ZTE Grand X LTE T82 - TD + LTE + CDMA 4G - 1,5Ghz Qualcomm dualcore 1900 mah ICS
J
johndebur
neues handy von ZTE, das ja theoretisch überall funktionieren sollte? Läuft mit ICS und unterstützt LTE, TD und CDMA . Weiß zwar jetzt nicht was die mit TD meinen? TD-SCDMA also UMTS? TD-SCDMA - Wikipedia, the free encyclopedia
LTE gibt es hier ja auch.
Hat einen Qualcomm MSM8960 dual core mit 1,5 GHz verbaut und eine 1900 mah Batterie.
Soll auf jeden Fall ab Herbst auch in Europa erhältlich sein
TD+CDMA+LTE?中兴Grand X LTE T82登场-新机-山寨机网
Of TD CDMA LTE? ZTE the Grand X-LTE T82 debut
In the recently held 2012 23rd international telecommunications exhibition in Singapore, ZTE has released a new machine to support 4G network model for the Grand X of LTE T82, the aircraft is ZTE's first single-chip LTE 4G phone. The Grand X-LTE equipped with Android 4.0 system, CPU Qualcomm MSM8960 dual-core, clocked at 1.5G. The main camera is equipped with 8 million pixels (1080P HD video capture and playback), the battery capacity of 1900mAh. Is the world's first positive key LTE handsets. The Grand X-LTE on the 20th of this month will also be on display in the GSMA Mobile Asia Expo, the third quarter is expected to visit the Asia-Pacific and European markets.
MSM8960 Qualcomm fourth-generation mobile chip, dual-core 1.5GHz. Based on the ARMv7-A "Krait" (Bungarus), using 28nm process, with new graphics core Adreno 225 and the support of almost all the new communication standard baseband. Which includes all of TD-SCDMA, CDMA, 3G network and Cat.3 LET, the network, there are now popularity of Bluetooth, Wifi, FM and emerging NFC technology, the MSM8960 one chip can be the perfect support. Compared to the current multi-chip solutions for mobile phone manufacturers commonly used higher degree of integration, lower power, higher performance.
