Akku nach ca. 6 - 7 Stunden leer
dirk0402
Wenn es für einen Jugendlichen ist, kauf das mobistel cynus t6. Kostet 149€
Das hat einen 4400mah Akku.
Jugendliche verbrauchen den ganzen Akku in whatsapp, facebook usw. Weil das Display Dauer on ist und das frist den Akku.
hufranz2014
Handy war nur eingeschalttet und es wurden ca. 10 sms versandt am nachmittag
Mpie 4.5’’ Android 4.4.2 MTK6582 Quad Core 598.0~1300.0MHz RAM 1GB ROM 4GB Unlocked Quad Band AT&T WCDMA GPS IPS FWVGA Capacitive Smartphone TH MINI 809T
Android 4.4.2 OS + MTK6582 Quad Core 598.0~1300.0MHz + 1GB RAM + 4GB ROM
4.5” capacitive touch screen + 480 x 854 screen resolution
Dual camera, 5MP front camera and rear camera supports up to 8MP photo output with AF and flashlight
Support 720P video recordings
Support TF card up to 32GB
Support proximity sensor, G-sensor, Actions and gesture (In standby and main menu interface or in the gallery at the top of the screen waving your hands to make LAUNCHER or PHOTO to the left turn)
Calculator + Calendar + Clock + Browser + Email + Gmail + Play Store + Music + Gallery + Videos+ FM Radio + USB/Bluetooth tethering and WIFI hotspot
This Cell Phone works with 3G & 2G networks
(1)Compatible 3G network: WCDMA 850/2100MHz
The name UMTS (Universal Mobile Telecommunications System) is usually used in Europe. The UMTS Forum has confirmed that WCDMA is the world's most popular 3G technology
Outside of Europe, the system is also known by other names such as FOMA or W-CDMA. In marketing, it is often referred to as 3G or 3G+.
(2)Compatible with 2G Networks: GSM 850/900/1800/1900MHz
Example of Compatible Networks
France: Bouygues, Orange, SFR GSM, Virgin
UK: MCom, T-Moblie, TeleWare
Ireland: Vodafone, O2, Meteor, Tesco
Spain: Orange, Movistar, Vodafone, Simyo, Yoigo
Portugal: Vodafone, TMN, Optimus
USA: -Mobile/AT&T, NET10, Straight Talk Sim Only, SIMPLE Mobile(uses T-Mobile towers) ,
Telcel América, Black wireless, Cellular One, Go Smart, Wall Mart Family Mobile (uses T-Mobile towers), Fuzion Mobile and Suncom, Airvoice, CTC, Edge, Indigo, Tuyo, 7-Eleven, Callplus, O2, Lucas, Suncom
Please make Sure You have Sim card service so it means this phone will work.
Canada: Rogers, Fido
Australia: Optus, Telstra, Vodafone, Virgin
Italy: TIM, Vodafone, Wind
Basic parameters
Model
MINI 809T
Available language
Bahasa Indonesia, Bahasa Melayu, Cestina, Dansk, Deutsch, English, Spanish, French, Filipino, Hrvatski, Italian, Latviesu, Lietuviu, Magyar, Nederlands, Norsk bokmal, Polski, Portugues, Romana, Slovencina, Suomi, Svenska, Viet, Turkish, Greek, Russian, Bulgarian, YkpaiHCbKa, Hebrew, Arabic, Thai, Korean, Chinese
Phone type
Dual Sim (Single SIM and Single Micro SIM)Cell Phone
Format
GSM/WCDMA
Network
GSM 850/900/1800/1900MHz WCDMA 850/2100MHz
Phone shape
Bar Phone
Display size
4.5’’
Display material
IPScapacitive
CPU
OS
Android 4.4.2
ROM
1.52GB storage available (system used 2.48GB, total 4GB)
RAM
1GB
Screen resolution
480 x 854
G-sensor
Yes
TF Card
Support up to 32GB
Battery
1800mAh
Talking Time
180-320minutes
Stand-by time
60-90hours
Dimensions
130.7*66*7.8mm
Basic function
Ringtones Type
Polyphonic/MP3
Messaging
MMS, SMS, Email, Gmail
Profiles
General/Meeting/Outdoor/Silent
Audio
AAC, AMR, MKA, MP2, MP3, OGG, WAV
Video
3GP, AVI, MP4, MKV
JPEG,PNG,BMP, GIF
Office Format
PDF, PPT, Excel, Word (Under the assistant of third software, like Kingsoft office)
Data applications
Bluetooth
Yes
GPS
Yes
Data Transfer
USB cable
Wifi
Yes
Personal Hotspot
Camera
Front camera
5M pixels
Rear camera
8M pixels with AF and flashlight
Multi-media function
MP3 player
Yes
TV function
No
Mp4 player
Yes
FM radio
Yes
Additional Features
Music, Gallery, Sound Recorder, Vides, Movie Studio, Voice Search, FM Radio, Torch
Calculator, Calendar, Clock, Browser, UC Browser, Email, Gmail, Play Store, Downloads, Google, Google Setting, To Do
Ausgelebt
Outfluencer
Das Display zieht mit am meisten Akku bei einem Smartphone. Am besten schaust du einmal unter Einstellungen->Akku was wie viel Akku verbraucht hat um zu sehen ob sich da irgendwo etwas eingeschlichen hat.
