s7yler
Youtube.com/s7yler
So hier einen Geekbench 3 Akku Test Vergleich:
Handy/Modell - CPU Type - Battery Runtime/Score - Hersteller Angaben
UMI eMAX................ARM MT6752 - 08:44:40 - 4968.............3780 mAh laut Hersteller
Ecoo E04..................ARM MT6752 - 06:58:30 - 3721............3000 mAh laut Hersteller
SISWOO Cooper i7....ARM MT6752 - 06:14:20 - 3539.............2100 mAh laut Hersteller
Thl 2015..................ARM MT6752 - 06:05:50 - 3331.............2700 mAh laut Hersteller
Ulefone Be Touch......ARM MT6752 - 05:25:10 - 3043.............2550 mAh laut Hersteller
Und ein Unboxing Video dazu:
Let the flaming begin!
Highlights
5.5 inch IPS OGS capacitive screen, FHD 1920x1080 pixels
MTK6752 Octa Core, 1.7GHz GPU:Mali-T760
Android 4.4 OS (Android Lollipop 5.0 Update)
2GB RAM + 16GB ROM
Size: is 7.8 mm thin
Backcover is of plastic (none-removable)
Notification LED, Red & Green
Battery 3780 mAh
Dual SIM card dual standby, micro sim slot
Dual Cameras, 5.0MP front camera, 13.0MP back camera
Support FDD LTE/4G/3G/GPS/Wifi/Bluetooth/Miracast
Networking:2G: GSM 850/900/1800/1900MHz, 3GWCDMA 900/1900/2100MHz, 4G: FDD LTE: 800/1800/2600MHz
Original Beitrag:
Momentan gibt es noch nicht viel Information über UMI eMAX, nur der Namen und das es ein 3780 mAh Akku hat, und immer noch recht dünn sein sollte, plus ein Bild vom Hong Kong Trade Fair wo man auch einige Spezifikationen sehen kann.
Highlights
2GB RAM + 16GB ROM
Battery 3780 mAh
Original Beitrag:
UMI eMAX is only 7.9mm thick, the claimed battery capacity is over 3780mAh.
UMi have made a name for themselves with the UMI Zero. After that UMI created a fantastic PC tool called Rootjoy to support custom ROMs.
While we are still wondering what would be the next, UMI just hit us with their Hammer. The toughest cookie UMI Hammer smartphone. However, if anyone had been looking at images of the Hong Kong trade fairs that just finished, you might have seen images of a new UMI phone called eMAX.
After communicated with UMI, UMI eMAX is designed with a 7.9mm thickness body with over 3780mAh capacity battery.
This mean for a heavy smartphone user, the phone still can last 2-3 days long. If the eMAX specs are going to be real, then it would be the most outstanding smart phone, with similar specs as phones which only has 3000mAh battery. /Text & Image Source UMI
