PS1-Emulator: Auf welchen Chinamobiles lauffähig?
Fork
"FPSEce is a PlayStation emulator for your Windows mobile device."
Aber auf welchen China Handys ist er lauffähig?
Sytemvoraussetzungen:
"FpseCE 0.10 need any PocketPC or Smartphone running on Windows Mobile 2003,
Windows Mobile 5 / 6 / 6.1 / 6.5 with an ARM processor, at least 25Meg of Program
Memory.
For best Result, any Device with ARM processor > 400mhz. PXA270,PXA310, PXA320
or the Last Snapdragon 1ghz!
Device must have such screen resolution: 240x320, 240x400, 320x320, 480x640,
480x800.
FpseCE is able to work on any Resolution but Menu Skins are made for only for those
listed screen resolutions."
Auszug aus der PDF-Datei, die Teil der Download-Datei ist.
"On the software-side you need FPSEce (which you can download for free on this website), PocketISO to compress your images (if you like), an image of a PlayStation-game you own,and a PlayStation-BIOS for use with FPSEce"
"But finally we developed a very useable emulator that supports hundreds of games - and it'll become more and more every day.": Compatibility-List
[ame="http://www.youtube.com/watch?v=-MHCQiT6e54&feature=player_embedded"]YouTube- FpseCE overlays. Medievil on TG01[/ame]
"One of our principles is to keep this software free.": Downloadseite
Gegen eine Spende gibt es die "supporter-version", which allows to save and load your game in realtime at every position on every game and also privileged support. Free updates until the next major-version is released is also included (this means if you buy v0.10 you also may download and use 0.11, 0.12, ..., 0.19 for free).": Link
Quelle: http://www.fpsece.net/
Fork
best Result ... with ARM processor
... soll nicht heißen, dass es nicht auch mit anderen funktioniert: *hint, hint, nudge, nudge, say no more!* ;)
[ame="http://www.youtube.com/watch?v=wuAtfLz06GI"]YouTube- Meizu M8 running FPSEce (PSX emulator)[/ame]
Ok, zugegeben, etwas lahm, aber es gibt vielleicht noch andere Spiele, die flüssiger laufen. ;)
J
johndebur
Auf meinem T5355 läuft das auch (irgendwie), habe aber die Steuerung noch nicht so ganz gepeilt?!? :(
Das gleiche hier mit dem t5353+ kann bei Autorennspielen irgentwie immer nur nach links lenken aber nie nach rechts.
oder der Character läuft immer links um die Ecke aber nicht nach rechts, ZB bei GTA1
Hier ein kleines Video tut ( nicht von mir ):
[ame="http://www.youtube.com/watch?v=63XAci8jDgg"]YouTube- FPSECE 0.10 on HTC HD2 small HowTo ENG and GER[/ame]
Scihero
Klingt ja nicht besonders vielversprechend, wenn selbst das vielgepriesene Meizu M8 nicht in der Lage ist, die Spiele flüssig zu emulieren. Hab Demos auf dem HTC HD2 gesehen, die dafür einmalig aussahen. Leider ist auch der Preis des HD2 einmalig...da kann man sich ja gleich3 Chinamobiles für kaufen.
Dahmer
Persona non Greta
hab ne frage zum emulator,brauch ich dafür die iso`s von den spielen oder wie soll das funzen
Scihero
Emulatoren simulieren nur eine Konsole, das heißt, du brauchst zum Spielen, ähnlich wie bei einer Konsole eben auch, die Games noch, in diesem Fall Roms...aber nur, wenn du auch das Original besitzt! ;)
Scihero
Der Emulator ist ja nur für Windows Mobile, aber das N21 ist ein Android Phone...ob es das also für den Android schon gibt, weiß ich nicht. Zumindest spuckt Google nichts aus.
