UMI X1S - MT6589 4,5" HD display (720p) 1GB Ram 4GB Rom JB
J
johndebur
noch ein Umi mit MT6589 chip, laut gerüchten soll es so um die 1000 yuans kosten.
8.5毫米四核优米UMI X1S配置曝光 - MTK手机网
8.5 mm quad-core quality rice the UMI X1S configuration exposure
High quality rice phone recently exposed upcoming quad-core star models UMI X2 configuration, attracting countless friends and the media attention, only 1499 yuan price and powerful hardware configuration and quality rice vermicelli s heart. From high quality rice Mobile recently announced 2013 first and second quarters
High quality rice phone recently exposed upcoming quad-core star models UMI X2 configuration, attracting countless friends and the media attention, only 1499 yuan price and powerful hardware configuration and quality rice vermicelli s heart. From high quality rice Mobile recently announced 2013 first and second quarter of product planning, we can see the shadow of another MTK6589 phone the phone model quality rice UMI X1S, you can see that after excellent meters X1 quad-core upgrade version.
Quality rice phone
As can be seen from the table above, the parameters, The excellent meters X1S keep the X1 ultra-thin body design, measurements size of 129 * 68 * 8.5mm X1 If the guess is correct, UMI X1S may continue to use the dual-core version of the appearance design. Obvious hardware upgrade the, X1S equipped with the MediaTek MT6589 four-core 1.2GHz processor, built-in PowerVR SGX544 graphics processor. Screen specifications and X1, 4.5-inch IPS screen, the the HD level 1280 * 720 resolution, 326 PPI reached the retinal level, the touch screen using the the Corning second generation glass screen. Memory, and camera specifications and X1, the 1G RAM +4 G ROM memory as well as the first 200 million + after 8 million camera. But the battery to get upgrades, higher capacity polymer lithium battery, the battery capacity of the same body size UMI X1S rose to 1850 mA, built-in three-axis gyroscope, including commonly used sensing devices running Android 4.1 jelly beans system.
The excellent the meters X1S the time-to-market with the X2 about are officially listed in the first quarter of this year, priced at a thousand-level speculated $ 999. Quality rice Mobile had very low-key, this one published the Xiangxi configuration of the two new machines, blockbuster effect has been reached, but the two phones hardware parameters, and the price is certainly attractive, but work more important product launch will continue to surprise everyone.
J
johndebur
soll angeblich 999 yuans kosten? ist im Grunde ein umgebasteltes X1. Angeblich wird erst das X1S erscheinen und dann das X2. Also verzögert sich das X2 etwas, gibt auch technische Probleme mit der 2GB Ram Variante, die erstmal gelöst werden müssen.
千元四核优米X1S近期先行上市
Thousands of quad-core the quality rice X1S recent first
Quality rice phone has the latest news, the official has announced the latest dynamic quality rice products, reads as follows: "quality rice X1S have mature production line and supply chain, will be listed in the most recent, although we are much more concerned about the high quality rice X2 small only sorry to say slightly slightly again be understood from the above text thousand dollars of high quality rice X1S will be the first listed and X2 2G memory exists some difficulty still optimize test, and listed time or the back to be postponed, but the official affirmed, that is X2 the same will be listed later.
As for quality rice X1S morning had been exposed in X2 publicly when the relevant configuration, but its light is X2 concealed X1S positioning '000 entry-level quad-core products, the X2 uses the same MTK MT6589 quad-core processor.
