Iocean X7S - MT6592 5" FHD 2GB Ram 16Gb Rom OTG dual sim 5/ 13MP Cams
J
johndebur
das X7 bekommt nun auch den MT6592. Der Vorverkauf startet heute und geht bis 21.1. , der offizielle Verkauf startet dann am 21.1. . Der Preis: 1399 yuans (170€)
Anscheinend gibt es das Handy mit 2000mah oder 3000mah AKku
http://www.iocean.cc/X7S.html
欧盛X7S精英版八核发布 1399元预约开启 mtksj
Ou Sheng X7S elite eight-core version release 1399 yuan reservations open
Just today ( the 13th ) afternoon, Ou Sheng phone officially announcedOu Sheng phone recently held a low-key launch of new aircraft under "3X8" line , for the release of what the product has not been officially announced , the relevant information from the point of view or a model for the G7 includes a new phone, but the new machine may Not only a . Just today ( the 13th ) afternoon, Ou Sheng Mobile officially announced the launch of the European Sheng X7S Elite , the aircraft will be equipped with MT6592 eight-core processor , eight -core X7 is an upgraded version of the original .
Has released publicity chart shows , Ou Sheng X7S and multiple X7 quad-core version does not look much different place, still a straight square style, no accident, then measurements should be the size of 141 * 69 * 8.95 mm , a front after the black and white color .
X7S Elite version will be upgraded to a 1.7GHz processor main frequency of the MT6592 eight-core processor, with 2GB of memory to run and 16GB of storage space , the screen size of 5 inches , using LTPS technology , resolution of 1920 * 1080 , for the full OGS laminating process . X7S there before 5 megapixel camera self-timer , stacked 13 million pixel camera with F2.2 aperture / blue glass filter / anti-fingerprint coating, support 5CM macro picture , the battery capacity of 2000 mA , with 3000 mAh battery accessories compatible. And X7HD , the aircraft can support WCDMA + GSM dual card dual standby , support WIFI-DISPLAY, OTG function, equipped with electronic compass, gyroscope and other sensors .
From Europe to Elite named Sheng X7S term, there will likely follow the flagship version , plus hear about the G7, there should be a variety of recent European Sheng eight -core machine unveiled. Currently X7S Elite was the 13th started to accept reservations , booking Until at 12:00 on the 21st of this month , the same day the official start of the first sale , the machine is priced at 1,399 yuan . Reservation Address : http://www.iocean.cc/X7S.html
J
johndebur
sind zwar "nur" 16gb ROM aber man kann ja nachrüsten
ja es gehen bis 32GB Speicherkarten, laut Parametern
Memory Card Micro-SD (T) card up to 32GB
Wo, wie, was genau bestelle ich daim Shop?
Wo:
Bis jetzt nur Vorbestellung , http://www.iocean.cc/book/view-67-2.html
auf der Englischen Seite habe ich es noch nicht gesehen:
http://www.iocean.cc/en.html
http://www.iocean.cc/Dealer.html
Wie:
naja mit login und passwort und Geld :p
Was:
Ein Handy :grin:
SaThaRiel
Bin bei einem Video zum ZP998 von Zap hierauf gestossen (war ein Kommentar):
http://www.youtube.com/user/mediateklab/videos
Scheint so, als ob hier einiges passiert wäre. Ggf. kann man ja einen 3000mAh Akku nachkaufen? Das ZP980+ (meine Zwickmühle) hat auch nur nen 2000mAh Akku, lediglich das THL T100S (alle ungefähr gleich) hat einen 2300mAh Akku, ist mir persönlich aber zu klobig ;)
highwind
Man bekommt die Iocean Geräte inzwischen auch zu halbwegs fairen Preisen von der italienischen Niederlassung des Herstellers
http://www.iocean.it/
Mit dem Code "giziocean" bekommt man weitere 5% Rabatt auf jeden Artikel
Da die Abmessungen laut cect-shop identisch sind, sollte doch eigentlich das für die anderen X7 verfügbare Kit aus 3000mAh und Rückschalen-Cover auch in das X7S passen?
http://www.aliexpress.com/store/product/3000mAh-Battery-and-Back-Cover-for-iocean-X7/103919_1101427545.html
Ist das schon irgendwo bestätigt?
"Bestätigt" kann ich dir nicht sagen, aber ich bin um ehrlich zu sein auch davon ausgegagen, denn das Gehäuse ist identisch
SaThaRiel
Das X7S ist mit 278€ aber ziemlich "teuer" (vergleichsweise)....ich denke, bei CECT kommt man günstiger weg.
Und zudem:
Disponibilità:QUESTO PRODOTTO NON È PIÙ DISPONIBILE
Leider schon ausverkauft. So ein Mist :(
highwind
Ahjo, mit dem Code sind es 265€ und weil Versand aus Italien kommt da auch keine extra Steuer drauf... Bei CECT käme die eben noch drauf und damit kostet es da dann circa 250€
Ich finde 15€ Unterschied sind noch im Rahmen dafür, dass man im Fall der Fälle "europäisches Recht" und den deutlich einfacheren Garantieablauf hätte - Im Endeffekt muss das natürlich jeder selber entscheiden und ich persönlich würde wohl auch aus China bestellen.
Es sollte nur als Alternative genannt sein, für die Leute die dem Eigenimport aus China kritisch gegenüber stehen ;)
closebor
