Jiayu G6 - MT6592 5,7" FHD OTG NFC 8/13MP Cams dual sim 2GB Ram 32GB Rom
J
johndebur
Neues handy von Jiayu , das im April erhältlich ist. Mit 2GB ram kostet es 1799 yuans (209€) und mit 1GB 1499 yuans. (174€)
1399元/1499元起 佳域G6与S2正式发布 mtksj
1399 yuan / 1499 yuan good domain G6 and S2 officially released
Good domain G6
Big change in the appearance of good domain G6
G6 first appeared in last year's users conference, out of the prototype display showing good domain G6 with a three-stage design , more rounded corners , and now apparently released G6 new mold enabled. Statistics show that good domain G6 measurements for size only 156 * 79 * 8 mm , boasts a large proportion of the Samsung NOTE3 screen size is 151.2 * 79.1 * 8.3mm, while Cool 9080W reached 155.8 * 81.5 * 8.3mm, although the ratio of plastic shell NOTE3 slightly longer , but at the same size products can be regarded as a very exquisite body of a class .
Has released renderings show the upper and lower ends of the aircraft are circular surface , so the box is very flat , similar to the style and MEMO II, the machine uses a lot of aluminum alloy . Another big selling point is the back of the good domain G6 also will be equipped with Corning Gorilla Glass , more beautiful body while improving protection .
Removing integration stylish appearance , the machine 's core configuration also deserve special attention , good domain G6 will be equipped with 1.7GHz main frequency MT6592 eight -core processor , the screen is 5.7 inches , with a full- fit technology and OGS 2nd generation Gorilla glass , resolution of 1920 * 1080 , camera, Sony module using pre- 8000000 , rear 13 million pixel Panasonic camera, running Android 4.2 system . Function more complete , G6 supports OTG, NFC, wireless charging and dual noise reduction technology wheat , support gyroscope , HALL sensor switches and other mainstream and support WCDMA + GSM dual sim dual standby and dual speaker design provides better sound output.
Good domain G6 and S2 are provided with double height version , high version is a combination of 2G RAM +32 G ROM , which is low with 1G RAM +16 G ROM memory , with other versions of the same specification level . With good domain version of the S2 level prices are 1,399 yuan / 1699 yuan , good domain G6 double version is priced at 1,499 yuan / 1799 yuan , S2 will be listed within this month , while the G6 will need to wait until April .
leecher88
hier enttäuscht mich Jiayu sehr !!!! kaum ist das G5 draußen schon schmeißen sie ein neues nach ??? und noch dazu gleich so einen riesen Sprung von 4.5 inch auf 5.7 ???
Hier hat Jiayu definitiv in meinen Augen einen Fehler gemacht !
Designmäßig finde ichs gut vor allem weil sie wieder was neues bringen im Vergleich zu ihren eigenen Modellen !!
Aber 5.7 muss wirklich nicht sein :(((
NotChinaMobiles
Das G6 wurde bereits im Sommer 2013 angekündigt. Da stand ebenfalls dabei das das G6 ein großes Smartphone wird. Leider stand aber nicht mit dabei das die Octacore version des G5 so unnötig ewig auf sich warten lässt........
Daemonarch
Chiclone-Lover
Wer zwingt dich denn bitte, das große Modell zu kaufen? Dafür bieten sie doch kleinere in allen Größen, Formen, Farben und Austtattungen an...
Das die Leute sich sogar noch über ein großes Angebot beschweren müssen! :no2:
J
johndebur
Fotos vom G6
双面玻璃+铝合金机身 佳域G6真机照放出 mtksj
Double-sided glass + aluminum body good domain G6 real machine photos released
A week before , good domain far the heaviest weight of its two products - good domain G6 and S2 officially released , there is no line under the high-profile conference, the only announced two new low-profile official forums relevant information to complete the entire publishing process . On the product itself , these two products have their own characteristics , S2 emphasizes maneuverability , excellent dimensional control , G6 owns huge screen , and the application of a variety of advanced technology , more beautiful design, function fully .
Now good domain G6 real machine photos have been released , more information show out . Good domain G6 uses unibody design, the internal frame is made of aluminum alloy and the border , back and front , like Corning Gorilla Glass has . Because it is a unibody , G6 does not support battery replacement and storage expansion , but can support WCDMA + GSM dual sim dual standby , card slot and the power button and volume keys , USB interface with the right. The reason for this is mainly because the upper and lower ends of the arc-shaped aircraft , combined with the shape of a radius really brings a different visual experience , so that the whole is richer sense of design .
