sd card memory VS phone memory(pinphone)
jazmie
if phone connect to to usb,choose mass storage mode.
-in pc explorer ist show the folder in sd card memory@phone memory?
-how to check space avaible in phone memory and sd card memory?
You are right.
On your pc you can see two drives.
One is the phone-memory, the other the sd-card.
And how to check the space???
Just look at the properties your pc is showing you ;)
jazmie
i check memory still 3GB..but install java game said error..need space 4MB...it should be enough...why happen like this?
i try install in phone or sd card also same error.
but my freespace still 3GB...still many...already try delete many java...got 2 only..but still same
It´s a bigger java-app you want to install?
I believe the pinphone is not able to run that app.
The heap-size memory has nothing to do with the storage-memory.
The heap-size is a part of the RAM that is for running java-apps. That one will be to small...
Can you try to install a smaller app? That should work instead.
jazmie
oic...heap memory=RAM
that java just need 4MB only
other java application can
one more..i run video...then i close application by push home button on phone...i try running again that video error said insufficient memory...then i try restart the phone then the video i can run...y this happen?
ist i push home button to close the video,the video still running in background?
If another java app is running than the pinphone can´t work with the "bigger" one.
And video:
i don´t think it is running in the background.
But you should ever close the media-player correctly.
Than that problem will never appear again :)
