FET T8888 - qualcomm dual sim handy
J
johndebur
neues dual sim Android handy mit Qualcomm CPU von FET:
http://shanzhaiji.cn/mobile/20110616/24294.html
http://www.fetphone.com/fetphone.asp?id=55
http://cn.engadget.com/tag/FET+T8888/
We also wonder why so quiet recently in Shenzhen, saw this remote T8888 Andrews models, using Qualcomm Qualcomm MSM 7227 CPU, clocked at 600MHz, a selling point is the dual card dual standby, dual-card machine and past compared with some improvement.
Including 512ROM +512 RAM, before 300 000 after 5-megapixel autofocus camera, 1850 mAh battery 2, the other including Bluetooth 2.1, WIFI, 3.5mm headphone jack, Micro USB interface, support for GPS, radio, 3.8 inches capacitive touch screen with a resolution of 480x800, the back is a matte texture, built-in electronic compass, also equipped with distance sensors and light sensors, the current firmware version is 2.2, the producers said there will be 2.3 upgrade.
Lamanga
finde es lustig das jetzt auch die seiten gecloned werden :hihihi:
laut der seite ^^ soll es sogar angeblich hspa+ haben lol
Fork
... und ich finds schön, dass wir mal bei einem Chinamobile einen Screenshot des Quadrant-Benchmarks zu Gesicht bekommen: ;)
Aus einer der oben verlinkten Quellen.
C7R10
sieht dem HOT HD958 von etowalk ziemlich ähnlich an auch von der verarbeitung... weil wenn der preis auch um die 399 $ ist wäre mir das leider schon zu teuer :(
J
johndebur
hier noch ein Text von m8cool:
Qualcomm WCDMA dual-program machine T8888 coming out real machine multi-map
http://www.m8cool.com/zxsj/66895.aspx
In the early part of the forum put it over the design and the detailed parameters of the T8888, dual WCDMA, Qualcomm program the machine we have the impression it? Real machine out of it! 512ROM +512 RAM, before 300 000 after 5-megapixel autofocus camera, 1850 mAh battery 2, the other including Bluetooth 2.1, WIFI, 3.5mm headphone jack, Micro USB interface, support for GPS, radio, 3.8-inch capacitive touch screen with a resolution of 480x800, the back is a matte texture, built-in electronic compass, also equipped with distance sensors and light sensors, the current firmware version is 2.2, the producers said there will be 2.3 upgrade, Come see Figure!