Although good domain G6 is equipped with a 5.7 inches 1080P resolution Full fit the big screen, but the size is a relatively small category, measurements are 156 * 79 * 8mm, in addition to a variety of color options for users, pioneered the black version , slightly after the white gold version with the Tyrant .
The aircraft will be on sale in the market in April , 2G RAM +32 GROM high version with 1G +16 G low version priced at 1499 yuan and 1799 yuan , have a 1.7GHz eight-core processor clocked MT6592 , 8000000 /1300 dual -megapixel camera and 3500 mA batteries, gyroscope , electronic compass sensor rich and NFC, OTG, wireless charging and other features.
1-14032500111SD.jpg 1-140325001150c3.jpg 1-140325001202S8.jpg 1-1403250011404S.jpg 1-140325001131429.jpg
SIM-Sohn
Damals sollte auch ein 5000er Akku verbaut werden. War ein sehr gutes Kaufargument. Obwohl mir die Ausstattung und Optik bei dem jetzt auch sehr gefallen.
Daemonarch
Chiclone-Lover
Ach du nee, was hätte denn das mit so einem Akku für ein Klotz werden sollen? Das wär ja 20mm dick geworden.
SIM-Sohn
Die Angabe war schon sehr verwunderlich. 3500 sind auch schon recht viel. Sicher auch ein Grund warum es so nie erschienen ist. Bleibt nur zu hoffen, daß es auch dieses mal nicht nur Theorie bleibt.
J
johndebur
Das Jiayu G6 hat nun eine Netzwerklizens bekommen, sollte bald zu haben sein.
已获入网许可证 佳域G6上市在即 mtksj
Network license has been good domain G6 market soon
With the launch of the eight -core G4 , S2 two products , excellent phone and finally into the eight domains of the nuclear age , the former as low as 699 yuan price is very close to the people , the latter brings more performance and better technology . There is also an eight -core machine also paid close attention to users , the machine is good domain G6, it can be called a good domain present in all aspects of its strongest model, design, configuration and functions have spectacle.
Good domain G6 formally at the end of March a network license , only one step away from the market , time to market when be published in this month.
G6 uses a one piece aluminum body , the whole no protruding parts , including the camera , 156 * 79 * 8mm measurements , both the front and back of Corning Gorilla Glass II , in addition to the standard black color , white color, there Tyrant gold version , not only limited to the sides of the frame golden part , white is still the main color .
Remove able to attract the attention of the design , G6 also has a 5.7 inches screen 1080P Full fit , 1.7GHz eight-core processor clocked MT6592 , +1300 800 million camera and 3500 mA battery , configuration, running Android 4.2 system . Support NFC, OTG and gyroscopes , HALL sensor switches, etc. , in addition to wireless charging function first appeared in a body good domain products , expand relatively strong .
Aircraft 1G RAM +16 G ROM standard version sold 1,499 yuan , has 2G RAM +32 G ROM high version , sold 1,799 yuan .
Na ja, mir ist es fast noch ein Tick zu klein.
Habe mal ein wenig mit einem Ali ge-chated. Meinte, wenn ich es order, hätte ich es in der ersten Mai Woche. Nur habe ich vergessen, zu fragen welches Jahr. Zwei Hersteller haben mich noch nie enttäuscht: UMI und Jiayu. Mir gefällt die Form und sonst ist alles drin, was das Herz begeht.
Battery Capacity(mAh): 3500mAh
2GB RAM 32GB ROM, Don't support external memory
J
johndebur
Das G6 wird am 1. Mai verkauft, als 2GB Ram Variante, wie hoch die Stückzahl ist steht allerdings nicht fest.
Wann es das Handy mit 1GB Ram gibt ist auch noch offen.
可无线充电 5.7英寸八核佳域G6高配版首发 mtksj
To eight-core wireless charging 5.7 inches high with a good domain G6 starter edition
In mid- March , the highest so far good domain handset specifications good domain G6 officially released , this product sets the big screen , eight-core , full function equal to one, once released it attracted numerous onlookers , a good domain Yutong current high-end products .
In May Offer Plan recently disclosed , G6 is not on the list , but the latest news shows really good domain G6 arrangements on sale starting in the period May , apparently to leave a surprise to everyone .
