NO.1 N3 5.7 inches large screen thousand Yuan NEW NO.1 N3 appearance
phone, no.1 n3
  • antwoormoglichkeit
    Abstimmungen: 0 0.0%
    Abstimmungen: 2 100.0%
    2
Lambertane
Evaluation Passion for October was past.The major manufacturers have also released at the beginning of this year's flagship products, such as the Samsung GALAXY Note 3, LG 's G2 as well as domestic brands Meizu MX3 and xiaomi 3, NO.1 phone N3 etc. , Today give you a surprise, since that is a surprise then what is it ? Not long ago , the major media have reported the NO.1 phone N3, claims to have the same appearance and note 3 Today, I gave you a look at the N3 in the flesh !
Do not doubt your eyes, you're not mistaken , this is the N3, never be overestimated ! N3 change in appearance is very obvious from the previous S6 cobblestone design concept into a tough exterior , the appearance looks more noble, more refined in detail to some of the front panel as well as fine ornamentation narrow frame design, the appearance of N3 lot of extra points , let the phone has been somewhat tough, the beauty of science and technology .
N3 with a 5.7 inches of OGS full fitting screens, their sophistication is good, the naked eye has been difficult to feel grainy. Smooth touch screen phone , the operation is also very sensitive , and more wear-resistant , so usually when we need not foil, then it will not affect the touch screen , it will not affect the display.
Position in front of the phone handset spotted a dust network protection , earpiece sound is relatively large , the basic call is no problem , next to the two black specks handset is light , proximity sensor , the far right is front camera , camera megapixels , and before hundreds 2000000 or 3000000 contrast , better reflect self- powerful artifact .
Phone bottom of the screen is N3 iconic home key , key feedback obviously , feel good. In the Home key on both sides were now hidden menu key return key , two keys do not use words you do not see , after pressing the backlight will be lit, accompanied by a shock effect , tactility is also quite sensitive .
N3 body thickness of 8.3mm, the thickness of this in the current smart phone is all middle level, but because the phone 's screen , with the massive back of the phone there is a location close to the edge of the arc, so that will make people feel able to visually very slim
Headphone jack on the top edge of the phone is the noise-canceling microphone , in addition to a large black spot is the phone's infrared transmitter inside the phone comes with an application that can be turned into a remote control N3 .
Bottom of the phone design is very special, the most notable is the data line interface, and our common Micro USB interface is different , N3 using this interface is USB3.0 interface, if your computer supports USB 3.0, then you can enjoy fast transmission speed , under normal circumstances USB 3.0 transfer speed can reach 100M / S. This interface is also compatible with conventional Micro USB data cable, but that is not so fast transfer speeds of up to it , the other is no difference . At the bottom of the speaker using a relatively tough design style , metallic dust network protection , sound is relatively large, relatively clear in the subway can hear ringtones .
Here we are talking about one of the priorities of the N3 , N3 is a new design that is handwritten pen, pen still retains a key for use with the phone's touch features , which we will explain in detail later .
Rounded tip of the stylus will not scratch the phone screen . Tip away a certain flexibility, so to give you a better user experience writing touch . Insert the stylus into the pen tray when the front is more smooth, there will be some resistance in the last paragraph , and there is a small buckle stuck stylus touch pen to prevent loss.
N3 back a fierce look that is the cortex , in fact, is a plastic material , but with a leather decoration , feel way better than the traditional glossy plastic better, but from real leather are still some gaps . N3 is the white version , which is our evaluation of this is that the plastic backshell .
Back of the phone has a 13 million pixel camera, equipped with LED lights , While this camera slightly convex cover of the phone , although it looks not very obvious, but if the flat on the table , the camera is sure to touch the desktop , we should be careful to use protection against scratches around the camera affect the appearance .
N3 with a removable rear shell design, mobile phone standard battery capacity of 2,800 mAh , the battery capacity is relatively large , but because the screen size is also great, so the overall endurance capacity and not too prominent, normal use of the words used to ensure the day time , but basically in the evening are the need to recharge . We can prepare spare batteries or power to help select a mobile phone has a more lasting usage time. Phone dual small card design, benefits of this design is to save the phone's design space .
NO.1 of previous generation products S6 , N3 and S6 in appearance there is a clear distinction, however, two aspects of the design details phone also has a lot of similarities, let's look at the appearance of N3 and S6 contrast.
NO.1 S6 and NO.1 N3
N3 much larger on the screen , like the big-screen users will be more favored N3, can be seen from the comparison , S6 border narrower than N3 .
Summary: For this evaluation N3 appearance , I believe we have a comprehensive understanding of the machine . N3 hardware configuration is quite high , so excellent appearance, coupled with decent hardware setup, I believe that loving big -screen phone a friend , N3 is everyone's first choice !
guesa
The look alone is not important.
If GPS, WiFi, 2G/3G, battery is as bad as in the S6, I would not have such a phone.
ich würde es aber als SPAM ansehen
Das ist ein Beißreflex. Selbst wenn es ein Eigeninteresse gibt, das hier zu veröffentlichen: Fast JEDER Forumsteilnehmer hat immer ein Eigeninteresse an den eigenen Posts, und sei es nur, Klickzahlen oder Zustimmungen zu erhöhen oder eigene Lieblings-Phones zu promoten.
Ich jedenfalls bin immer dankbar für Produktvorstellungen. Sonst bräuchte ich dieses Forum nicht. Deshalb finde ich es doof, hier so rumzunörgeln. Das hier ist ein Review von Lambertane (egal ob durch die Marketingbrille oder nicht) aber keine versteckte Werbung für einen Shop.
Also: Thank you Lambertane
Bei uns gehen halt die Alarmglocken an, wenn User über anonyme Proxies oder über IPs, die eindeutig in Spamdatenbänken gelistet sind, posten. Darum die Skepsis ;)
oskaliope
