Hiphone 4 688 MT6235B Firmware
KLiFF
anybody know how can i change/upgrade the full 128MB firmware?
You can not download the full image.
Not with FlashTool and also not with Spiderman.
I will check the firmware and give you a flashable version :)
Edit: Here now is the flashable Version: click
And please note: your firmware ist not secure :(
Flashing on your own risk.
Do it as in the video for NAND-Flash (the download): click
First flash all ROMs with the scatter-loading "scat_MT6235_Rumpelstilzchen.txt"
After that flash the ROM with scatter-loading "scat_txt_SEC.txt"
Now the phone should work :)
KLiFF
thanks,
i try to upgrade/change the firmware, because the wifi is not work, try to enable wifi= always search.. search... search.... and nothing found wifi network.
i think change/upgrade the firmware, solve the wifi connect.
and why write only 30MB (rom,third,secondary), the full flash is 128MB (132mb).
Because you can not handle a NAND-flash as full flash.
128MB includs also the custom-memory. Has nothing to do with the firmware.
The scat_txt_SEC.txt is a scatter-loading file to correct the secret-zone.
Because that firmware is not save.
I have no experience till now with that option.
So only flash the new one if you got a correct readback of the original.
Perhaps your phone will be dead.
NAND flash ist always with some risk ;)
oskaliope
