HTC HDII - HD2 mit verbesserter Hardware?
J
johndebur
Leider steht da nicht was verbaut ist, könnte auch nur der MTK chip sein. Allerdings soll die hardware des HD2 klon an Android 2.2 angepaßt sein.
Hat angeblich auch eine 8Mp kamera mit Anti-Verwacklungs-effekt, wenns stimmt. :)
Blöd nur , daß das HDII logo so riesig ist.
http://art.m8cool.com/113-27974.aspx
Andrew HD2 2.2 upgrade news came out, the majority of fans quite excited, Xiao Bian also very excited, as a configuration to the power of intelligent machines, in all aspects of performance are impressive, it can be said is rare in the market rivals The. Today the new version has been renamed HDII HD2, and we want to know what new HDII change? Here with a look.
In order to effectively distinguish the old version and earlier versions, so that consumers get a real new HDII, The new TP has been changed to positive LOGO HDII (II Roman text), everyone is still a matter of opinion whether or not it beautiful. And new HDII canceled front camera function, because the system is temporary native Andrew does not support video calls, note the difference when you buy Oh.
The following is the key slightly, the old version WM HD2 is for system development, running WM system is very stable, but poor stability of the system is running Andrew, the new system development HDII is optimized for Andrew, Andrew the system is very stable and smooth running (to run angry bird), but the WM system might not run stable.
HDII by the third generation of capacitive touch screen responsiveness greatly improved, rear camera imported using the NEC 800W pixel camera and supports anti-shake feature six-axis, the image quality is very good. In the audio processing also has its own unique, Cai Yong Jia YAMAHA independent speaker audio decoder chip design, the ring volume sufficient, characteristic sound very good, just lacking a little bass intensity.
Editor Comments:
2.2 The new version of HDII into Andrews greatly improved after the playability of the machine to retain the powerful configuration is to ensure the smooth running of the machine, and uses self-developed 3G Gigabyte motherboard technology, power / EMI / anti-static all have good performance. As a business / entertainment features are very powerful machine, I believe HDII will give us the appearance of a new feeling, the aircraft is about to blaze, we stay tuned ~ ~
Petteri
Ich auch, ich weiss nämlich sonst auch nicht viel mehr darüber und ich bekomme dann einen der ersten, wahrscheinlich Full of Kinderkrankheiten! :)
NiSa1990
HDII vs HD2/HD9
klingt wirklich hammer das Teil!
wo ist den da jetzt der Unterschied zu dem HD2 von etowalk?
http://etowalk.com/template/detail/displaydetail.html?itemId=333585&currency=USD
hab gesehen das von fastcardtech hat nur build in memory, dafür kann man aber Android oder WM installieren??
kann das hier da nicht genauso mithalten?
http://etowalk.com/template/detail/displaydetail.html?itemId=336605&currency=USD
sieht für mich wie die selbe Technik, nur anders verpackt, aus!
Hallo
Wenn ich das HD2/HD9 mit der HD t-mobile version vergleiche dann ist die Kamera Position der augenfaelligste Unterschiede. Ersteres hat die Kamera in der Mitte der schmalen Seite und unterstuetzt SD Karten, letzteres hat die Kamera nicht in der Mitte der schmalen Seite und untersstuetzt kein SD Karten.
Die Abbildung zu dem HDII hat die Kamera nicht an der Position des HD2/HD9 von ETOWALK.
Vielleicht hilft die Beobachtung...
