UMEOX X3 - dual sim 5,3" screen - MT 6573
J
johndebur
hat den alten MT6573 Chip , aber dafür ein 5,3" display.
http://www.mobileuncle.com/news/devicenews/2011/1226/6871.html
UMEOX beautiful 5.3-inch X3 listing MT6573's first dual card dual standby mobile phone the
The phone started this UMEOX beautiful X3 booked. Using MT6573 ARM1176 650MHz low-power processor architecture, with a Power VR SGX531 OPENGL
Using MT6573 ARM1176 650MHz low-power processor architecture, with a Power VR SGX531 OPENGL 3D ES1.1/2.0, 16M tps and max. 500Mpps graphics accelerator, supports WCDMA 3G and GSM 2.75G double standard, GSM (850/900/1800/1900 MHz), WCDMA (BAND1/BAND5), at speeds up to DPA 7.2Mbps/UPA 5.76Mbps.
This beautiful mobile phone using an advanced high-energy lithium-ion polymer battery capacity of 2550 mAh, larger than the average smart phone battery over 50%, light weight and electrolyte does not leak, and does not contain any harmful metals and there is no battery memory effect , called the green battery.
UMEOX beautiful X3 basic parameters of reference
Brand beautiful (UMEOX)
Type X3
Colors black
Listing Date in 2011
Appearance Bar Phone
Video call support
Other Intelligent Systems Intelligent Systems
Phone operating system UI (developed based on Android 2.3.5) + Android dual system of native
Smartphone product category
CPU model MT6573
CPU frequency of 650MHz
Touch screen input
Type of entertainment
Network
Network standard WCDMA handsets
Support band GSM (850/900/1800/1900 MHz), WCDMA (BAND1/BAND5)
WWW browser support
WAP browser support
Show
The main screen size 5.3 inches
The main screen color 167,000 color
TFT main display materials
The main screen resolution of 480x800 pixels
Touch screen capacitive screen, multi-touch
Gravity sensor support
Light sensor support
Support from the induction
Storage
Body Memory 1GB 512MB RAM +512 MB ROM
Type of memory card support TF card (microSD card)
32GB maximum storage expansion
Camera
Camera with
30 million pixels, vice camera
Pixels 5.0 million pixels
CMOS sensor
Flash LED lights
Video capture support
Continuous function support
Zoom mode, auto focus, image stabilization function
Graphic format support JPEG, PNG, GIF, BMP and other formats
Image size 3264 * 2668
Battery specifications lithium batteries
Battery capacity 2550mAh
Up to 700 minutes talk time Theory
Up to 480 hours of standby time
3.5mm headphone jack
Data Line Interface USB 2.0
Product size 150 * 81 * 11.7 mm
Body weight 178g
Products built-in antenna
f2001
One_Eye
da ich was um die 5" suche wäre das ja eine alternative.
hat jemand hierüber evtl schon ein video gesehen, auf yout... ist nichts vorhanden.
was ist das für ein co-prozessor, und stimmen die 800mhz.?
Dahmer
Persona non Greta
das habe ich ja in dem anderen thread schon empfohlen,wurde aber mehr oder weniger abgelehnt
Dahmer
Persona non Greta
ja,abgesehen davon das die geräte nahezu identisch sind,ist das auch ein entscheidendes argument :)
platoom
suche für:
Umeox X3
bzw
Simvalley SPX-5
den LCD als Ersatzteil.
vielleicht kann jemand von euch helfen
im voraus schonmal Danke
N
nubbeldupp
Die Daten sind sehr verwirrend... habe das Handy gerade bei ebay und bei etowalk.com gefunden...
Die Ebay-Beschreibung müsste eigentlich die gleiche wie bei etowalk sein... unterscheidet sich aber... so hat das Handy auf ebay 800MHz und auf der Seite nur 650MHz
EBAY:
CPU
Dual Core
CPU: MT6573T ARM11 800MHz + MT6162 ARM9 400MHz
GPU: PowerVR SGX 531
UMEOX X3 3G WCDMA Android 2.3 Dual Sim 5.3" Capacitive Touch Screen Wifi GPS | eBay
etowalk:
CPU
Dual Core
CPU: MT6573 ARM11 650MHz + MT6162 ARM9 400MHz
UMEOX X3 3G WCDMA Android 2.3 Dual Sim 5.3 Capacitive Touch Screen [2871] - US$399.00 - Smartphone Professional - EtoTalk
Wie man sieht soll die CPU bei ebay sogar anders heissen :)
I`m confused... :resent:
N
nubbeldupp
Dann bin ich ja beruhigt... wobei ich auch nix gegen eine 800MHz CPU hätte :p
schranzed1985
@ColonelZap: Der Thread hier hat zwar schon nen langen Bart, aber eines würde ich trotzdem gern los werden......;-) Der MTK6573 läuft NICHT immer auf 650MHZ. Das ist nur der Standardmäßig eingestellte Takt. Der Chip lässt sich in 1MHZ- Schritten von 299-806MHZ skalieren. Das Umeox X3 bzw SimValley SPX-5 läuft mit 806MHZ absolut stabil
Tip: Playstore, MTK CPU-Control 0,99cent. Zum übertakten ALLER Handys, die auf dem MTK 6573 Chip basieren!
Wer sich ein bißchen mit Android und vor allem Linux auskennt, der weiß, das die Speicherverwaltung von Android nicht wirklich dem entspricht, was für ein Smartphone das beste wäre.
Gegen mein SPX-5 ist ein iPhone4 ein langsames Handy!
Wenn sich genug Leute dafür interessieren, poste ich gern ein Tutorial, wie man mit größerem Cache, virtuellem Arbeitsspeicher und eine durch einen simplen Tweak wesentlich schnellere SD-Karte ein deutlich schnelleres und vor allem flüssig laufendes SPX-5 bekommt!
Von der Original-Speicherverwaltung mal abgesehen, haben die Chinesen ein meiner Meinung nach sehr gelungenes Gingerbread gebastelt, Das einzige was mir fehlt ist die Loopfunktion vom Kernel und (sehr ärgerlich) es wird leider nur das Fat32 Dateisystem unterstützt. Wer also gern bastelt und zb Embedded Ubuntu aufs SPX-5 flashen will muss selbst entsprechend nachbessern.....
