Star S 7589 rooten
komisch...
ich muß mich nicht anmelden :) bin auch nicht registriert.
hier die anleitung:
What to do:
Extract the 2 downloads to a clean folder
Copy the superuser zip to your phone’s SD card
Navigate to MTK6589 ADB driver folder and Run install_driver.exe regardless of whether you have 64 bit Windows or not, this is what you should run to install the driver. Running the other .exe does nothing. You should get a confirmation message saying the drivers installed successfully.
To make sure the drivers have been installed and are properly recognizing your phone, plug your phone into the USB and open device manager on your PC. Confirm at the top of device manager you see “Android Phone” > “Android ADB”.
Run flash_tool.exe from the previously extracted flash tools folder
On the right side of the Flash Tool, you’ll see “scatter loading”. Click that box and navigate to and select the scatter file in ‘CWM and scatter’ folder from the previously extracted zip. Now in the bottom half of Flash Tool, you should see ‘Recovery’ checked and pointing to the CWM ‘recovery.img’ in the ‘CWM and scatter’ folder.
Unplug your phone from the PC and turn it off. Some recommend a battery pull for a few seconds, but it wasn’t a step I took.
In Flash Tools, at the top click the “Download” box. A warning will come up saying not all boxes are checked. Click ‘Yes’.
Now you’re at the point of no return. Plug your phone back into USB. You’ll see the % bar at the bottom of Flash Tools increasing in different colors. At the end you’ll see a green circle in the middle of the screen confirming all has been completed successfully. Shouldn’t take more than a few seconds.
Now boot into recovery by holding UPVolume and the powerbutton. Hold them until you see the dead Android bot, then hit the power button. Your recovery should be blue. That means you’re in CWM.
Select update from SD in CWM recovery
Navigate with the volume buttons to the previously copied superuser zip and select it with the power button
Navigate to ‘Yes’ and select with the power button
Bam, it will install superuser. You are now rooted.
Reboot and search “root checker” on google play. There are several. Assuming all went well, you will see a dialog asking for root privileges. Alternatively, run whatever software you know requires root access and it will request root access if all went well.
dorschdns
ClonePhone Facharzt
Ich brauchte mich nicht anmelden, ich hab es mit der unter dem Link angegebenen Anleitung geschafft die Phones zu rooten.
Um die benötigten Files downzuloaden, hab ich die gute alte Tante Google bemüht.... hat auch geklappt.
Was soll das ganze Theater schon wieder?
hartmannsteffen
Thommy...du findest meinen Beitrag kindisch? Findest es kindisch, das ich mein Handy durch Hilfe eines anderen gerootet habe? Wo liegt eigentlich dein Problem hier? Das du mit einigen hier nicht kannst, ist bekannt. Schau einfach der Tatsache ins Auge, das es noch andere hier im Forum gibt, zb. eben dorschdns oder Herr, die auch was können. Neid und Missgunst sind wohl deine Begleiter. Ich dachte, das Forum ist dazu da, sich gegenseitig zu helfen.
R
rWx
die datein könnte man hier im download bereich hochladen, wenn sie nicht schon vorhanden sind. ( SP Flash Tool, CWM recovery, MTK6589 ADB drivers, and superuser)
ansonsten "Gizbeat Combo.zip hier hochladen
Jibbet schon hier, hab ich die Woche hochgeladen :)
http://chinamobiles.org/showthread.php?34257-Zopo-ZP810-ZP800H-H7500-Firmware-Root-Recovery
ADB Treiber sind aber im GizBeat Paket nicht dabei, braucht man auch nicht. Sind die VCOM Treiber, die man fürs Flashtool benötigt.
tommy0815
die Lösung heißt die richtige Version vom Flashtool nehmen.
z.B. die 48 oder am besten die aktuelle!
Edit: mit der 52 geht es nicht beim S7589
tommy0815
doch ist so!
Wieso schreibst du jetzt wieder was ohne es zu versucht zu haben?
Ich habs grad gestern erst wieder bei nem S7589 gemacht?
Slo
Hallo zusammen,
hab mir gestern eins bestellt, bin mal gespannt welche Version klappt :[
tommy0815
die einfachste version ist cwm-r aufs handy (findest du in meinem Thread) und dann die eine Datei per CWm-R installieren (die erste Datei aus Methode 3)
aber das war schon immer so....problem ist nur immer ne CWM-R zu bekommen, wenn man selbst keine basteln kann!
Aber für das Modell befindet sich ja eine in meinem Thread
hartmannsteffen
Und genau das ist dein Problem Tommy...erst immer irgendwas erzählen, von...ich weiß wie es geht, ich weiß welchen Fehler er gemacht hat...ich könnte es ihm sagen...aber einfach mal ordentlich erklären, nicht immer auf diese unglaublich rechthaberische Tour...würde dich gleich viel sympathischer erscheinen lassen.
tommy0815
hab ich dir angeboten das wir das zusammen in einer Teamviewer Session machen?
Weiß ich was du machst?
ICH habe kein S7589 wie kann ich dann Tips geben?
Hätten nur wir ZUSAMMEN machen können.
matt_smith hat sich an mich gewendet, weil er auch das S7589 hat und bei ihm kam der gleiche Fehler!
Es war also kein Bedienfehler deinerseits. Aber woher sollte ich das wissen?
Ich seh nicht was du tust und meine Hilfe hast du abgelehnt.
matt_smith war dankbar und wir konnten das Problem schnell lösen! Das hat keine 10 Minuten gedauert!
hartmannsteffen
Tatsächlich glaube ich dir sogar...ja, ich denke, du hättest das Problem mit mir gemeinsam lösen können. Nur verstehe weder ich, noch so manch anderer hier nicht, warum du immer erst vorher so ein Gewese draus machst und nicht gleich deine Hilfe anbietest, bevor du deine Weissagungen und Vorahnungen kundtust. Wie ich schon schrieb..es würde dich um ein vielfaches sympathischer machen.
tommy0815
mir ist egal was andere von mir denken.
Und ich denke wenn ich dir, einen Menschen den ich nichtmal persönlich kenne, anbiete meine Zeit für ihn zu opfern, dann spricht das nicht wirklich dafür das ich ein Assi bin oder?
Wenn ich dann aber deine Reaktion darauf lese...
von wegen Problem konnte nicht gelöst werden, kann geschlossen werden....sorry das ist einfach nur kindisch.
Mehr als meine Hilfe kann ich nicht anbieten. Wenn es nicht erwünscht ist ist es ok, ich dränge mich keinem auf.
Aber dann jetzt hier die Leute wild zu machen, was schließlich dazu geführt hat das jetzt eine universelle Rootanleitung für die 6589 erstellt wurde und auch noch gepinnt wurde, das ist wirklich schlimm.....da es nämlich keine universelle Anleitung ist!!
Ich "freu" mich schon auf die ersten Leute die sagen ich hab alles genauso gemacht wies in der Anleitung steht und nun fährt mein Handy nicht mehr hoch.
Dann muss ich den LEuten wieder erklären das es keine universelle CWM-R gibt und man für jedes Handy eine eigene CWM-R braucht und dann darf ich das am Ende wohl wieder ausbaden, weil die Leute sich dann alle an mich wenden und fragen ob ich ihnen helfen kann.
Ich helf ja gerne, aber wenn dann sowas bei rauskommt, dann überleg ich mir das 2x
Denn ich weiß auch besseres mit meiner Zeit anzufangen!
cliffgull24
