Mediatek MT6752 / MT6732 - 64-bit LTE SOCs von Mediatek
J
johndebur
Wird wohl noch einige Zeit dauern, bis die chips kommen :p
联发科64位八核LTE处理器MT6752/32或用A53架构 mtksj
MediaTek 64 MT6752/32 or eight-core LTE processor architecture with A53
Not only is 4G LTE, 64-bit computing in MediaTek have already begun to prepare , in October last year MediaTek formally ARM Cortex-A50 Series authorization to launch 64 mobile processor foreshadowed. After supporting TD / FDD-LTE and a variety of 3G networks LTE SOC MT6595 release , MediaTek another bit heavy weapons -64 SOC is also part of the information published insider out , it is learned MediaTek next launch 64 LTE phone system single chip or code MT6752/MT6732.
MTK previous products from naming to speculate , MT6752 should be is the legendary 64 8 -core LTE chip code , and MT6732 perhaps four core design . Although no two 64-bit chips Xiangxi specifications announced, but sources said , MT6752/32 will use ARM Cortex-A53 architecture !
A53 and A57 belong to the ARM Cortex-A50 series , popular speaking , A57 performance is more robust , and A53 will have a lower power consumption while taking into account performance, both of which support ARM AArch64 64 -bit instruction set , the difference is addressing and caches , promoting energy efficiency MediaTek 64 CPU using Cortex-A53 is not an accident, but in what specific process , frequency and other specifications needed time to verify .
Qualcomm recently announced a 4G terminal -oriented thousand Yuan Xiaolong 410 MSM8916, this LTE SOC A53 uses the same architecture , another rumor that Qualcomm is contrary to the original intention of the secrets to build 64 eight -core LTE SOC MSM8X36, apparently MT6732 and MT6752 just become engaged the 8916/8X36 powerful weapon , perhaps this year you can see the MTK 64 -bit chip release.
J
johndebur
neues zu den 64 bit CPUs von Mediatek.
联发科64位处理器详情曝光:有惊喜 mydrivers
MediaTek 64 processor details Exposure: surprise
Previously, we worked all exposed two 64-bit processor from MediaTek MT6752 and MT6732, their positioning and Qualcomm Xiaolong 410 previously published similar , the main low-end models.
About MT6752 and MT6732 processor architecture of these two now have a more clear view , these two processors are used in standard Cortex-A53 architecture is based on 64 AMRv8 standard 64-bit ARM instruction set processors . MT6752 which should be eight-core design, and MT6732 is the quad-core design . Both integrated baseband chip support WCDMA, TD-SCDMA, GSM, LTE-TDD and LTE-FDD.
About its performance we do not hold out much hope, though 64-bit architecture , but analysts say the current point of view , the performance Cortex-A53 architecture is actually under the same frequency and Cortex-A9r4 almost, really tough, because originally the main A53 taking into account the performance of low-power architecture , and the current A7 does have certain similarities.
MediaTek to style point of view, these two processors will inevitably after the launch price is very cheap, face Xiaolong 410 series may be some advantages to become the main force entry age of 64 .
J
johndebur
Auf der MWC werden die LTE chips vorgestellt. u.A wird es auch den MT6589 und MT6590 als LTE Version geben.
联发科2014 MWC大会将发布64位LTE SOC mtksj
MediaTek 2014 MWC Conference will release 64 LTE SOC
Opening MWC Assembly soon, there MediaTek heavy material appears , Taiwan joint news latest news shows , MediaTek will be exhibiting at this year's Mobile World Congress (2014 MWC), in addition to the published MT6595 eight-core LTE SOC may be in the current MWC Conference debut outside , MTK will be released at the conference 's first 64-bit support for LTE networks smartphone system-on- chip (SOC), MediaTek declared officially enter 64 markets, positive against Qualcomm .
This time, though not publicly release the processor specific model , but the news that is for the " low-end market " products , but also through MediaTek latest product roadmap shows that this MWC Assembly released 64 LTE SOC that is previously there MT6532 small amount of messages. MT6732 will use 4 -core design, not only support 64-bit computing , while supporting TD / FDD-LTE 4G network , backward compatible with 3G/2G, apparently MediaTek low-end market is another masterpiece . MT6732 will use a higher EER ARM Cortex-A53 architecture , lower power play with better performance is a feature of MTK products have been integrated 4 A53 cores, speeds up to 1.5GHz, supporting 13 million pixel camera , 1080P video playback .
In addition to MT6732, otherwise the built-in 8 A53 core MT6752, MT6732 higher than the latter specification , is currently the highest MediaTek 's model of a product, and the MT6595 will be positioned as high-end market . MT6752 main frequency of 1.7GHz, supports 16 million pixel camera , 1080P screen / video codec , etc., also supports multiple network modes , including LTE .
