iPDA Wm 7 - ipad alternative?
J
johndebur
Neues tablet mit GPS empfänger und 3G Sim karten slot. Im Moment läuft Windows CE darauf, aber in einem Monat soll es auch mit Android geben.
http://digibusy.com/new/tablet/20100716-3.html
This flat-panel machine with GPS is the U.S. SiRF (Joseph) has introduced the latest SiRF Prima (Premarin) chip platform, ARM11 core, 600MHz frequency. 7-inch 800x480 touch screen, also pre-256MB DDR2 memory, built-in 2GB capacity Flash memory body, and supports the maximum 32GB external TF card expansion.
The product itself also provides a rich interface, a standard and a USB and a mini-USB, TF card slot and headphone output. Also offers a 3G SIM card slot, but the standard of the slot is not open.
Operating system, now is Wince 6.0 pre-installed systems can also support Google's Android system, but the Google system will be end of the month to meet with you.
J
johndebur
neues Android 2.1 Pad, nennt sich haipad.
http://shanzhaiji.cn/mobile/20100816/19369.html
http://shanzhaiben.com/28/n-4628.html
Hainer haiPad program is adopted Telechips 8900, processor clocked at 720MHz, built-in 2G memory, 7-inch touch resistance screen resolution 800X480, only the bottom of the front of a sleep button, click into hibernation, click restore, sleep is a key next to the camera, should be 30 million pixels interpolated to 130 million, to video also line the words used to take photographs of some difference, but no one should be holding a 7-inch device camera, built-in WIFI, built-in microphone, built-in gravity sensor. Interface, the largest of a TF card slot supports 32G TF card, 2 MINI USB interface, Heiner haiPad comes with a standard USB MINI USB conversion cable to switch, external standard USB devices no problem.
Hainer also point commendable, built-in dual-core 1600mAh battery and a range of very small, at full load, play HD movies can open WIFI to 3 hours and 40 minutes of life,
und noch ein pad: finde ja die Belüftungslöcher in Android Form nett :)
weiß jetzt nich genau wie es heißt. In den Android settings steht unter Model number: flycat.
und auf der Rückseite steht nur Android tablet.
Also flycat tablet. ? :)
http://shanzhaiben.com/29/n-4629.html
Gossip much that we bring the following to a new Android flat, Chupin Fang leading from Shenzhen Hua Group. Is a 7-inch Tablet PC, 16:9 screen, the standard resolution of 800x480. Processor is used marvel PXA166, based on ARM11, clocked at 800MHz.
Master
Marvel (Marvel) PXA166
Frequency
800Mhz, ARM11
Memory
256M DDR
Flash
1GB
Screen
7-inch screen resistance (800x480)
Battery
3.7V 4800mAh
Weight
400g
OS
Android1.6
Other
GPS, G-Sensor, Camera
This is a flat configuration parameters, use the Android1.6 version. Manufacturers statement, you can upgrade to Andorid2.2, probably in October this year.
Hey habe gerade Sat 1 Frühstücksfernsehn geschaut^^
und da haben die ein Android Tablet mit 7 Zoll getestet nach 10 minuten war sein Tablet gesprungen und reagierte nicht mehr.
Also sollte man vll. mehr als nur 84 Eus für sein Tablet ausgeben.
Aber was es mitlerweile alles auf dem Tabletmarkt gibt ist ja zur Zeit hauptsächlich nur was für die Couch gedacht oder?
Lg
Stephan
versus
GalaxyTab MBP Milstone
iPad & Internet
Zitat apple:Die beste Art das Internet, Mails, Fotos und Videos zu erleben. In deiner Hand
Bloss das Apple das Internet mächtig beschneidet und die ganzen Fanboys und Jünger das auch noch gut finden und verteidigen :taunt:
Ein Internet-Tablet ohne flash/flashvideos....ist wie ein Geländewagen ohne Vierradantrieb weil der Hersteller sagt das das zu gefährlich ist und zuviel Sprit verbraucht :p
kein-clone
"Apple-Jünger"
ich finde zwischen der aussage "arbeiten" und "erleben" ist ein großer unterschied. ich finde sogar, das das eine gar nichts mit dem anderen zu tun hat.
für einen heimanwender ist meiner ansicht nach ein tablet eben hauptsächlich für die couch gedacht. und nicht für großartiges arbeiten. jeder tablet nutzer wird auch zusätzlich ein notebook oder gleiches haben, was von heute auf morgen auch nicht zu ersetzen sein wird.
