Getek A8 - Mt6575 5,2" WVGA display
J
johndebur
noch ein handy mit großem Display:
mobileuncle link
5.2-inch flat-panel phone imitation of the Samsung i9220 MT6575 Gaoke A8 grand debut!
Hi-Tech Group's latest, Gaoke A8 Listing. This section the Gaoke A8 tablet phone, drawing on the design style of the Samsung I9220, Samsung desktop system is also used, using the high-definition 5.2-inch capacitive screen design, the use of the Taiwanese chip MTK6575 platform, clocked at up to 1GHZ, battery is Shakespeare Di battery chips, the capacity of the real 2600 mA (User testing, normal use to two days) hare points to 3500 points, test 5:00 Touch.
Two of the original factory configuration: the original battery, original direct charge, the original headset original memory card 8G manual, warranty card, box.
The manufacturer presented a spree: the original protective shell, original charger, original protective film, the original 3D red and blue glasses.
Now we attach the Hi-Tech A8 basic hardware parameter information!
Network frequency of 900MHz, 1800MHz
Screen parameter single-screen
Available colors Black
Dimensions 149 × 82.2 × 11.4 (mm)
Weight 265 (g)
16 million color screen color depth
Carry-band dual-band
Of two of the Standard battery, a charger, headset, data line
GSM mobile phone standard
Display parameters
Screen pixel external screen parameters: 800 × 480; screen size: 125.1 × 74 × 2.25 (mm); support the touch screen, TFT
Operating system android
Operating system version number of the android 2.3.6
WAP functions Support Wap 2.0
GPRS function Support
Camera support for the first 30 million pixel 500 million pixels. , Built-in 5 million pixel
The number of camera
JAVA function support, MIDP 2.0
Phone memory 4GMB
Local connection Bluetooth, USB
Does not support handwriting input
Radio support, built-in
MMS support
USSD not supported
POC (PTT) is not supported
WLAN support
Streaming media support
IMPS does not support
SyncML is not supported
Supported media formats
Video playback 3GP, MPEG-4
Audio playback of WAV, AMR, MP3, MID
Picture format JPG, GIF, PNG, of BMP
DRM digital rights management is not supported
EDGE functionality support
MP3 support
Core chip (chipset) Model MT6575
Electronic dictionaries do not support
PDA functionality is not supported
E-mail support, POP3/SMTP
GPS does not support
Optical zoom is not supported
Extended storage support, Tflash cards
Expansion card capacity to support
3G is not supported
RFID does not support
Custom-the-shelf
Camera tone, to close the
TV function is not supported