After MT6752 release, will be listed in mass production in the third quarter of this year , the time to market with LTE end eight-core MT6595 time should be close , but high-end positioning of the MT6752 will be listed in this year's Q4. Prior to this , MediaTek will launch the integration of MT6589 MT6290 LTE MODEM eight-core version , allowing customers to quickly enter the 4G era , the fastest production listed in the following quarter.
With the rapid rise of the 3G era , MediaTek pace faster and faster , tight old rival Qualcomm, which recently launched a low-end 64 410 Xiaolong chip , want to dig through the low-cost MediaTek partners purpose is self-evident , the MediaTek faster time to market schedule , is a powerful counterattack against Qualcomm , 4G , and I believe in the 64-bit processor , MediaTek will still bring an unexpected surprise !
Squizzy
naja. nur so lassen sich in naher zukunft die 8gb ram im handy realisieren :grin: damit man dann auch ordentlich aufm handy seine 3D Animationsfilme rendern kann ^^
charly60
Möchte da meinen beiden Vorrednerm zustimmen, irgendwas neues müssen sich die Hersteller wie Samsung, Apple, HTC usw. ja einfallen lassen um den Kunden das Geld aus der Tasche zu ziehen und da müssen die chinesichen Hersteller auch nachziehen. Ist ja bei PC, TV oder Digicam auch nicht anders.
Wobei 90 % der Smatphonenutzer ein Gerät mit 4 - 5 Zoll Display, max Quadcore-CPU, 1gb RAM/8 gb ROM und QHD- bzw HD-Auflösung reicht, behaupte ich mal.
Und wenn ich in zwei jahren nicht ein Samtphone mit UHD-Auflösung habe bekomme ich nen "Aussteiger"! :hehehe:
tommy0815
bei QHD Auflösung kommen wir jetzt zu einem Konflikt.....bei den Chinesen ist qhd 960x540
bei den Europäern bedeutet qhd q=quad =4 faches HD (2.560 x 1.440)
thor2001
Darum ja auch QHD und qHD...hätten sie aber besser regeln können.
64bit hin oder her, bin schon froh, dass der MT6595 mittlerweile mehrere GPS-Systeme nutzen kann und ebenfalls LTE.
Das ist meiner Meinung nach wichtiger als die 64bit.
tommy0815
ja ihr seit gut das habe meine müden Augen gar nicht bemerkt :grin:
dachte es gibt jetzt 2x die gleiche Bezeichnung für 2 verschiedene Auflösungen :)
und zu den 64bit.
Also ich brauch das. Generell braucht der Mensch immer größere Zahlen, dann fühlt man sich besser :grin:
ich habe auch lieber 64 Euro in der Tasche als nur 32 :p
J
johndebur
Wurde nun offiziell von Mediatek vorgestellt.
http://mediatek.com/en/mwc2014/mediatek-launches-mt6732-a-64-bit-lte-soc-to-spur-the-new-super-mid-market/
Premium technology at a mainstream price point will fuel the next global wave of smart devices
TAIWAN, Hsinchu – 23 February, 2014 – MediaTek today announces the 64-bit LTE SOC MT6732 at the Mobile World Congress in Barcelona, Spain. The MT6732 delivers a next-generation computing system consisting of a coherent 64-bit ARM Cortex-A53 cluster and Mali-T760 GPU – providing next-level 64-bit mobile computing and LTE for the rising Super-mid Market, consisting of billions of consumers ready to adopt smart devices with premium features at mainstream prices – many for the very first time. The MT6732 platform delivers:
Next-Generation 64-bit Mobile Computing System
  • Quad-core, 1.5GHz ARM Cortex-A53 processor system, delivering the performance boost and 64-bit CPUs that will become mainstream in mobile devices
  • Next-generation Mali-T760 GPU with support for the Open GL ES 3.0 and Open CL 1.2 APIs and premium graphics for gaming and UI effects
Advanced Multimedia Features
  • Supports low-power, 1080p, 30fps video playback supporting the emerging video codec standard H.265 and legacy H.264 and 1080p, 30fps H.264 video recording
  • Integrated 13MP camera image signal processor with support for unique features like PIP (Picture-in-Picture), VIV (Video in Video) and Video Face Beautifier
  • MediaTek ClearMotion™ technology eliminates motion jitter and ensures smooth video playback at 60fps on mobile devices
  • MediaTek MiraVision™ technology for DTV-grade picture quality
Integrated Multi-mode 4G LTE Modem
  • Rel. 9, Category 4 FDD and TDD LTE (150 Mb/s downlink, 50 Mb/s uplink)
  • 3GPP Rel. 8, DC-HSPA+ (42 Mb/s downlink, 11 Mb/s uplink), TD-SCDMA and EDGE are supported for legacy 2G/3G networks
  • Integrated Connectivity Solutions
  • Supports dual-band Wi-Fi to effortlessly connect to a wide array of wireless routers and enable new applications like video sharing over Miracast
  • Bluetooth 4.0, supporting low-power connection to fitness gadgets, wearables and other accessories such as Bluetooth headsets
The MT6732 platform will be commercially available by Q3 of 2014, with devices expected by the end of the year.
