A-GPS - doubt
JATG
I'm about to buy a mobile phone white label that says owning just "A-GPS" (not internal GPS).
If I install a browser like CoPilot and respective maps on sd card, I can navigate offline?
In other words, my question is whether the system with A-GPS it is possible to browse offline, without spending net traffic, since the browser and maps are on the respective memory card.
Or this system always needs to connect to the network?
Thank you.
A-GPS is just a network based support for real GPS. A-GPS needs a working network connection.
So you can not use it offline at all.
Regards,
Mario
If a phone has A-GPS that SHOULD indicate that "real" GPS is also there. Nobody makes a phone with JUST A-GPS, A-GPS without real GPS doesn't make any sense.
JATG
In some shops says GPS built-in in other shops says A-GPS.
I don`t know if is just A-GPS or GPS and A-GPS...
What you think?
closebor
