大锤手机1S Dachui 1S - MT6589T 5" FHD display 1GB Ram 4GB Rom 13MP Cam
J
johndebur
neues MT6589T Handy von Dachui. Gibt es einmal mit MT6589 und HD display ( Dachui 1 , bzw 大锤手机1 , Sledgehammer phone 1 ) und mit MT6589T und FHD display ( Dachui 1S , bzw 大锤手机1S , Sledgehammer phone 1S )
Hersteller:
http://www.dachui.com/
你震惊了没 大锤手机1/1S六月面世 mtksj
Are you shocked yet sledgehammer Phone 1/1S June launch
See the title you thought it was the old law of the hammer mobile phone, you are so wrong! Brand of the phone, called Sledgehammer Sledgehammer Technology Shenzhen registered, its two "Sledgehammer" Products and Sledgehammer Sledgehammer phone a phone 1S spot sale soon in June, but there is no specific time to market, and the sledgehammer What distinguishes mobile phones will have it, take a cursory look.
Sledgehammer phone
It is reported that the two products Sledgehammer Sledgehammer mobile phone 1 and 1S will use MTK6589 quad-core processor, but the difference is that the hammer on the 1st of the main frequency of 1.2GHz version, and 1S will use the 1.5GHz MT6589T. The other two are slightly different screen size, sledgehammer phone a screen size of 5 inches, equipped with HD 1280 * 720 resolution level, while 1S screen size consistent with the former, but the level of use FHD 1920 * 1080 resolution rate, the higher standard. Besides two versions may have to 1G RAM +4 G ROM memory, equipped with 13 million pixel high-definition camera.
005243n6e6xkxuszt8qf62.jpg005246hb3dwla46bd444xc.jpg005249lgdvgllwg0wxgl8q.jpg005253lsd0p0psjfzik929.jpg005259gvtgvzpkvvfbttnn.jpg005303p355hn1155v1evz3.jpg005307w5yya5tttrs9mnp9.jpg005311ay157ggiy17zv7y7.jpg005315p548twuiwudk93i7.jpgScreenShot016.jpg
oh, das gefällt mir, besonders die gerundeten seiten ....
preis ist noch nicht bekannt?
@john, könntest du die preise in zukunft in euro oder dollar angeben, wäre sehr nett :)
nö, aber zum essen kannst mich mal einladen...
ich komme mit den juans oder so nicht klar, deswegen.
J
johndebur
J
johndebur
Das Dachui 1 / 1S ist nun zu haben.
Das Dachui 1 mit HD display und MT6589 kostet 799 yuans ( 99€ )
Das 1S mit FHD und MT6589T kostet 999 yuans ( 124€ )
价格够草根 大锤手机1/1S今日开卖 mtksj
Price enough grassroots sledgehammer phone 1/1S on sale today
Earlier this month, has been exposed sledgehammer phone close to the old law because the name of the hammer system / mobile phones known by many users, but after the announcement of some products has not been below, has finally brought its sledge hammer mobile phone 1 and 1S re-appearance, the latest official information to display this product will be in today (the 24th) 10:00 started the first sale, a sledgehammer on the 1st of the official standard price is 799 yuan, while the higher specification 1S sold 999 yuan, total number of 1000, two versions of 50% each.
The first product sledgehammer phone internal model C1, can be seen as a sledgehammer on the 1st Standard Edition, 1S is the high version, the biggest difference is the processor and screen size difference. Phone one uses a sledgehammer main frequency MTK6589 1.2GHz quad-core processor, and the processor 1S updated MT6589T, main frequency up to 1.5GHz, a screen aspect sledgehammer to HD resolution 5-inch IPS screen, 1S with the 1080P 1920 * 1080 resolution, the same size. In addition, according to the official website of the information point of view, these two almost identical versions of the other aspects of the built-1G RAM +4 G ROM memory, support for expansion, standard capacity of 2600 mAh battery, after former 3,000,000 + 8 million pixels dual camera, running Android 4.2 version of the system. Both body size is 142 * 72 * 9.5 mm, supports WCDMA + GSM dual card dual standby, built-in light, distance and gravity sensors.
Sledgehammer phone
Sledgehammer phone name is "Ray," the packaging information from the official point of view the exposure enough thunder, which tether is the legendary "rope" do? How ever more like a simple gift box packaging.
From a price perspective, sledgehammer phone is indeed relatively low, just feel now with the old hammer OS Lo detached, should people have in the system's performance is refreshing, but unfortunately did not see a special presentation, interested Friends of the machine available at the official website to learn.
bzw gibt es da unterschiedliche Pakete ? Wahrscheinlich gibt es noch irgendeinen Schnick Schnack dazu ?
  • 720P bare metal version of ¥ 799 ( €99 )
  • 720P Package Version ¥ 999 ( €124 )
  • 1080P bare metal version of ¥ 999 ( €124 )
  • 1080P Package Version ¥ 1299 ( €161)
1-130624015IB63.jpgFireShot Screen Capture #032 - 'Google Übersetzer' - translate_google_com_translate_sl=zh-C.jpgScreenShot002.jpgScreenShot001.jpg1369307195_62_7513.jpg1369297261_59_6679.jpg1369297259_73_8820.jpg1369306702_19_9962.jpg1369306695_66_4297.jpg1369306731_06_2336.jpg1369306709_01_2467.jpg1369306723_99_9691.jpg1369306713_83_1546.jpg1369306719_04_4763.jpg
  • CPU frequency 1500MHz
  • Quad-core CPU model MTK6589T
  • GPU Power VR SGX544MP
  • Keyboard type virtual QWERTY keyboard, handwriting input
  • Input retina screen, multi-touch
  • System Android 4.2.1 OS
Capacity
  • Memory 1G RAM + 4GROM
  • Extensible Storage 16GB, 32GB optional
Network
  • Network standard WCDMA / GSM
  • Network Frequency GSM 850/900/1800/1900MHz
  • WCDMA 850/900/1900/2100MHz
  • SIM card supports dual card dual standby
  • Data services GPRS / EDGE / HSPA +
  • GPS GPS + AGPS
  • Bluetooth Bluetooth 2.0
  • WIFI WIFI 802.11b/g/n
Battery
  • Capacity 2600 mA
Screen
  • Screen size 5.0 inches
  • Multi-touch screen material FHD Full HD screen fit
  • Resolution FHD 1920 * 1080
  • Touch screen capacitive screen, multi-touch
Photograph
  • Rear camera 8 million pixel autofocus
  • Front camera 3,000,000 pixels
  • Sensor type light sensor, proximity sensor, orientation sensor, gravity sensor
  • Flash LED flash
  • Large aperture F/2.2 aperture
  • ISO sensitivity mode support
  • Metering mode support
  • WB support
  • Focus mode support
  • Focus area support
  • Autofocus support
  • Shooting style support
  • Shooting scenes support
  • Other features face recognition, auto focus, image stabilization, real-time filters
Camera
  • Video capture 1920x1080 1080P HD camera
  • Other video night mode
Multimedia Player
  • Music player supports mp3, acc, amr, ogg, m4a, mid, wma, flac, ape, aac, wav and other formats
  • Video playback support mp4, h.263, h.264
  • Picture playback support JPEG, PNG, GIF, BMP and other formats
  • Flash Player Support
  • Radio Support
External buttons and connection port
Inductor
  • Gravity sensor support
  • Distance sensor support
  • Electronic compass support
