T-Mobile HD2 English Discussion Thread
petertrol
i dont know gromano, i think Petteri will be the person that told us if we can use the mtk rom for our tmobile, but i dont know how to do it: with a cable and which software?? Please Petteri give us this valued information.
Petteri
I asked for it in china! Hardware is only 99% to your T-Mobile Version, so HD9 i get is a little bit different. So you`ll need everything from here: http://chinamobiles.org/downloads.php?do=file&id=505
includet all NEW drivers and Softwares to flash, and you need a special flashcable with 3.5mm jack to USB! Because you have to use both cables (Flash and Standard USB) to flex the ROM! Otherwise no chance.....
g.romano81
I have problems with the download of this ROM.
I asked to the webmaster.
I hope he can solve the problem.
Are included also detailed instructions on how to flash this ROM?
Petteri
No, i will write an instruction, but i`m on a fair now.....so at first, you have to formate the phone with software tool, then flash V1 first, when all V1 is flashed you have to flash again the V4!
petertrol
thanks petteri for the info, we will wait for your instructions file before flashing, i hope you do it right as the rest of things ;)) cause i think its very risky process...we have to do it very carefully. Thank you very much.
GeoBroker
LowMan
Re: Wifi remote access on Dual Sim T-Mobile HD2
I do not understand what Your problem is.
Do You want to connect Your HD2 to internet and share the connection with some PC ?
So internet access on PC via HD2?
Is this possible??
Hi, yes it is.
I´ve done it with my notebook. but only via USB Cable or Bluetooth.
First you have to go to Internet via GPRS.
Second, you start the app "Internet Sharing" here you can choose the connection!
Regards
i would like to use my tmobile as modem in order to conect it to a PC for having internet access through the phone, is that possible? how? Thank you.
Here is the answer: http://chinamobiles.org/showthread.php?24960-T-Mobile-HD2-English-Discussion-Thread/page7
GeoBroker
Hi peterol,
I have the german ROM. So my Icons are in german.
Otherwise you can start the program from "My device\windows\IntshrUI.exe
Regard
Do you know the function of Wifi remote access?
I would like to use it but it doesn't work on my T-mobile HD2
Wy do you want to use this software? You can connect you phone via usb cable and active sync.
Or you can connectviy bluetooth and active sync.
If you use an windows XP you have to use active sync on your pc.
If you use windows 7 you have to use windows mobile device center.
now I try to install wifi remote access on my phone. I´ll test it......
regards
I want to view my hd2 device (files inside it and storage card) from PC.
Sorry if I'm not so clear
I test WiFi Remote access.
1. I´ve installed the Software from Window Marketplace - is free software (use Region "USA-english" then you can download and install)
Don´t use the WinPhone7 version.
2. Install on your device
3. Start wifi and connect to your home network
4. Start the app
5. type a password in the field
6. enable WiFi Remote access.
7. open the browser on PC an type the IP Adress you see on your device
8. type the same password in the mask in your browser
9. finish - WiFi remote access works
Best regards
g.romano81
Thank you
But I did as in your instructions and my browser shows "unable to reach the page"
"The connection has timed out
The server is taking too long to respond.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web."
4. Start the app
Best regards
GeoBroker
please give details:
1. witch OS do you have on your PC
2. Witch browser do you use
3. Are scripts allowed in your browser
4. What kind of wireless network do you use.
Maybe I can help you.
I will upload some screen shots from my connections soon. I use Windows 7 Home Prem Edition and Firefox. My network is WPA2 Security.
See you later
GeoBroker
It doesn't work for me.
I type the address like 192.168.0.4
or http://192.168.0.4
but it doesn't work
Thank you again for everything
Best regards
are your sure that your IP is correct? Because normaly the private IP is
192.168.2.1 for the router and
192.168.2.xx for any other devices.
I have a FritzBox and the AVM Routers have 192.168.178.1
So your IP 192.168.0.xx and the 0 I never saw
Regards
g.romano81
I'm sure the IP is correct
I have Windows XP Home edition
Mozilla Firefox 3.6.13
Javascripts are allowed in my browser
I use a router NETGEAR DNG2000
protection mixed WPA-PSK + WPA2-PSK
The IP is correct 192.168.0.xxx
Attached there is a Firefox screen shot (italian language)
Noha
Is somebody out ther how test flashing the Android rom?
I would get the Android rom!!!
But i think there is the same Problem with the "old" screen or did somebody know if this is no problem?
Noha
GeoBroker
Hi g.romano81,
I think I have an idear to solve your problem. Last night I remember that my phone dosn´t connect to my home network. What´s wrong:
I was in holyday and we stay in a hotel. I connect my phone to the free hotel wifi network. So when I came home my phone does not connect because the phone "forgot" the right settings for my home network.
Please do the following things:
first, delete your wifi profile
second, make a soft reset with the small der button on the back.
third, start wifi, and the phone will find your home network.
fourth, type in your security code an now you are connect to your home network.
fifth, start WiFi Remote Control and see what IP Adress now on the sreen.
at last I hope it is working now
good luck and best regards
closebor
