Vivo X5 Max - Snapdragon 615 5,5" FHD Super Amoled 2Gb Ram 16GB Rom 4,75mm dick 5/13MP Cams dual sim
J
johndebur
Wird anscheinend im Dezember vorgestellt.
vivo预告全球最薄手机:4.75mm mydrivers
vivo notice the world's thinnest phone: 4.75mm
Just, vivo in the official release of the new micro-machine X5 Max posters. Yes, it is our previous coverage of the "world's thinnest phone."
Previously, the aircraft has passed the MIIT network license, the relevant parameters are also exposed it. Its measurements size of 153.9 × 78 × 4.75 (mm), body thickness of 4.75mm, 4.85mm thinner than the OPPO R5.
Configuration, vivo X5 Max uses .5 inch 1080p screen, equipped with 1.7GHz eight-core processor (MT6752), built-in 2GB memory + 16GB fuselage storage, providing 5,000,000 +1300 megapixel camera, running Android 4.4.4 system.
It is understood that the aircraft is expected to be officially released in December, there is a Xplay debut with new series.
http://mtksj.com/html/mtkshoujizixun/9526.html
1-141111152555N5.jpg 1-141111152622213.jpg s_a20b293e88ee43a7ae4f312f79f91d2a.jpg
J
johndebur
angebliche Bilder vom Handy?
薄到没有朋友 疑似vivo X5Max真机现身 mtksj
Thin to no friends suspected vivo X5Max real machine appeared
vivo is preparing for a new slim -X5Max, because the aircraft is expected to exceed the thickness of the OPPO R5 and ELIFE S5.1, very popular with everyone's attention recently, in a few days ago, suspected X5Max real machine spy photos have been exposed.
Sources said the product in the following figure is poised vivo X5Max, although not directly give specific figures thickness, but very slim indeed roughly the thickness of the aircraft could see visually the edges even less than 4mm and, according to information circulated before, X5Max thickness may be 4.75mm, hopefully become the thinnest smartphone.
To so many of the components inside the inclusion of such a thin thickness, is not a simple matter, taking into consideration the manufacturer's R & D capabilities. In this new on, vivo using the name "Critical sided cloth board" technology, the advantages of this technique is that the vast majority will do the motherboard components side, reducing the space occupied, allowing for a more slim X5Max thickness.
Recent official vivo to "thin heartstrings" as the theme for most of the characteristics X5Max were exposed, except everybody knows slim thickness, vivo X5Max will use better materials to build the fuselage, make it more robust, in a very under thick slim figure, reserved memory card expansion and 3.5mm headphone jack, and will bring unimaginable HIFI sound quality.
Finally, the need to mention is that a lot of news is still pointed vivo X5Max MT6592 program, if the situation is really using the 1080P 5.5 inches, the eight-core MTK MT6752 carrying more tricky.
highwind
Das zweite "Foto" (=CAD Bild) aus dem Eröffnungspost sieht echt atemberaubend aus, nicht nur wegen der Dicke sondern vor allem wegen des extrem guten Display zu Gehäuse Verhältnisses!
Schade, dass man bereits auf dem zweiten Foto (=echtem Foto) im vierten Post schon erkennen kann, wie sehr hier wieder ohne Ende beschönigt wurde... da ist mindestens doppelt so viel Gehäuse über dem Display wie vorher (von der Kante, die auf einmal eine Rundung geworden ist ganz zu schweigen)
Mitch
Atemberaubend! Hoffe es bleibt beim 5" Display und wird nicht größer...spannend wird dann nur noch die Akkulaufzeit :)
J
johndebur
Ist wohl eher ein 5,5" Super Amoled Display
vivo X5Max将采用SuperAMOLED屏幕 mtksj
vivo X5Max will use SuperAMOLED screen
A new generation of ultra-thin products X5Max vivo HIFI + available soon, want to become "the ultimate HIFI slim Kings" and the mystery of the layers of this phone are also being opened in public after the fuselage interior design, vivo X5Max used screen material has officially declassified.
Nothing less than the current mainstream LCD screen material with OLED, due to additional components without a backlight module, which has inherent advantages in thickness, while the pursuit of the ultimate thickness vivo X5Max has chosen in the SuperAMOLED OLED screen, and its process improvements, thickness X5Max screen panel screen and thinner than ordinary SA, reached 1.36mm or less, along the foundation and the use of "one-sided critical layout" technology for ultra-thin motherboard thin body.