Offer good domain G6 is high with the first edition , with 2G RAM +32 G ROM combination of high-capacity memory , priced at 1,799 yuan , currently only available in black version , the official release date is at 11:00 on May 1 , an unknown quantity, overwhelmed users get to buy a piece of wooden headphones , foil piece.
G Series product prices almost thousand floating near the blockbuster debut of 1799 yuan G6 gives "high " confidence is still there. The machine uses one metal structure design , internal frame, border , etc. are metallic materials , in addition to the screen , the back is also covered with a two -generation Gorilla Glass, and the thickness of 156 * 79 * 8 mm screen size than the vast majority of products with the Body more petite , is to show the process together with the S2 product .
In addition there is high version called G6 luxurious configuration , with eight-core 1.7G frequency MT6592 / 5.7 inches 1080P LTPS fit the whole screen / 2G +32 G memory and Sony 8000000 +1300 megapixel Panasonic dual camera, 8 mm thickness to accommodate 3500 mA large battery , and a customized Android system . Additional functions include wireless charging , NFC, OTG function, support WCMDA + GSM dual sim dual standby and gesture sensing , HALL switches, gyroscopes and electronic compass sensor.
There is also a good domain G6 Standard Edition, only slightly different memory specifications , using a combination of 1G RAM +16 G ROM , possibly late to market.
J
johndebur
Fotos vom Handy
双面玻璃+金属中框一体设计 佳域G6黑色版图赏 mtksj
Double-sided glass + metal frame integral design layout reward good domain G6 Black
Good domain phones until now the highest specification products good domain G6 official debut in May during the sale, regardless of technology or will this phone configuration and functions than the previous G series products strong one, is the product of good quality domain strategy one, prices have gone up, the price is high version 1799 yuan.
1-1405060HK7.jpg 1-1405060HP2.jpg 1-1405060HP5.jpg 1-1405060HQ0.jpg 1-1405060HQ3.jpg 1-1405060HQ6.jpg 1-1405060HQ9.jpg 1-1405060HR3.jpg 1-1405060HR6.jpg 1-1405060HR9.jpg
truce
JiaYu G6 Launch auf Juni verzögert :negative:
http://www.chinamobilemag.de/jiayu-g6-launch-auf-juni-verzoegert.html
http://www.gizchina.com/2014/05/06/jiayu-g6-hd-photos-launch-date-delayed-till-june/
Es sieht so aus als ob das JiaYu G6, welches bis vor kurzem noch als "erster Batch" erhältlich war für eine Weile vom Markt ist. JiaYu hat heute bekannt gegeben, dass das JiaYu G6 nicht vor Juni in den Verkauf geht.
Das JiaYu G6 ist der größte Konkurrent für das iOcean X8. Der Grund dafür sind die ähnliche Spezifikationen, wie der Aluminium / Gorilla Glass Body, ein 5.7" FHD screen, der MT6592 Octa Core SoC, 2GB RAM, 32GB interner Speicher, die 13 / 8 Megapixel Kameras und ein 3.500mAh größer Akku. Warum genau sich der richtige Launch verzögert ist noch unklar. Eventuell gab es noch Probleme mit der Hardware oder JiaYu entwickelt noch ein Update auf Android 4.4 KitKat und will den nächsten Batch dann damit ausliefern.
truce
Soooo die ersten Aliexpress Händler melden, daß sie die neuen Jiayu Geräte jetzt vorrätig haben.
(Vorerst aber wohl nur das schwarze G6 mit 32GB Speicher)
Meins wird nach langem Warten auch demnächst los geschickt.
Ich bin gespannt :grin:
truce
Habe es damals vorbestellt zu ca. 242 € inkl. Express Versand
(eigentlich Fed EX aber versendet jetzt wohl mit DHL Express)
+ ? € Einfuhrumsatzsteuer..
also round about 290 €
EDIT:
Tracking funktioniert schonmal :ok:
  • Like
Wertungen: Ora
truce
ahhhhh wie geil is das Teil bitte...:Mauridia::Mauridia::Mauridia:
huch nicht zuviel Euphorie - tschldigung..
Bilder und so folgen heute Abend, wenn ich alles fertig eingerichtet habe :dance3:
achja: 242,71 € + 35,17 € = Gesamtkosten: 277,88 €
