Lenovo K920 (VIBE Z2 Pro) - Snapdragon 801 6" QHD (2560 × 1440) 4000mah NFC 7,7mm dick 16MP Cams
J
johndebur
neues Phablet von Lenovo mit QHD display und dual sim
联想超猛新旗舰:6寸2K屏、7.7mm全金属机身 mydrivers
Lenovo whopping new flagship: 2K 6 inch screen, 7.7mm full metal body
After vivo, OPPO, LG, more and more manufacturers began planning to launch 2K screen phone. Tonight, there are a flagship Lenovo 2K screen was exposed out.
Media people @ Wang Shenyang tonight at Joe microblogging bursts of three pictures, which we can see Lenovo's all-metal flagship phone VIBE Z2 Pro.
Exposed configuration table shows, Z2 Pro has a slim 7.7mm full metal body, using 6-inch 2560 × 1440 screen, equipped with 2.5GHz Snapdragon processor 801 provides a 16:9 16 million pixels, OIS Optical Image Stabilizer camera.
The aircraft will be built 4000mAh battery, support for NFC functionality. You can see from the real machine spy photos, it also supports dual card dual standby function.
s_18f67753461541aea00221c6d26db63b.jpg s_c8a45d7a5a2c4372a009af3438a01838.jpg s_eadf4ff3bebe414491a8c4406ff54c12.jpg
J
johndebur
Noch ein paar Fotos.
联想全金属旗舰曝光:配置彪悍/4000mAh电池 mydrivers
Lenovo 's flagship all-metal exposure : Configuration sturdy / 4000mAh battery
After K910, Lenovo's new flagship has surfaced in last night , the configuration still looks very good , as we look to see their own preferences.
Users are now once again released a set of Lenovo 's new flagship Z2 real machine diagram , the back with a metal material , camera peripheral has also joined the red circle , built-in dual flash, the proportion of body panel is also good.
According to yesterday parameter see , Z2 Pro 2K with a 6-inch screen ( resolution of 2560 × 1440 pixels ) , full metal body thickness of 7.7mm, equipped with a 2.5GHz Snapdragon processor 801 (MSM8974AC), offers 16 million pixels , OIS optical Image Stabilizer camera.
In addition , the most impressive is that this phone is also 4000mAh capacity battery , which supports dual card dual standby . Also to be noted that , in addition to the Pro version , Z2 should have regular edition, properly properly .
s_6d0e30c2373647cd8105282aab671996.jpg s_b1af43f1244a491e8d7574e5e3886a12.jpg s_ec8fc4e9a606433a9588d2c1ffc156de.jpg
J
johndebur
Hier noch Bilder vom K920. Es hat u.a. NFC und unterstützt FDD-LTE und dual sim
2K屏幕3GB RAM+16MP 联想K920惊现 Zol
2K screen, 3GB RAM +16 MP Lenovo K920 discovered GSMA
No matter what show I participate always get all kinds of surprises, of course, most of which are participating in a variety of interactive prizes get a small gift, but this year I am located in China Mobile's booth at the GSMA2014 found a big surprise - never Lenovo unveiled over the K920.
Lenovo K920 is arranged in Chinese mobile LTE terminal display area, and when I started not too much attention, but when you see signs parameters instantly improves attention. Lenovo K920 is equipped with a 6-inch screen with a resolution as high as 2560 * 1440, which is Lenovo's first 2K screen smartphone.
His body back with a matte texture processing, anti-fingerprint effect is good, back at the top of the camera's impressively written words 16MP, 16MP Lenovo is also making it the highest pixel value smartphone. From the point of view of its fuselage frame should be using a unibody design. Fuselage and no speaker, is designed in the bottom of the fuselage, causing the hand grip can be avoided when the barrier.
And it is very hardware parameters to the force: 2.5GHz Snapdragon processor 8974AC, 3GB RAM +32 GB ROM, 500-megapixel front +1600 megapixel rear camera combination, dual card dual standby, support for TD-LTE, FDD -LTE line with TD-SCDMA, WCDMA and GSM networks, built-in Android 4.4.2 system. However, it is unclear when it will be released, we will keep the attention.
Cg-4jlOX74OIISdIADXk-XmqMokAAOMrALiKiwANeUR242.jpg Cg-4jlOX75SIGAiKAEyuooOa__kAAOMrAM-6DkATK66102.jpg Cg-4jlOX786IY13fADoABv6gfmAAAOMrQJW5d4AOgAe895.jpg Cg-4jVOX76OIE1aEADlYqhRDVoUAAOMrQAAAAAAOVjC437.jpg Cg-4jVOX77GIFqYQADSCUinPoecAAOMrQCaA64ANIJq604.jpg Cg-4jVOX79qIcccwADJuwZF4HDgAAOMrQMGblcAMm7Z622.jpg
thor2001
FDD, B3 (1800 MHz) und B7 (2600 MHz)...