The machine's screen size has no doubt that the early release of its Ministry data show X5Max uses a 5.5 inches 1080P resolution screen, became a handful FHD resolution SuperAMOLED equipped with 5.5 inches screen products. As for the real thickness of the yet to be released, but informed sources said that the opportunity to retain a 3.5mm headphone jack, may X5Max really rumors like that, 4.x mm in thickness control.
As of now, the official is just the process of the aircraft publicity, HIFI vivo as a top priority, in X5Max who should be better reflected.
J
johndebur
Anscheinend kann man bei dem Handy zwischen dual sim oder mehr Speicher wählen ? Am 10.12. wird es vorgestellt.
全球最薄!vivo X5 Max:12月10日见 mydrivers
The world's thinnest! vivo X5 Max: 12 月 10 has become increasingly
The mobile phone industry is such that once the manufacturer to obtain a title, the vendor will send immediately subsequent force and beyond.
Just this, vivo officially announced that it will hold a conference X5 Max on the 10th of this month. Through the case before the exposure, the phone is very Guards.
The message has been displayed before, X5 Max will be the world's thinnest smartphone, the thickness of only 4.75mm, and more Guards is also built this thickness 3.5mm interface, while, vivo official also claimed that the aircraft will be equip a new Hi-Fi 2.0 standard.
Even more interesting is that this phone would have such a function, it is a versatile Cato, simply put, it is the user can select Dual SIM card + combination or single memory card.
If you are looking forward to this world's thinnest smartphone, might now take a look at an interesting invitation sent vivo.
J
johndebur
Wurde anscheinend heute veröffentlicht.
Das Handy hat dual sim oder man kann statt einer SIm Karte eine SD-karte einlegen. Vielleicht geht auch beides so wie beim Ascend mate?
Kostenpunkt 2998 yuans (392€) und ist am 22.12. erhältlich
全球最薄手机vivo X5Max发布!超逆天 mydrivers
The world's thinnest phone vivo X5Max released! Super Guards
Held in the afternoon Hi-Fi Carnival, vivo one up on the point, has released the world's thinnest phone --X5Max, body thickness of only 4.75mm, and created a number of records.
In order to achieve such a thin thickness, vivo from the structural design, electronic design, signal processing, material processing technology, device selection and customization, and other aspects of a breakthrough, the motherboard uses a unique "one-sided layout critical" to reduce the thickness 1.77mm, one side of the layout area of 90%.
In addition, X5Max using 3.98mm industry narrowest multi-spar wing box, and ensure the rigidity and sturdiness slim basis.
Screen, X5Max using a 5.5 inches Full HD 1080P super Amoled display, is also the world's thinnest, the thickness of only 1.36mm.
Meanwhile, X5Max also used the world's thinnest speaker BOX, its thickness is 2.45mm, also has the effect of putting excellent.
Cato is a major highlight X5Max design, which uses the primary card + Vice card design, that Micro-SIM card + nano-SIM card or TF card, the user can chose freely, vivo call "and or" card Torr.
It is worth mentioning that the machine also provides a slim 3.5mm standard headphone jack, and pioneered the cocoon interlocking headphone jack, ensuring space and performance while greatly enhance the structural strength of the headphone jack.
Core configuration, X5Max equipped with 64 eight-core 1.7GHz Qualcomm Snapdragon 615 processor, with 2GB of RAM + 16GB body storage (128GB extended support), providing 5 million +1300 megapixel camera (Sony IMX214 sensor, official claims camera level and Xshot quite).
In addition, X5Max also supports K song mode, the built-in reverb YAMAHAYSS-205X processor chip, for the first time on Android platform with real-time ear back vocal reverb sound. Also use the speaker box and Wi-Fi sync screen projected onto a large screen, you can simulate the KTV sound environment. Currently, sing, love to sing, Teana K songs, songs and other universal App K has support.
Systems, X5Max pre-installed on Android 4.4.4 of Funtouch OS 2.0, vivo is also dedicated to its AMoled screen customization dark visual solutions.
Etwas über das Soundsystem im handy:
不仅全球最薄 X5Max Hi-Fi 2.0发布 mydrivers
Not only the world's thinnest X5Max Hi-Fi 2.0 release
With the arrival of the world's thinnest phone X5Max, vivo also released a new Hi-Fi 2.0 architecture. Compared to the previous Hi-Fi 1.0 (for use on Xplay3S), 2.0 upgrade in many aspects, vivo called "next-generation handsets Hi-Fi standard."
