Yusun W702 - dual sim WCDMA handy
J
johndebur
WCDMA dual sim handy von yusun mit dem neuen MTK chip:
http://www.mobileuncle.com/news/devicenews/2011/0818/5644.html
YUSUN new machine language letter W702 gain another victory Bai flag program exposure MT6573
Basic configuration:
CPU: MTK mt6573 650Mhz
System: android 2.3
Network: WCDMA + GSM dual card dual standby
Network frequency 900MHz, 1800MHz
LCD: 3.5 inch HVGA resolution
Camera: 300,000 pixel camera deputy, the main camera, megapixel
Available colors Black
Dimensions 116.8 × 60 × 13 (mm)
Weight 135 (g)
J
johndebur
ein paar mehr details
http://shanzhaiji.cn/mobile/20110908/25066.html
MT6573 +3 G Dual language letter W702 "artifact" will debut
W702 "Artifact" has a side of the 3.5-inch HVGA touch screen with a MediaTek MT6573 solution, clocked at 650Mhz, Android2.3 equipped with the latest operating system, carrying massive applications that support WCDMA + GSM dual mode dual standby, 30/130 ten thousand pairs camera.
Artifact main performance parameters: Dimensions: 116 × 63 × 13mm, weight: 135g, Web: GSM900/1800MHz WCDMA2100MHz, Chipset: MT6573 + MT6162, clocked at 650MHz, the system platform: Android2.3, Screen: 3.5 inch, 320 × 480 pixels Camera: Rear camera 3.2 megapixel, autofocus, front camera 30 megapixel, memory capacity: 512MB ROM, 256MB RAM, extended memory: 8GT card, maximum support 32G, wireless connectivity: Bluetooth, Wi-Fi, GPS: support GPS, other features: acceleration sensor, proximity sensor, photoelectric sensor, FM radio, interface: Micro 5 pin, 3.5mm headphone jack, battery capacity: 1550mAh.
256MB RAM ??? warum machen die das noch???
Gute Frage, scheint bei den MT6573 Phones aber fast "Standard" zu sein?
Entscheidend ist ja eigentlich nur, wieviel Ram ist noch frei, wenn man alles Mögliche gebootet ist. Bei meinem Lenovo A60 habe ich trotz Intallation vom Launcher Pro ca. 80MB freinen Ram und das reicht dicke :)
