Changhong Honphone Z9H - MT6592 5,5" HD 5000mah TD + WCDMA dual sim 13MP Cam OTG
J
johndebur
Das Honphone Z9 wird nun auch mit dem MT6592 ausgesrüstet und bekommt einen 5000mah AKku
双3G/5000毫安电池 长虹Z9H至尊版上市 mtksj
Dual 3G/5000 mAh battery listed Changhong Z9H Extreme Edition
Wang listed power last September No. 1 Z9/Z9S really made a handful of rainbow scenery , Z9/Z9S not only has a large battery 5000 mA , body measurements also control well, about the thickness of only 9 mm , the whole configuration is also Changhong at that time many models of the few high specification products listed in the G01 on the soon after , Changhong will upgrade this classic product to the eight-core platform , the new version of the internal model Changhong Z9H, also known as the Z9 Extreme Edition .
There are several upgrades Changhong Z9H most noteworthy , first by MT6589T replacement became the main frequency 1.5GHz eight-core 1.7GHz MT6592 processor , higher performance ; secondly Z9 Unicom had only supports WCDMA 3G network , Z9H after upgrades supports TD-SCDMA + WCDMA dual 3G network compatible mobile / Unicom 2G. Besides the core of life is still selling the aircraft , in addition to its built-in 5000 mA battery , the Changhong Z9H also supports battery pack, enhance endurance.
Others, such as the appearance , such as the line to the Z9 , has achieved a 5.5 -inch HD screen , 13 million pixel camera and custom systems can support OTG function , gravity , distance and other common light sensor and comprehensive.
Changhong Z9H Extreme Edition has taken the lead in Changhong phone store shelves , consistent prices quoted market price and the original Z9 , sold 2,499 yuan , the current start , then there OTG cable, holster and a capacity of up to 10,000 mA original battery Mini carapace .
J
johndebur
Die sind ja bekannt dafür Handys mit starkem Akku zu bauen. Und anscheinend gibt es auch nocht einen 10000mah externen Akku mit dazu , wenn ich das richtig verstehe. Habe es aber auf deren Seite noch nicht gefunden, die ist echt konfus.
tommy0815
gibt es denn da irgendwo schon ein Datum, wann das Ding rauskommen soll? Weil ich bin ehrlich gesagt schon ein wenig genervt jeden Tag laden zu müssen!
tommy0815
ja ich hab es auch grade geshen, wollte das aber nicht wieder schreiben, weil sich dann der Thread auch wieder nur Vor- und nachteile von internen bzw. externen Akkus dreht :grin:
aber das ist echt immer so....irgendwas hab ich immer an den Dingern auszusetzen :grin:
Wobei wenn der Akku wirklich 5000mah haben sollte, dann müßte er auch mal 3 Tage halten!
DANN könnte ich mich auch mal mit anfreunden und wenn der Akku dann in Eimer geht schick ichs Dir zum Reparieren.....weil du dann schuld bist :grin:
closebor
