Manta 7X - Snapdragon 801 5,5" FHD 2GB Ram 32GB Rom 13/13MP Sony Cams 4200mah LTE
J
johndebur
neues Handy von neuer Handy Firma Manta. Habe deren Webseite noch nicht gefunden.
惊现无按键手机!Manta X7将杀到 mtksj
Discovered no key mobile phone! The immediate concern Manta X7
Mobile industry has developed rapidly, many companies entangled in a price war, when part of the brand carries the dream of avoiding such a quagmire create innovative products, as this upcoming Manta X7, it does not have an ordinary smartphone "special features", the machine uses no buttons design, known as non-key phone!
Obviously Manta is a newly established brand - and never heard before Manta's name, the brand from Shanghai, China Science and Technology Co., Ltd. was founded dolphin, the first product called Manta X7, X7 is the official description - it is a "from tomorrow "smartphone.
Exposed by the current renderings can be seen, the aircraft's fuselage side seems really no common Power, volume and other keys, abnormal clean around the body, but can see the HOME button below the screen. Design, the machine should be used after the metal shell, the effect can be seen in Fig back with good metal texture, in addition to the application of the fuselage upper and lower ends of the popular micro-arc curve design.
Not equipped with physical buttons, then the machine is how to achieve the volume, switch machines and other commonly operate? Perhaps a relationship with the machine uses "smart borders", commonly used function keys by touch in the box "smart borders" to complete. In addition to official statistics, Manta X7 also features an innovative tracking technology thumb, thumb through the wisdom of the border sensor location on the screen to form a "hot zone thumb," so the dial pad, and other applications are always displayed in the range of thumb can be manipulated to achieve true the one-handed operation, even if the screen is bigger, but also the normal control with one hand.
The current can be learned just fur, although no more substantive content exposure, but only the "no key" and "wisdom of the border," and so it is sufficient to attract attention, everyone on the phones price, configuration and other increasingly tired of the moment, it is time to point things stimulate innovation, and "from tomorrow" Manta X7 some concern.
1-141201150A2260.jpg 1-141201150Fa24.jpg 1-141201150HK62.jpg 1-14120115063O08.jpg 1-1412011506125O.jpg
Cykless
Gut ähnlich wie beim Iphone nur anders rum, finde ich jetzt eigentlich gar nicht so schlimm. Sieht dennoch cool aus, sorry wegen der Frage aber stand irgendwo was es kosten wird?
iErp
Ich meinte eher, die Cam ist irgendiwe zu hoch positioniert, nicht in der vertikalen Mitte zwischen Gehäuserand und diesem iphoneartigen Streifen. Dass die da links oben is stört mich an sich auch ned ;)[DOUBLEPOST=1417773139,1417773022][/DOUBLEPOST]
Schade, das New Kids Handy wäre schon geil
Aber ja, hätte was ;) Schau mal mein neue Manta Junge
Aber es bräuchte noch ne neongrüne Sonderedition
Cykless
Oder ein Neon grünes Case irgendsowas. Aber wenn es das in richtigen Neon grün geben würde, dann würde ich das Handy sogar vorbestellen. Wäre mir auf jeden fall wert!!
Igitt... auf dem neunten Foto in Deinem Post Nummer 7, @johndebur , sieht es ja so aus, als ob das Gerät unten nur einen flachen proprietären Anschluss hat, den man nur mit einem kleinen Adapter auf USB wandeln kann... :(
Oder sehe ich das falsch?
Profirudi
Da fehlt nix Neon grünes, da fehlt der Stylus mit Fuchsschwanz ;)
ein paar cowboystiefel als handyhülle wären auch nicht schlecht
Da musst aber dann aber auch reinpinkeln damit das Handy ordentlich reinpasst.
Wem das Handy zu dick ist, der kann es ja auch tiefer legen lassen. Dann ist es nicht mehr so hoch. Da kann man dann durch das Tuning das Handy um ca. 0,5 km/h schneller aus der Hosentasche ziehen.
closebor
