Huawei Honor 4X - Snapdragon 410 64bit 5,5" HD FDD LTE B1/ B3 2GB Ram 8GB Rom 3000mah dual sim
J
johndebur
Neues LTE HAndy von Huawei, kostet 1299 yuans (168€). Erhältlich am 6.11.
http://4x.honor.cn/pc/index.html
http://www.vmall.com/product/1494.html
6模14频双卡全网通 荣耀畅玩4X开始预约 mtksj
6 die 14 band dual sim full glory Netcom Play 4X start booking
After the campaign trail for some time, the glory Netcom phone finally opened a mysterious veil, the phone still play smooth debut product, called Play 4X, is glory for thousands of stalls built a true full Netcom phone .
Glory Play 4X is undoubtedly the most talked about places its full Netcom ability to prove the facts Play 4X does have an extraordinary network compatibility, the machine can support six die 14 frequency (FDD-LTE / TD-LTE / WCDMA / CDMA / WCDMA / GSM), full support for China Unicom, Mobile, Telecom's 4G, 3G, 2G network, and can support dual card dual standby, card 1 and card 2 enables mobile + Unicom card blindmate, Telecom SIM card can only be placed in the card slot 2.
Band can achieve many network compatible, very complex considerations manufacturers RF R & D strength, glory Play 4X using LDS antenna technology, combined with dual antenna design (main diversity antenna for LOOP + IFA hybrid antenna, diversity antenna is a dual LOOP antenna technology), the core solution for Xiaolong 410, clocked at 1.2GHz, supports 64-bit systems.
Other specifications mainstream enough, play 4X has a 5.5 inches 720P resolution, full fit screen (touch screen can touch 10:00), with 2G RAM and 8G ROM memory, after the former 5,000,000 13,000,000 pixels dual camera, battery capacity reaches 3000 mA, supporting electronic compass, dual noise reduction as well as WiFi-Display wheat and other functions, built on Android 4.4 custom EMUI3.0. The machine's design also under the martial arts, especially the back rosy, there wove textures, the main camera with a flash of inspiration is said to come from the shape of the orbit "Laputa" in the robot on the rear case, looks very personality, color aspect there white and gold two versions.
In addition to this much anticipated full version Netcom glory Play 4X also launched a telecommunications version of 4G, though still MSM8916 64-bit quad-core CPU, but only part of the support network telecommunications 4G, 3G and GSM networks, can support dual card dual be a selling point, basically the same as other basic specifications and full CNC versions.
Release date, the glory Play 4X full version Netcom and Telecom 4G version began appointment on the 28th morning, November 5 appointment ended, the first time was snapped at 10:00 on November 6, full CNC version is priced at 1,299 yuan Telecom version for 999 yuan.
1-14102Q0524C44.jpg 1-14102Q0531Y61.jpg 1-14102Q05304118.jpg 1-14102Q05331594.jpg 20141028103243284.jpg
Bänder:
Network standard card 1:
Mobile 4G / 3G / 2G; Unicom 4G / 3G / 2G; Telecom 4G / 3G / 2G; Card 2: Mobile 4G / 3G / 2G; Unicom 4G / 3G / 2G. . (Note: a card 1 and card 2 at the same time can be set only one card for 4G / 3G, one for 2G (GSM); 2 telecom cards only one card, telecom card is inserted, the card 2 only. for 2G (GSM))
Network frequency card 1:
TDD-LTE: B38 / B39 / B40 / B41; FDD-LTE: B1 / B3; TD-SCDMA: B34 / B39; WCDMA: B1 / B8; CDMA: BC0; GSM: 900/1800 / 1900MHz (roaming); card 2: TDD-LTE: B38 / B39 / B40 / B41; FDD-LTE: B1 / B3; TD-SCDMA: B34 / B39; WCDMA: B1 / B8; GSM: 900/1800 / 1900MHz (roaming )
Data service LTE Category 4:
150Mbit / s (downstream), 50Mbit / s (upstream); TD-SCDMA: 2.8Mbit / s (downlink), 2.3Mbit / s (upstream); WCDMA: 42Mbit / s (downstream), 11.2 Mbit / s (up); CDMA2000 EVDO: 3.1Mbit / s (downlink), 1.8Mbit / s (up); GPRS / EDGE: CLASS 12
eltipo
Hab mich mal ein bisschen angelesen. Das ist ja ein absolutes Frequenzchaos weltweit. Man kann nur darauf hoffen, dass die Hersteller universelle Modems einbauen, die man dann eventuell passend freischalten kann. Ich befürchte, sonst wird das nie etwas.... o2 zb sendet gar kein UMTS hier, das haben die gleich sein lassen, sind direkt auf LTE gegangen, hat man nur nix von. Die Telekom hat auch nur Landfunk... Also nix gewonnen....
Gesendet von meinem CUBOT X6 mit Tapatalk
J
johndebur
Ja ist echt ein Chaos. In china ebenso :) da sind die FDD-LTE frequenzen nur in bestimmten Städten zugelassen, als Test Bänder.
Und hier wollte doch eplus oder wer auch immer mit TD-LTE herumexperimentieren.
naja ich denke die nächsten CPus können dann alle Bänder :) Gibt ja auch schon von Marvell oder so chips mit allen möglichen Bändern.
Chocoball
Ich behalte jetzt ein Auge auf das Snapdragon 615 (64-bit/LTE) weil das Snapdragon 410 schon wieder aus 2013 ist.
Die Huawei Modellen (Ascend P7, Ascend Mate 7) in Europa unterstützen Band 20 aber die Honor Reihe ist eigentlich nicht für Europa gedacht.
Joolsthebear
Bisher ist das ZP999 das einzige Gerät welches mit B20/800 Mhz umworben wird ... schade das es das nicht ins MX4 geschafft hat ... werd wohl noch ne Zeit lang beim OPO bleiben und mit dem fehlenden LTE leben ...
Chocoball
@thor2001 wenn ich so rundschaue sehe ich Honor Modelle nur mit B1 und B3 aber soll Honor in Europa kommen wird es hoffentlich auch B20 wie die Ascend Reihe bekommen. Sobald es in normalen Shops wie Mediamarkt auftaucht werden wir vielleicht mehr wissen.
Ab Morgen ist es schon erhältlich in den Niederlanden. Es soll auch 4G+ unterstützen. Wenn ich mehr weiss melde ich mich.
Merlini
Zauberer
@Chocoball
Hm, "alle gängigen Netzstandards" ... ich bin da sehr skeptisch.
Die (LTE)Bänder sind nämlich dort nicht aufgeführt.
Grüße
Das betrifft hier wirklich nur die Standards und leider nicht die einzelnen Bänder. Das 4X unterstützt leider B20 in der China Version nicht. Ob das Gerät nach DE kommt, konnte selbst auf der Honor Vorstellung heute in Berlin keiner sagen.
closebor
