iOcean X8 mini PRO - MT6592 5" HD 2GB Ram 32GB Rom 2/8MP Cams dual sim OTG 2200mah KitKat
J
johndebur
Noch gibt es keine Infos, wann das Handy kommen soll und was verbaut ist. Vielleicht gibt es eine LTE Version ?
依旧时尚 欧盛X8 mini版真机谍照曝光 mtksj
Still fashionable Ou Sheng X8 mini version of the real machine spy photos
Earlier this year, acting has always been low-key in Shenzhen Ou Sheng phone quietly released several new models, there is an eight-core product is the key, on behalf of the EU in the first half of 2014 Sheng trend, in addition to pricing populist X7S, has a giant screen for G7 and outside, fashion design, using double-sided glass + metal frame structure of most European Sheng X8 suction eye effect.
Also see the latest news from the European X8 positioned as the flagship Sheng will build a mini version of the real machine spy photos have surfaced.
People are pleased that finally saw him in the new pure white version, rather than the former black and white "panda color" real machine photos, Ou Sheng X8 mini version of the front panel is white, the color of the frame using mashups way, seems to be the silver upper and lower ends, the middle body is white, inferred, X8 mini version of the three-stage design is perhaps the back, but after the shell or two that can support the demolition.
Although the structure may change, but the overall style is still in line to the X8, if the latter, like a mini version of the shape Founder, screen frame is very narrow, it should still slim thickness. When it comes to size, since called the mini version, screen size decrease the possibility of the highest, which means Ou Sheng X8 mini measurements will be reduced accordingly.
About mini version X8 is still no clear information on the release, there are two guesses more reliable, a new machine should still MTK program, or Xuhui Shun should join the tide LTE network support; Second, the price will be lower than the X8 is inevitable, with a more friendly price fashion design will give users X8, I believe this is also loved by everyone, wait and see.
MTK mobile phone network reproduced the original article please retain links: still fashionable Ou Sheng X8 mini version of the real machine spy photos
J
johndebur
hmm von LTE ist jetzt nicht mehr die Rede. Es soll aber eine Pro Version geben, ob die das dann hat steht da jetzt nicht.
欧盛X8 mini规格全揭晓 ROM亮了!mtksj
Ou Sheng X8 mini specifications announced ROM bright!
Speaking of Europe's most beautiful products Sheng, Sheng concern European mobile phone users will be likely to vote for the latest listing of X8, the aircraft with glass and metal materials combined with Founder on tough shape, bring people in front a bright new feeling. In order to carry forward this advantage, Ou Sheng X8 mobile phone based on the new mini version of the aircraft - Ou Sheng X8 mini.
Live mini name, X8 mini X8 intuitive feeling is that the smaller version, the black version of the same design and standard version, both before and after the glass-covered, in part as a magnesium alloy frame, and even details such as buttons, the interface location is also exactly the same, just because the screen size smaller sake, Ou Sheng X8 mini height, width, some smaller, measurements are 142 * 70.1 * 7.6mm, thickness unchanged. Another early exposure of the mini version of the real machine photo shows the aircraft will have the white version, optional colors richer, slot areas. X8 mini is still on the left side of the fuselage just opened a card, can support dual card standby.
Can not be stored in the extended memory space inside mobile phones tend to be larger - the user to store data, but X8 mini's ROM has some big surprise, the machine has up to 32GB storage space, running memory to 1GB, so with a very rare, large ROM become a major highlight of the aircraft design outside.
Another cut is the screen, processor and camera three specifications, the new machine is equipped with five inches 720P resolution LTPS screen, touch screen can be realized with wet hands, gloves manipulation, using MTK6582 quad-core programs and equipment 2,000,000 8,000,000 after former pixel dual cameras, the battery capacity of 2200 mA, supporting WCDMA + GSM dual sim dual standby, as is the small and X8 + Nano SIM card slot design.
Finally talk X8 mini features, following the X8 \ upgrade G7 and other products to kitkat, mini version X8 run directly on Android 4.42 customized system, supports many somatosensory operation, from the user to upgrade troubles, in addition to the aircraft built in gyroscope, electronic compass sensor.
