Neues Pad ???
hotwebnet
Ich würde mir gerne ein neues Pad kaufen, habe 150€ zur verfügung und frage nun einmal in die Runde welches ich mir kaufen soll ??
10,1" soll es haben HDMI und einen schnelle CPU, natürlich auch ein gutes Display auch bei sonneneinstrahlung...........
J
johndebur
gibt angeblich tablets für 500 yuans, allerdings mit kleineren Displays. Aber ob man damit glücklich wird weiß ich nicht.
shanzhaiben link
Here are a A10 Tablet PC program from Shenzhen far Lee, 8-inch 1024 x 768 resolution, multi-touch capacitive screen, black two color choices, run Android4.0 system, now the price is only The 4XX element.
Other configuration parameters: 512M RAM, 4G storage, with front camera supports video calls, Mini USB extension, HDMI high definition output, and can also customize the 1G RAM and 8G storage with version.
shanzhaiben link
Screen is very obvious to use the experience to enhance the Tablet PC, I7,-T, recently listed Haina Aurora version is powered by 7 inches with a resolution of 1024 x 600 HD IPS screen display and touch operation experience are very good, moreis the dual-core processor and IPS HD screen Heiner I7,-T priced at a mere 499 yuan, great value, Heiner's slogan is: to spoil your eyes!
oder für unter 600 yuans ein mini ANdroid laptop:
shanzhaiben link
The the first full-of Chi A10 the netbook market, the price of 5XX
Following this product is very popular in the domestic low-end flat-panel A10 processor, based on the Cortex A8 architecture, clocked at 1.1GHz, 512M memory, built-in 4G memory, using the 10.1-inch 1024 x 600 LCD screen. To run Android4.0.3 system, the wealth of Android apps can be installed to support 2160P HD video playback, can be relatively smooth to play online video, with the front camera for video calls, the body is equipped with three USB ports, you can easily connect a variety of outside set, RJ45 Ethernet port, 3.5mm audio input and output, a standard SD card slot, battery life of 4-5 hours.