erst mal den akku paar tage "trainieren wenn er neu ist.
alles was man nicht braucht deaktivieren....
unnötige frequenzen abschalten..
danmue
oder gibt es Kaufempfehlungen... für Kinder bis ~ 100 - 140,-
Umi X1 Pro:
http://www.100kaufen.de/produkte/smartphone/umi-x1-pro/
Zopo ZP700 bekommt man für etwa 100,- mit Versand aus Deutschland.
Ansonsten: Akku erst ein paar mal entladen (bis unter 20%, aber möglichst nicht bis 0%) und wieder laden. Dann entfaltet der sein vollständige Kapazität.
6-7 Stunden bei wenig nutzung ist auf jeden Fall nicht normal.
Ich habe bei den China-Phones eher die Erfahrung gemacht, das die Akkus dort länger halten als bei Samsung und Co.
GPS und Bluetooth sollte aber generell nur bei bedarf aktiviert werden. Das frisst eine menge Akku. (Nicht nur bei China-Phones)
dirk0402
Geht das immer nach dieser Zeit aus oder war das die erste Akku Ladung?
Wenn das Gerät neu war, laufen am Anfang viele Dienste die am Akku saugen.
Am besten Akku aufladen und mindesten 24 Stunden an lassen, nicht leer laufen lassen. Besser schon ans Ladegerät bei 20-30% rest Ladung.
wydan
hast du den akku ein mal
Kann das sein, wurde nichtmal telefoniert und trotzdem nach 6-7 Stunden leer.
wie schon der doc sagt, das muss sich etwas einspielen, wenn es ganz neu ist, man muss auch ein mal den akku ganz runter fahren auf rot oder lehr.
du kannst unter einstellung, batterie/akku, dir anschaun, was am meisten strom braucht
die app easy battery saver trimmt dein handy auf strom spaaren
Generell bin ich ja sehr entäuscht von diesem ChinaPhone. War erstes wird letztes sein
was stört dich vielleich können wir dir weiter helfen
guesa
Der Akku ist schon mit mageren 1800 mah angegeben, wenn die noch gefaked sind, kann ich die Aufregung verstehen.Vielleicht kannst du den Akku mal wiegen, damit wir ihn besser einschätzen können
1800 mager???
iphone 4/4s hat auch "nur" 1400mAh und hält paar tage...das sagt absolut nichts
das wiegen sagt auch nichts konkretes aus...
am besten erst mal trainieren einige tage...
unnötige dienste abschalten, apps die man nicht benötigt entfernen oder deaktivieren.
unnötige quad band frequenzen abschalten (oder muß usa u. andere ständig mitlaufen?)
N2k1
Seit wann kommt man beim iPhone 4/4S weiter als 12-16h?
Mit der Masse kann man zumindest in eine Richtung abschätzen, was geht und was nicht geht.
Auch ein permanenter Zellwechsel (gerade bei UMTS) frißt Akku.
Daher ist die Aussage
leider unzureichend.
Eingeschaltet = Standby und immer am festen Ort?
Dann ist etwas faul!
closebor