Bin ja wirklich gespannt ob es ein Dualsim geben wird, das alle deutschen Frequenzen unterstützt.
Leider kein microSD-Slot.
J
johndebur
schwer zu sagen. Solange die mit TD-LTE rummachen eher nicht. Irgendwo stand auch, daß die CHina Unicom FDD-LTE testet, aber im Moment nur B1.
Aber B3 und B7 ist ja auch nicht schlecht. :)
Da kommt der Bildsensor aba ganz schön ins "glühen", hoffentlich haben die ne Wasserkühlung eingebaut!:hehehe:
Technologie Wunder? 500-megapixel
Der kommt von der Wunder Kamera...:(
Ich möchte gar nicht wissen, wie oft @johndebur es schon erläutert hat, daß das durch die Google Übersetzung kommt. GEFÜHLTE 1000x MINDESTENS :hehehe:
Aber scheint ja immer wieder für einen Lacher gut zu sein? ;)
J
johndebur
Neu
Sieht so aus, @johndebur wird es sicher bestätigen können ;) Man(n) muß sich nur ein paar Nullen wegdenken, bis der Wert Sinn macht :grin:
Edit:
man kann ja auch bing, yandex oder baidu zum Übersetzen hernehmen. Jeder übersetzt halt anders :p
bing:
But it is also very powerful hardware parameters: 2.5GHz Xiao-long 8974AC, 3GB RAM+32GB ROM,500 mega pixels front + rear 16 million pixels camera combo, dual SIM dual standby, support TD-LTE, FDD-LTE line with the TD-SCDMA, WCDMA and GSM network, the built-in Android 4.4.2 system. But it is unclear when they will be released, we will keep an eye on.
baidu:
While the hardware of its parameters is also very awesome: 2.5GHz snapdragon 8974AC processor, 3GB RAM+32GB ROM, taking pictures combined 5000000 pixel pre +1600 megapixel rear, dual card dual standby, support TD-LTE, FDD-LTE with TD-SCDMA, WCDMA and GSM network, built in Android 4.4.2 system. But it is not clear which will in the when issued, we will also maintain attention.
hmm yandex kann kein Chinesisch.
liegt auch oft daran , wenn man man ganze Sätze übersetzt, wird was anderes genannt, als wenn man nur einen Bruchteil übersetzt.
5 million pixels front +1600 Wan
The 5000000 pixel pre +1600 million
und wenn man die richtigen Sachen löscht, kommt dann irgendwann was sinnvolles heraus.
So jetzt hab ich was :grin:
500万像素 + 1600万像素
baidu:
5000000 pixels + 16000000 pixels
google:
5 million pixels + 16 million pixels
Mega pixel kennen die wohl nicht?
J
johndebur
Das handy ist am 5. August zu haben.
6英寸2K屏 VIBE Z2 PRO于8月5日发布
6 inches 2K screen VIBE Z2 PRO released on August 5
Lenovo's low-end products flowing into the market, high-end products, but hardly rich, and even can be called scarcity, and last year turned out to VIBE sub-brand is to change this situation and the birth of the first listing of the two products VIBE X with VIBE Z now been slashed prices, and this is to remind everyone that the new machine is about to immediate concern.
Sure, Lenovo has officially released the notification, the new conference will be held on August 5, and a new picture appearance, from the design point of view, he worked in public fairs this year Tianyi phone faceless VIBE Z2 PRO finally came.
The representatives of the association is currently the highest level of new specifications stronger than ever a lenovo smartphone, Z2 PRO uses a 6 in. Ultra HD 2560 * 1440 resolution display, powered by 2.5GHz frequency Xiaolong 801 main processor, built 3GB large memory RAM and 32G ROM based on Android 4.4 custom VIBE UI. The phone's camera specifications are also very cattle X, front camera self-timer is 500 million pixels, 16 million pixel camera support OIS optical image stabilization feature, support for 4G networks.
Members may have noticed a striking figure publicity shading, yes, this is the texture design Lenovo VIBE Z2 PRO back shell, Z2 PRO and S860, is the all-metal shell design. Since the shell is coated design, coupled with beautiful texture and metal material, the whole very metal. Moreover thickness VIBE Z2 PRO also thin enough, only 7.7 mm, a width of 81.3mm.
While it is impossible to know the true performance of the machine, but just look at the configuration, appearance, then, VIBE Z2 PRO already has a flagship wind, called the big trick-class product.