OFFTOPIC:
ehrlich jetzt: ich misse gar nicht flash. weis gar nicht warum immer die selben argumentationen kommen. also dann bitte noch usb, bluetooth... fällt nichts neues ein?
ich denke langsam reicht es und jeder weis was leute wie dich stören. aber zum kauf zwingt dich ja auch keiner.
ich bin halt jdm. der im appstore sich was kauft ohne groß im netz zu suchen. nutze das ganze angebotene system sehr aus. bedienung ist unschlagbar, genau wie das design. service spielt für mich auch eine große rolle, wo ich bei apple nichts zu bemängeln habe.
ich habe fertig. :this:
J
johndebur
hier mal ein riesen iphone aufgeschraubt, das Tablet gibt es seit März. Das ding heißt JK01-TT , kann auch sein daß es das Ding von TESO ist. ( http://www.teso-epc.com/Html/Main.asp )
naja hier der Bericht von shanzhaiben mit Bildern:
http://shanzhaiben.com/32/n-4632.html
übersetzung:
http://bit.ly/9JPzod
This is a large iPhone with Intel ATOM N450 processor clocked at 1.66G. Using a 2.5-inch mechanical hard drive capacity of 160G, the memory capacity of 1G. 10.1-inch screen LCD, resolution up to 1024x600, and increased capacitive touch screen. Support screen rotation, multi-finger touch, handwriting operation, etc., the whole weight of less than 1.2 kg. This flat-panel business in Shenzhen price is given 2,100 yuan.
kein-clone
"Apple-Jünger"
so, jetzt habe ich das ipad. ist schon ne lustige sache, aber wie ich schon geschrieben habe ist es eher für die couch. habe mir zwar mal office hd2 installiert, aber nutzen werde ich es wohl kaum (nutze auch so kaum office etc.). zum surfen, spielen, emails etc. echt klasse!
und habe es sogar neu und eingeschweißt für 440€ bekomme (16gb wlan).
der verkäufer hat 2 stück am 08.08.2010 bei mediamarkt laut rechnung für je 404€ gekauft.
J
johndebur
nächsten Monat kommt irgentein neues pad raus mit Metall-Gehäuse, android und 1ghz Cpu. mal sehen was sich da so entwickelt :)
http://www.shanzhaiben.com/42/n-4642.html
More heavyweight products still to come, Xiao Bian has received previous rumors, the cottage will be out and the same 9.7-inch screen, Apple, metal shell, built-in will use the ARM Cortex-A8 core, 1GHz frequency. This is similar to Apple is simply amazing.
Not yet seen a real machine, but has been seen driving out of the metal. They did not know whether it will adopt the 1GHz clock speed, or lower the frequency used. Software will be used Android2.1, magic is, Android2.1 will be replaced by Apple's interface, or even mimic the interface of Apple iOS the third layer. If the information reliable, next month to see prototype.
J
johndebur
Weiß nicht mehr ob wir das nicht schon haben. Der Firmen name ist auch schwer per baidu zu googlen. Übersetzt heißt die Firma "Haina" oder "hainer" im chinesischen so 深圳海纳数码科技有限公司 , hab trotzdem nicht deren Internet seite gefunden.
naja egal , die haben sich auch noch nicht fürs logo entschieden . Denke mal das "Logo" ist nur ein platzhalter.
Das pad hat nen 800Mhz Telechip + 3d graphikbeschleuniger und 10" screen.
Das pad soll Mitte September zu haben sein.