Official yet to be announced over the excellent the meters X1S the appearance photo, but to infer from the known parameters, X1S may design and X1, both dimensions are 129 X 68 X 8.5mm, and X1 has 8.5 mm The slim, black and white colors. Will be equipped with the MTK6589 four nuclear program, the processor frequency rate of 1.2GHz, supports WCDMA / GSM dual-mode, small battery capacity rose to 1850 mA system version Android 4.1. Memory, camera, as well as the screen most of the specifications and X1 relatively close, X1S 1G RAM +4 G ROM memory, equipped with 4.5-inch HD-level resolution of 1280 x 720 IPS wide viewing angle screen, the Corning second generation tempered glass external screen, In addition, with 2 million + after 8 megapixel camera, the main camera for the back-illuminated second generation, F2.4 aperture. Built-in gravity, light, magnetic distance sensor and gyroscope, entertainment and more. This article from the the MTK phone network http://www.mtksj.com
Quality rice phone official news quality rice X1S in the basis of the original X1 system optimization better, the same time the the X1 small body problems have solutions, addition X1S fastest month in mid-volume production, forecast price of $ 999 .
mur1967
Stellt sich die Frage, ob sie mit den neuen Modellen das GPS Problem gelöst haben. Ansonsten 5 $ mehr und das Hero H7500+ kaufen. Argh, die haben auf den Bildern neben den Hardware Softkeytasten, zusätzlich die Software Sofkeytasten.
nizeazz
Da scheinen ziemlich viele hersteller probleme mit der RAM zu haben. Ich schätz vor mai gibt es kein jiayu oder umi x2 mit 2gb zu haben zumindest in EU nicht. LEIDER!
J
johndebur
benchmark Fotos und hardware info :
运行Android 4.2 优米X1S跑分信息
Running Android 4.2 You running meters X1S, partial information
Excellent rice phone official said recently that its entry-level '000 quad-core smartphone the quality rice X1S fastest production in the middle of this month listed in the hardware configuration can not be compared with the X2, but if it opened in March to sell , there was still a lot of users will choose the first listing X1S, which is why unknown MTK6589 phone Taobao sales considerable reason. The official quality rice has begun the campaign trail for UMI X1S information has been released before the aircraft safety Bunny ran sub:
Ann Bunny V3.1 version of the evaluation showed that the the comprehensive quality rice X1S run points about 12600 points, with many little difference between MT6589 quad-core processor models run scored and can be found, in addition to the information through the system detects parameters vary with the initial official release of the, UMI X1S system upgrade to Android 4.21 version, original announce the X1S system 4.1.
1-130124004040114.JPG1-130310013524K4.jpg1-130310013511W8.jpg1-13031001345I09.jpg1-13031001343KW.jpg
J
johndebur
Fotos vom X1s und kostet 999 yuans:
Excellent the meters X1S price confirmed for 999 yuan more than the appearance of images released
Information some time ago quality rice phone official announcement, UMI quality rice X1S may be the first listing, tentatively priced at $ 999, before the excellent rice phone official also confirmed the UMI X1S the final pricing is the 999 yuan, listed in the near future. X1S X1 quad-core upgrade version, not just a simple upgrade some hardware configurations, lack of X1 itself once existed have been optimized, X1S debut will be a new image.
The UMI X1S core hardware parameters are as follows:
Processor MTK MT6589 1.2GHz quad-core
Memory 1G RAM +4 ROM
Screen 4.5 inches IPS 1280 * 720 the Corning second generation glass
Camera 2,000,000 + 8,000,000 back-illuminated F2.4 aperture
Battery 1850 mA
System Android 4.2
Sensor Light, gravity, distance, magnetometer, gyroscope
Function Bluetooth 4.0, WIFI, GPS and WCDMA + GSM dual card dual standby
Selling price 999 yuan
The quality rice X1 initially debut as recommended machine, Brush Wizard a dual-core smartphone, powered by a MTK6577 dual nuclear program, many users attention due to the ultra-thin body, mainstream configuration as well as the competitive price, as the upgraded version, high quality rice X1S as well as brand new X2 these quad-core products is a lot of loyal powder high hopes, hopes the high quality rice to bring satisfaction jiyou early works.
J
johndebur
Umi X1S im vergleich mit der Dualcore Variante (weißes handy ):
优米X1S工程机与双核X1对比 mtksj
Of excellent rice X1S engineering machines with dual-core X1 contrast
Remember X1 is just out of high quality rice, by virtue of the Brush wizard through brush ROM strong call to get the attention of a lot of friends through strongly recommend machine platform, also about to launch soon gifted meters X1 is an upgraded version of the quad-core, this model for excellent the meters X1S the quad-core phone is priced uncertain, with dual-core version price remained at 999 yuan. Quality rice before phone official has released a real shot the UMI X1S engineering machine, and comparison photos with the dual-core version.
