Star V12 mit MTK6577
Kimbo
Okay Cool =) Danke für die Infos =)
Wäre noch super wenn du mir sagen könntest wie ich die Firmware drauf bekomme ;)
Bin Android neuling ...
Hatte vorher nur iOS und Firmwares jenseits der Touchhandys geflasht xD
I have found a way to flash my phone with a good ROM with Google Apps (including the Store!), here is my procedure. (Enschuldigung, mein Deutsch nicht gut für einen so lang und technisch Text)
uleFone V1277 / Star V1277 MTK6577 ROM Flash procedure
Warning:
This procedure is from my personal experience with my own uleFone V1277. I can't guarantee that it will work with your phone.
Greetings:
Thank you to the community of the following forums and websites:
-http://forum.china-iphone.ru (For the ROM)
-http://chinamobiles.org (For the flash tool)
-http://bm-smartphone-reviews.blogspot.fr/2012/05/mt6575-flashing-tutorial.html (for the help)
What do you need.
• SP Flash Tool: SP_Flash_Tool_v3.1222.00 software SP_Flash_Tool_v3.1222.00 - Downloads - Chinamobiles.org
• A ROM, I used this one: V1277-1009T_120807_OV5647_ICS2V1_V02_COM_EN
Яндекс.Народ
• Windows XP (I didn't tried with Vista/7)
How go in "Flash" mode
-Turn off the phone
-Remove the battery
-Replace the battery
-Plug the phone into the computer
After that, Windows should ask for the driver.
How to install the driver
The driver is in the \SP_Flash_Tool_v3.1222.00\new usb driver directory. The hardware name is. MediaTek PreLoader USB VCOM Port:
TIP:After the installation of the driver, the phone will show an battery logo and will disapear from the Device manager list. thats, OK, the phone will not stay in "Flash" mode if it doesn't receive instruction.
How to use SP Flash Tool
Thats easy, but need a good timing
First, shut down the phone and remove the battery.
Launch "\SP_Flash_Tool_v3.1222.00\Flash_tool.exe
Sélect the "Scatter-loading" file:
"\V1277-1009T_120807_OV5647_ICS2V1_V02_COM_EN\BIN\MT6577_Android_scatter_emmc.txt"
Warning: The "\SP_Flash_Tool_v3.1222.00\MT6577_Android_scatter_emmc.txt" file is almost identic but will cause problems with the user partition.
The .img files list is automatically updated
Press the "Download" button. The program will wait for the phone
Plug the battery in the phone and plug the phone to the computer
If the driver isn't already loaded, windows will ask for the driver
Flash procedure will begin. The progress bar will change of color and will finish with a green "O"
im grunde kannst du dich an diese anleitung halten, musst halt nur die neue firmware verwenden.
Kimbo
Hab die ROM jetzt geflasht und der erste eindruck ist Mega =D
Keine Multitouch bug
G Sensor geht
und ich habe denn eindruck das das OS flüssiger läuft.
Aber das beste kommt noch das Speicherproblem ist endlich gelöst,ich dachte erst wasn kack SD Karte wird nicht mehr erkannt,dann guck ich genau und siehe da,die SD Karte wird als Telefonspeicher genutzt.
Da ist eine Russenapp aber die Stört bis jetzt nicht und bekommt man auch irwie runter.
Handy ist auch schon Gerootet alles top.
Was mich sonst stört ist das Boot logo das nicht Orignal ist und die Batterie anzeige.
Sonst Top ROM bis jetzt werde nach ein paar tagen nutzung nochmals berichten ;)
bigmadmike
Hallo geht bei der Rom das GPS?
Hallo, ja GPS geht, ist eigentlich auch recht fix bei Navigon Select.
Im großen und ganzen läuft 121010 recht gut, kein Multitouch-bug und der G-Sensor funktioniert auch.
Speed ist auch sehr gut, Antutu zeigt ca. 5320 Punkte, fast 500 mehr als bei meiner 120829.
Nur ein Fehler hab ich und zwar wenn die Batterieladung unter 15-10 Prozent fällt, schmiert die systemUI ab.
dunicht
Eine geniale Rom bin voll zufrieden :yes:!
Alles Funktioniert Tausend dank an die Entwickler, dieser gelungenen Rom .
l.g. dunicht
Datscher
beim "Fummeln" habe ich mir die SystemApps zum Einstellen der USB-Verbindungen geknickt. Nun komme ich natürlich nicht mehr an die USB-Schnittstelleneinstellungen undf habe keinen Zugriff auf den Rechner. Über das Flashen eines neuen Roms müsste ich das doch wieder hinkriegen, oder? Nur wie geht das Flashen ohne USB-Verbindung? Eventuell über die SD-Karte?
Ich freue mich über jeden Hinweis :Mauridia:
Vielen Dank im voraus
Datscher
L
lauterohre
Hallo Datscher, hast du mal probiert ein Rom drüberzuflashen ?
Ich vermute, das sollte funktionieren da ja bei ausgeschaltetem Handy geflasht wird.
Datscher
Das habe ich mit verschiedenen Roms versucht, aber leider kommt immer die Meldung:
Error: Invalid OTA package, missing scatter. Update.zip ( V1277-1009T_120829_OV5647_ICS2V1.3_V05_COM_EN.7z) is not correct. Installation aborted.
Nun weiß ich nicht weiter.
bigmadmike
Versuch mal wie oben beschrieben zu Flashen. Von sd hat bei mir auch nicht geklappt.
bigmadmike
Also wenn du so Flashst wie oben beschrieben ist das Handy eh aus.
So ein ähnliches Problem hatte ich auch als ich die schon, Systemui ausgetauscht hatte.
Handy war nicht mehr als Laufwerk aufgetaucht nach Anschluss an USB.
Wenn du Flashen willst, nimm gleich die 121010.
http://dl.dropbox.com/u/23346928/
Star%20V1277%20Firmware%20v2.0/
V1277_121010_ICS2V1.3_V05_OV5647_COM_EN.7z
dunicht
Ich lade dir ein sauberes Backup hoch, Link kommt mit einer PM an dich
Das kannst du über das CWM flashen.
l.g. dunicht
Ach ja du musst die clockworkmod.zip vorher entpacken!
Ich kann nicht nachvollziehen, ob ich dir nun eine Private Nachricht gesendet habe, da bei mir im Postausgang nichts drin ist!
oskaliope