According to the official introduction, Hi-Fi 2.0 features a new over two op-amp system, using electronic properties of the strongest to do pre-op amp op amp charge current to voltage converter; with the "taste" the best driver strongest transport place to do after the class amplifier, power amplifier and is responsible for driving headphones.
vivo said two op amp to work together to reduce the signal loss in the process, the sound becomes noise floor cleaner.
In addition, under 2.0 architecture, vivo designed a new secondary power supply system. In addition to DC boost DCDC 1.0, also joined the LDO two innovative power, namely low dropout linear regulator power supply, greatly reducing the circuit ripple.
According to the data provided vivo, the current stability of the Hi-Fi 2.0 has made a huge improvement, leading to a more smooth sound and lower distortion, with multiple levels of the op amp filter, the average distortion dropped 10dB, equivalent to the sum from X1 to Xplay3S generations distortion reduction.
For more description of the image, vivo with such an analogy:
How can we better understand the difference between 1.0 and 2.0 architecture in the supply of electricity it? We compared the power of water, 1.0 framework we put water out to solve the problem of no water to drink. In 2.0, we come out of the water for added filtration systems and stable water pressure piping systems, making it a truly convenient to use and suitable for drinking water quality.
As the first product Hi-Fi 2.0 architecture, X5Max equipped with a new version of + SABRE ES9601 ES9018 exclusive combination regimen + + OPA1612 custom luxury circuit
Data front, X5Max can achieve over 120dB SNR, 118dB dynamic range, enhance the maximum distortion is less than -100dB, compared Xplay3S more than twice.
vivo stressed that although the architecture upgrade from 1.0 to 2.0, but the style is consistent voice vivo and give vivo sound style has a name: "Latte", that is faithful to the original quality, rich layers, and all with a touch of sweetness.
s_03a99b8a8a1247f696f2529b9cdb73d4.jpg s_3a88a1431f8e4db5a90a31550929616a.jpg s_4bfbc29a0f5e42d4a126ba49a415df14.jpg s_6fbfdf1698e5405b9a6e3816477ed65e.jpg s_8bed075e4afb45cbbe75e691fb9e933a.jpg s_944aeaaf2da84caa9b8849690924b465.jpg s_b969397c3b23488b83dbbd5eacb27237.jpg s_e0a531d2e7f649b4a98b687d97070a57.jpg
Photos vom Handy:
好一把“刀”:4.75mm最薄手机vivo X5Max图赏 mydrivers
Well a "knife": 4.75mm thinnest phone vivo X5Max tushang
This afternoon, vivo but also show the world their skill so thin, the world's thinnest phone X5Max 4.75mm official release, creating a number of records.
Of course, in addition to the thin, there are some other highlights of the aircraft, such as providing a standard 3.5mm headphone jack, support for the new Hi-Fi 2.0 and provides a top-op-amp chips and so on. And the camera, with camera and flagship Xshot vivo same level.
Although 2000mAh battery may become trough point, but this is all slim phone inevitable reality.
X5Max the official price of 2998 yuan. December 22, the whole Internet City.
s_0d6d762e75584dbeacfc04d54091104c.jpg s_0dbd21b0d1ad49bdbc49605e50452d73.jpg s_3d70fe9fbfe14a118bc53058e3f1c127.jpg s_07f900c2110a48b2859e0c36fccc540f.jpg s_8bd6345b2223487592b6075bf70fba12.jpg s_9f400275c86d4212ac7c1d679c575a0d.jpg s_9fe4024a9ce84c12a5a50aea82a0b611.jpg s_31a889cee72d4386a3c39f011b370e37.jpg s_041acde1905749de8a8f2584221af109.jpg s_43b7266a2dd945b188285c5d2dd351a1.jpg s_94adcce06f9d4b29ad74eb5d0b436f72.jpg s_98c1cc70f7f4420498f0362a3f8a3e11.jpg s_163a2089050f405fb96d1ca32de2d1b8.jpg s_191e6c3d5c1f4559b33dca25b866312f.jpg s_620eb554e29044e6bfa16cd49ce0eed7.jpg s_634e99781c1c4500ba7bf2ecdaea73b1.jpg s_18319dd36e764f5d8ce35daeae413d29.jpg s_a19f49b8d9f0442fab4982efc10378b5.jpg s_a204d4ed4f0d4c1e939e45c00847c094.jpg s_abd164edc39849f1aa310bff47b5c083.jpg s_b6ff4bc68bf7405bb6a792dec5985074.jpg s_c803b6a04a2c45189389a47809b2091e.jpg s_f3e58cb4e68b4eb6a3fb7b4f162d9ebf.jpg