First, let's compare the excellent of meters X1S and X1 is different at, based on the official fed information, on the basis of the X1, of quality rice X1S in the following changes:
1, MTK MT6589 quad-core processor upgrade
2, the system upgrade to Android 4.21 version
3, the switch to the the Corning second generation glass screen
4, X1S will be equipped with breathing lights
5, the battery capacity upgrade
Specifically what improvements yet to be officially announced, another official said optimization of X1S will be better.
1-1303152255594Q.jpg1-13031522554V17.jpg1-13031522553LS.jpg1-130315225510241.jpg1-13031522544H48.jpg1-130315225411161.jpg1-130315225300192.jpg1-130315225431359.jpg1-130315225250O0.jpg1-1303152252341E.jpg
funtron
Ich habe 2 umi x1s am 2.4 Bestellt mal schauen wann sie da sind.
UMI X1S Smart Phone MTK6589 Quad Core 4.5 Inch Gorilla Glass Screen Android 4.1 1G RAM 5.0MP Front Camera
SD card: none
Colour: Black
€163.18
1 of. UMI X1S Smart Phone MTK6589 Quad Core 4.5 Inch Gorilla Glass Screen Android 4.1 1G RAM 5.0MP Front Camera
SD card: none
Colour: White
€161.54
Sub-Total : €324.72
EUEXP: €34.20
paypal fee: €12.99
Grand Total : €371.91
also €185,95 alles inklusiv :)
-jha-
Ich bin ja echt mal gespannt, wann diese Umi-Phones wirklich real von irgendwem hier in den Händen gehalten werden. Langsam beschleicht mich fast das Gefühl, die Dinger müssten erst vom Yeti persönlich nicht nur zusammengeschraubt, sondern auch zur Post gebracht werden.
tritronic
Ich habe jetzt seit zwei Tagen ein UMI X1S. Nachdem ich mein schönes ZP980 die Treppe runtergeworfen hatte und der Touchscreen gebrochen ist, musste aus der Not heraus ein neues Telefon her.
Die technischen Daten entsprechen tatsächlich dem, was in den Shops so über das Telefon zu lesen ist.
Das X1S ist von der Grösse her sehr angenehm, die verarbeiteten Materialien sind allerdings deutlich weniger wertig als die meines bisherigen ZP980. Naja irgendwo muss der Preisunterschied ja auch herkommen, es war ja auch fast nur halb so teuer.
Gefühlt läuft das X1S deutlich flüssiger als das ZP980, was sicher daran liegen dürfte, dass das X1S mit 1280x720 eine niedrigere Auflösung hat, die den MT6589 nicht ganz so an die Grenzen bringt. Ansonsten ist das Display des X1S sehr gut, sehr blickwinkelstabil und hell.
Alles, was ich bisher so testen konnte, hat ganz gut funktioniert, allerdings reagieren die Touchkeys manchmal etwas störrisch. Die Kamera macht für ein Chinahandy ganz passable Photos, für Schnappschüsse reicht es, für anspruchsvollere Dinge natürlich eher nicht.
Die Empfangsschwankungen beim WCDMA-Empfang (bei mir im D2-Netz) sind auch bei diesem Telefon zu bemerken, anscheinend ist das ein verbreitetes Problem der MT6589-Telefone.
Wie auch beim ZP980 ist ein OTA-Updater zu finden, ob der von UMI allerdings je für Updates genutzt wird!? Im Moment ist jedenfalls Android 4.2.1 mit der Firmware 20130511-184037 installiert.
Wenn ich in einigen Tagen wieder aus dem Urlaub zurück bin und Interesse besteht, kann ich gerne noch einen kleinen Testbericht verfassen. Bis dahin habe ich sicherlich noch einige interessante Infos über das Telefon gesammelt :)
