J
johndebur
Heute hat Iuni ein neues Handy vorgestellt, das mit dem eigenen IUNI OS ausgestattet ist, an dem schon länger herumgetüftelt wird. Kostenpunkt für die 3GB Ram Variante: 1999 yuans (232€) und 1799 yuans für 2GB Ram (209€)
Also das grün gefällt mir
IUNI U2 正式发布:Snapdragon 800、400 万像素 UltraPixel 前置相机、全金属机身 engadget
Fotos vom Event: http://cn.engadget.com/photos/iuni-u2-launch-in-beijing-0/
http://www.iunios.com/iunios.shtml
IUNI U2 released : Snapdragon 800,400 UltraPixel megapixel front camera , all-metal body
Early was broke " passport " of the Ministry of IUNI U2 finally opened a mysterious veil. This is known as using the " hardest metal one body ( aluminum ) ," "single phone Emperor " has " the back of the phone for the first time on the metal surface to achieve double- Design" , the official view that such an approach could " break the people's metal machine straight straight down the stereotype . " In addition, another major selling point of this product is the 4.0 megapixel camera plus front and rear combination of 16 million pixels, because the main camera module huge volume , IUNI ultimately chose Lumia 925 as similar to " crater -type convex design ." The front side of the lens , actually using the same UltraPixel and HTC One technique ( in fact, the appearance is also quite like is not it? ) .
It is worth mentioning that the official gives IUNI U2 yield rate is only 48% , which can not help but have a trace of fear in its production capacity ( of course, that can sell well ) . As for other specifications , IUNI U2 uses a 2.2GHz Snapdragon 800 processor , 4.7 -inch screen and a 2,200 mAh battery 1080p , supports up to HSPA + network systems is the main application of "zero pre-installed " in IUNI OS. Body black, white , and green color options , 2GB RAM plus 16GB built-in storage capacity version is priced at RMB 1,799 yuan ; 3GB RAM plus 32GB of storage capacity will have a combination of consideration of RMB 1,999 yuan. Booking has opened the official website , and interested friends can take a look.