J
johndebur
Heute wurde nun auch der MT6752 offiziell vorgestellt.
http://mediatek.com/en/news-events/mediatek-news/64lte-mt6752/
Die Mediatek Seite will bei mir im Moment nicht laden, irgendein Webdesigner hat die verhunzt. :p
2GHz八核/64位/LTE 联发科MT6752正式发布 mtksj
Eight-core 2GHz / 64 / LTE MediaTek MT6752 officially released
LTE and 64 on the layout , MediaTek is rapidly moving forward , again ahead of time to market , first to the first eight-core LTE SOC-MT6595 debut at MWC meeting subsequently released its first 64 phone solution MT6732, today ( 25) once again posted heavyweight MediaTek products that support LTE network has eight core 64 -bit processor -MT6752, to further expand their product line into the high-end market .
Compared MT6732, MT6752 new release and other aspects of performance to the next level , MT6752 has eight Cortex-A53 application processor core speeds up to 2GHz, support for 64 -bit computing , the latest graphics processors built ARM MALI-T760, bring a more powerful gaming and multimedia performance.
Audio and video , MT6752 supports 1080P 30fps video playback and low power consumption 1080P video recording, video frequency technology with ClearMotion MiraVision technology and benefit from better multimedia experience ; supports 16 million pixel camera ; support FHD -level screen display.
MT672 also incorporates multi- mode multi-band LTE modem that supports Category 4 version , uplink and downlink transmission rate up 50M/150Mbit/s, compatible TD-LTE/FDD-LTE mainstream 4G standard, supports DC-HSPA + (42Mbits / s), TD-SCDMA, EDGE and GSM / GPRS.
MediaTek has always insisted on multi-core strategy , LTE and 64 era like this, while the People First price is also one of MediaTek's arms , MT6752 though specifications than the MT6732 higher for low-end market , but MediaTek are still stressed the "high cost" four words , the estimated price of the end product will still have close to the people . MT6752 Another advantage is perfectly compatible with the MT6732 pin , product upgrades and more efficient, it is learned MT6752 test to customers in the third quarter , completed before the end of production .
J
johndebur
Laut Mediatek läuft alles nach Plan und man kann die 64bit Prozessoren (MT6732 und MT6752) schon Q3 auf den Markt werfen, also vor Qualcomm etc.
高通哭了!联发科64位八核处理器提前上市 mydrivers
Qualcomm cry ! MediaTek 64 eight -core processors listed in advance
sinking 64 on iPhone 5S A7 processor architecture and is still one hot topic , because without it , Android camp, now a 64-bit product yet born , it can be said in this regard leading iPhone 5S Android camp in a year 's time .
According to the original plan for Android phone / tablet 64-bit ARM processor will officially debut later this year , specifically including MediaTek and Qualcomm MT6732/6752 Xiaolong 808 , etc., after they officially listed and will certainly set off a new wheel hardware war. However, the current situation, this war to advance .
Taiwan's technology industry news within the Times said the current aid MediaTek MT6732 and MT6752 64-bit processor progressed very smoothly , is expected in the third quarter of this year on the market, ahead of schedule for a whole quarter. This will beat other vendors a surprise, after all, according to the current schedule , the 64-bit processor Qualcomm earliest at the end of this year will be available early next year .
Another message also pointed out that from the beginning of the second half of this year , 64 eight-core processors will gradually gaining in popularity , slowly becoming mainstream and even in the end product standard .
J
johndebur
Schon ja , aber sind denn die grossen Labels nicht auch so ? Die brauchen ja auch Zeit bis mal ein Lollipop update kommt. Da wird ja auch erst nur ein Gerät geupdated, aber bis die anderen 64bit Geräte dran kommen steht auch in den Sternen. Zumindest ist es so bei Nubia OS von ZTE oder Vibe UI von Lenovo.
und bei meinem Gerät kommen eh schon keine updates mehr. Das war irgendwie schon bei Veröffentlichung tot , war wohl kein Verkaufsschlager. Naja :)