In addition X8 mini, follow-up will have X8 mini PRO listed some of the latter specification should be more powerful, and vigorously promote the speculation from the official, the mini version X8 will soon be listed in the domestic large, the time within this month, everyone Guess how much of it.
J
johndebur
soll bald erhältlich sein.
规格更强 欧盛X8 mini PRO配置全盘公开 mtksj
Specifications stronger Europe Sheng X8 mini PRO configuration overall public
Ou Sheng phone recently disclosed to the outside world with a version of its low-X8-X8 mini, fashion design, while maintaining X8, on the screen, memory and other core configuration adjustments, aims to do so in order to reduce costs and give users more choices. X8 MINI appear together along with the aircraft as well as an enhanced version of the name can guess from the PRO, which inevitably higher specification, recently Ou Sheng X8 mini Pro Xiangxi specifications have been the truth.
As X8 mini enhanced version, X8 mini PRO-core processor, memory, and does not shrink the two specifications, the standard version of the continuation X8 configuration, using the 1.7GHz frequency MTK MT6592 main eight-core processor and 2G RAM +32 G ROM large memory mix, this combination can basically guarantee mobile performance. Screen, camera, etc. and mini, still 720P resolution 5-inch LTPS display, front 2,000,000 8,000,000-pixel dual cameras, and 2200 mA battery, runs Android 4.4 system, through customization, adding a lot of fun and somatosensory practical interaction design.
And a mini version of the design is also the same, or double-sided glass + metal frame structure, the thickness as thin as 7.6mm, in addition X8 featuring black body gestures / wet hands / Taking operations and OTG / WIFI-DISPLAY function and gyroscopes Like a lot of sensors, additional features rich enough.
If X8 mini's 1G RAM and a quad-core CPU is slightly behind the current fast-paced, so Ou Sheng X8 mini PRO is perfect for a relatively small screen products, and both slim and stylish appearance, the core specification also mainstream , commonly featured, is worth looking forward to finally officially listed price. The end of the fastest mini version X8 listing enhanced version should also come soon.
Auf das NFC verzichtet das Mini. Geht beim X8 super. Oder habe ich etwas über sehen?
J
johndebur
Die internationale Version vom X8 mini Pro ist nun zu haben, außerdem ist es nun mit dem MT6592 CPU ausgestattet.
5英寸双面玻璃八核 欧盛X8 mini PRO海外首发 mtksj
http://www.iocean.cc/X8-miniPro-en.html
5 inches sided glass eight-core Europe Sheng X8 mini PRO overseas debut
Earlier this year the launch of the European Sheng X8 with stylish design and high-profile conquered a lot of friends, but because X8 has a 5.7 inches large screen, to love one-handed control of the user, may be somewhat difficult to have accepted, and the recent launch of the mini version just to solve this problem, which is reduced to 5 inches of the screen, in addition to a smaller size, appearance, and X8 is no different details.
X8 mini continue to be used in the form of the purchase of sale in the country, lower specification mini version cheaper, there's another synchronization Ou Sheng X8 mini PRO is the enhanced version of mini, there is a stronger configuration, mini PRO is now in overseas major electricity supplier website shelves starting price of about $ 269.99.
X8 mini PRO mini version of the same appearance and continuation of the metal frame + X8 sided glass design features, measurements are 142 * 70.1 * 7.6mm, starting for the black version, the follow-up will also launch a stylish white version. mini PRO processor, memory and other specifications better than the mini, enhanced version equipped with MTK6592 eight-core processor, combined with 2G RAM + 32G ROM large memory, is still 5 inches 720P resolution LTPS fit full screen, 2MP + 8MP camera and a 2200 mA battery, running depth of customization Android 4.42 systems, gyroscopes and other common sensors complete.
With the mainstream configuration parameters X8 MINI PRO is clearly the party dish, mini version of the case has started by insourcing of view, the way mini PRO may also be purchased within the domestic sale price will naturally be a lot of concessions.
oskaliope
