. Mobile phone accessories in this package there are wireless pinhole camera. Although wireless camera has this option long ago, but prior to transfer using Bluetooth, 13W camera is also unclear. The use of Bluetooth is not equipped with the launch, using short-wave, built-in lithium battery, and the effect of so-so than the Bluetooth transmission quality or whether it is a lot stronger from the above.
To use this wireless camera will have to pull out the antenna, otherwise the signal will be very clear. CMMB battery into the process, by default will automatically find the wireless signal to launch camera, if there is no need to find some images of Taiwan, it is easy to find.
autsch
ich habe einfach was ohne kabel gesucht