Der prototyp hat resistiven touch, allerdings soll es auch mit kapazitiven geben.
Sieht auf alle Fälle nicht schlecht aus :)
http://shanzhaiben.com/44/n-4644.html
Hardware used Telechips TCC8902 chip clocked at 800MHz, with 3D acceleration, hardware video decoder that supports full 1080P HD video. 10-inch resistive touch screen, 256M memory, built-in 4GB of storage. Android 2.1 operating system, 1080/720P HDMI video output, can support the extrapolation 32G SD card, you can use wireless Wifi internet access.
Recently, the Shenzhen Haina Science and Technology, prepared in September listing of a non-iPad plate appearance, measurements size 260x160x14mm, weighs 516 grams.
Positive part is a 10-inch LCD screen resolution of 1024x600, you can browse the full screen without scaling. Standard is a resistive touch screen, but the vendor can provide capacitive screens, capacitive screens advantage here is not to say, touch up quite nice, for a pleasant fashion, the user should be more prepared to 200 Tai Yuen.
J
johndebur
Midbbs ( http://www.midbbs.cn/ ) hat zusammen mit einer anderen Firma ein tablet entwickelt.
scheint mit windows XP zu laufen? Viel info gibts ja auch nicht. heißt SAYCOOL.
http://www.midbbs.cn/html/xinwendongtai/201009/02-2738.html
Oceania has five Shenzhen Technology Co., Ltd. formal and MID lovers House [www.midbbs.cn] partnership. The two sides will share resources, product publicity and promotion, all-round cooperation, seek common development and achieve win-win situation.
________________________________
und BENQ nReader:
http://www.midbbs.cn/html/xinwendongtai/201009/01-2730.html
It was reported this week at the Global Dealer Conference in Taiwan, the BenQ 10-inch display has its own Android flat plane nReader R100. nReader R100 size 173x267x14.4mm, weight 700g, all-black frame design, the Samsung ARM-based 667MHz processor, 4GB memory, compatible with SD / SDHC / SDXC card, WiFi and 3G wireless, USB and HDMI interface to provide , Battery life 12 hours. The e-book will run Android 2.2 system, in January next year in China, Taiwan and Japan, but prices have not yet disclosed.
___________________________________________
und Blue morning BM-999, soll mal epad heißen ( so übersetzt google die Firma 蓝晨BM-999 )
http://www.midbbs.cn/html/xinwendongtai/201009/02-2737.html
soll mit Android laufen , glaub ich, viel info ist da nicht in der post. Außer auf dem BIld steht was von 3G, Wifi und GPS
J
johndebur
Jetzt im September kommen lauter "richtige" ipad klone laut m8cool, zumindest solche die dem ipad vom Aussehen sehr ähnlich sein werden . Wie jetzt die tablets heißen oder ob die damit das Teso Lpad meinen weiß ich leider nicht genau.
Recently, they all have the Walled King announced its new Tablet PC, and announced in September officially listed. As a result of domestic ARM chip, its price should be around 1,500 yuan in general, not only will be so cheap in the domestic market of the Apple iPad suppress the formation of momentum, e-book reader will also create an effective anti-market.
Rockchip Micro (ARM) is the largest promoter of behind the scenes
It is understood that these will soon landed in the domestic market in September Most of the products using the Tablet PC is the latest RK2818 Rockchip micro chip, and with open source Android2.1 system, the hardware specifications of the capacitor can support 7-10 inches touch screen, and can be used with a variety of Internet WiFi/3G other way, so rich in functionality and in not less than Apple iPad.
According to the relevant vendor sources, the current RK2818 chip already has the ability to 1GHz frequency impact, and can support a maximum capacity of 1024 × 600 resolution, so in the case of mature cottage hardware and software manufacturers will be confidence that introduced 8 - 10 inch big screen model directly against the iPad. Compared with the genuine iPad, cottage flat panel computer processor, memory and hard drive and other hardware configuration has not too much gap between theory, even more than Apple iPad also high, and made most of installing a Bluetooth tablet PCs, video cameras.
