Changhong Z9 - MT6589 5,5" HD display 5000mah Akku ? JB 1Gb Ram ?
J
johndebur
neues handy von Changhong mit 5000mah Akku und eventuell MT6589 , die hardware Angaben sind im Moment nur Gerüchte.
Hersteller: http://www.changhong.com/
5000毫安电池!大屏超长待机神器长虹Z9或快面世 mtksj
5000 mA battery! Changhong big screen long standby artifact or fast launch Z9
Smartphone battery life issue has been the focus of most of the user, in order to pursue a longer standby time, many manufacturers have introduced products with a large capacity battery, such as the latest Lenovo P780, Philips W8510 and other models, and with the mainstream Quad-core platform. Battery field study years Changhong phone also introduced a lot of endurance flagship product, but undoubtedly the most anticipated news spread Changhong long long until the new quad-core machine - Changhong Z9, the machine has a large screen and large capacity batteries, the machine currently has access to network news, I believe that time is also fast.
From the exposure of the real machine spy can be found, Changhong Z9 design fashion, generous, though picture looks somewhat "appalling." Changhong Z9 overall style bias simple route, using a combination of straight + small fillet, borders are relatively narrow fuselage vaguely have brushed texture, a little more business sense of technology, the main camera area more chic design, the lens, flash and 8.0M words are concentrated into a box, the view from the figure did not seem to how the camera protruding from the body. In addition it is the thickness of the already spread, said that only 8.99 mm, long standby mobile phone comes in a leader.
Changhong Z9 will challenge the limits of the thinnest long standby mobile phone
The thickness of the previously mentioned Changhong Z9 less than 9 mm, this figure 5.x mm thick smartphone have appeared this is not unusual, but in the main life of the product is extremely rare, because the aircraft is equipped with a 5000 milliamperes large capacity battery. From the comparison chart can be found, Changhong 5000 mA battery capacity than the bottom of the big vivo cell volume is only 10 points, one more than twice its capacity there, visible Changhong battery technology really is not covered.
In addition to its large battery 5000 mA, the rumored Z9 will be equipped with a 5.5 inches large screen, resolution up to 720P-level, built-in 1GB of memory to run. The machine also will use 28-nanometer low-power quad-core processor, known long standby mobile phone are used MTK MT6589 low-power quad-core processor, Changhong Z9 perhaps equally MTK6589 program. Also Z9 will support WCDMA network, running Android 4.2 version of the system.
Some time ago Changhong insiders have revealed that the the long-listed Changhong Z9 has continued to improve, while the network has been the case from the point of view, this phone is perhaps the final time to market in the near future, following the Z3 Feng Li and other products after I believe this will bring Changhong phone better "Standby artifact."
J
johndebur
Das Changhong Z9 wird mit dem MT6589T ausgestattet
5000毫安!长虹Z9将搭载1.5G四核处理器 mtksj
5000 mA ! Changhong Z9 will be equipped with 1.5G quad-core processor
HONPhone Changhong phone most of the appearance of the Z series of products compared side business style , this new machine Changhong Z9 no exception . Z9 whole design is very simple , straight combination with the small fillet in the current Android phone uncommon, but Z9 material and technology and other aspects in more features , the machine in the box very smooth handling , suspected metal material, and there brushed texture decoration , the whole back of the fuselage also has drawing lines , the surface is high light treatment, red , dark blue , such as different colors, the whole look more grades .
Changhong Z9 body size of 141.9 * 74.2 * 8.9mm, 8.9 mm thickness has been coming out in the current 5.x product can not be called slim, but we all know that Changhong Z9 will be equipped with 5000 mA high-capacity battery , less than 9 mm thick body to accommodate 5,000 mA battery is unique in the current , long -listed Lenovo P780 standard 4000 mA battery , up to 9.9 mm thickness , thus increasing the battery should be thin fuselage Changhong Z9 the biggest selling point , excellent thick enough to be amazing.
Details of the aircraft's fuselage relatively unique, such as the machine seems to place the SIM card slot in the fuselage on both sides , this may mean that Z9 uses a one piece design, but this remains to be verified whether the specific
5.5 inches large screen + MTK6589T Quad
And many of the long pending targeting smart phones is not the same , Changhong Z9 does not save the screen size , the machine is equipped with a 5.5 inches IPS screen with 1280 * 720 HD -level resolution, from the previous spy photos seem OGS also uses a full- fitting techniques . Another part of the processor before the transfer of 1.2GHz frequency MT6589 four main core, but the truth is that the machine is equipped with a 1.5GHz MT6589T, only stronger performance , built-in 1GB of memory and 16G storage space to run and support the expansion of 32G . Camera specifications slightly ordinary , front camera is 1.3 megapixel , equipment 8,000,000 pixels main camera , running Android 4.2 version of the operating system , Changhong Z9 also built other common electronic compass sensor, support wcdma + gsm dual sim dual standby .
Life is naturally aircraft entrees , Z9 battery capacity reaches 5000 mA , which in the domestic smart phone is a high -capacity , and although there is a 6000 mA battery manufacturers push smart phones, but the thickness difference is too obvious more . According to official data, Changhong Z9 continuous talk time up to 16 hours and standby time of about 800 hours , the actual use has yet to be verified.
The battery has accumulated experience of many of its advantages Changhong applied to the smart phone body , the launch of Changhong Z9 does give attention to endurance users by surprise , especially business people , so a lot of money estimated retail price of the phone , like the machine users may wish to note that this site subsequent messages .
J
johndebur
Das Handy ist nun erhältlich und soll 2499 yuans kosten ( 308€ )
5000毫安一体设计 长虹Z9正式开卖 mtksj
5000 mA one design Changhong officially started selling Z9
Wang Changhong phone power due to built-in 3200 mA Series Z3 last year to become a large battery long standby smart phone leader, six months later, Changhong amazing once again launched a long-pending new machine-HONPhone Changhong Z9, the aircraft was named as a driving force on the 1st, Z9 both the appearance or will be a long life than conventional products Changhong more prominent, and heralds a new generation of ultra-long standby series Changhong officially set sail.
After months of polishing, this endurance primarily to new product was recently officially unveiled, Z9 has been officially on sale in the official mall, people are concerned about the price bottom, Changhong Z9 retail price of 2499 yuan.
J
johndebur
review vom honphone Z9
5.5寸长待商务机 HONPhone动力王 Z9评测 mtksj
Übersetzung
5.5-inch-long king to be powered business aircraft HONPhone Z9 Review
HONPhone Power King Z9 parameters
CPU MediaTek MT6589T quad-core 1.5GHz
RAM 1GB
ROM​
16GB, does not support the expansion card
Screen​
5.5 inches 1280x720 resolution IPS OGS full fit
Webcam
8,000,000 pixels F2.2 rear (5 set of lenses) +130 megapixel front camera + Wide Single fill light
Operating system Android 4.2.2
Dimensions​
141.9 × 74.2 × 8.99mm
Battery​
5000mAh (not removable)
Network WCDMA + GSM dual sim dual standby
Type of SIM card Standard SIM card
Reference Price 2499 yuan
X. Evaluation Summary
Through evaluation we can know, in addition to have a powerful endurance capabilities, HONPhone power king Z9 phone manufacturing process, screen performance, shooting and hardware performance have achieved good results, is a performance of a balanced business model. As a breakthrough battery technology and mass production of products used in mobile phones is yet to come, the market equipped with high-capacity battery cell phone or demand, and hope that more manufacturers have introduced similar models to meet consumer requirements.
