Lenovo Music Lemon K3 Note - MT6752 5,5" FHD 2GB Ram 16GB Rom FDD-LTE dual sim 3000mah 5/13MP Cams
J
johndebur
Habe die FDD-LTE Bänder noch nicht entdeckt. Preis ab 899 yuans (132€) ohne diesen Lautsprecheraufsatz und 999 yuans mit Lautsprecher (150€)
http://sale.jd.com/act/KfzsobMI5Bx.html?cpdad=1DLSUE#haos
Werbeclip: http://yuntv.letv.com/bcloud.html?uu=82abd5491f&vu=916da33ca5&width=640&pu=ae87902567&height=360
完爆魅蓝红米 联想5.5英寸新机发布 mydrivers
After blasting charm blue and red rice Lenovo released a new machine 5.5 inches
Tonight, the association held a press conference in Beijing, officially launched the music lemon K3 Note.
Specific configuration, music lemon K3 Note the use of 5.5 inches 1080p display, equipped MT6752 eight-core 1.7GHz processor, 2GB of RAM and 16GB of built-in storage fuselage, providing a 500-megapixel front camera and a 13 million-pixel rear camera, battery capacity 3000mAh (removable), runs on Android 5.0 Lenovo VIBE UI 2.5.
It supports Mobile / Unicom double 4G network and dual card dual standby, does not distinguish between main and secondary card, two SIM cards can switch freely between the 4G network.
The machine Standard Edition is priced at 899 yuan, compared with the price either configuration or charm blue and red rice Note should be stronger for some.
In addition, it also provides $ 999 Teana version has increased the ceramic piece vibration speaker (behind the bump is) . The K3 Note Teana version on the box, and the box can form a resonance cavity, known as the loud music can bring better experience.
550fbdbaNc48e0e0e.jpg 550fbdb9N92b24a2c.jpg 5510174eN69f655f3.jpg 550fbdbaN5e39e8e6.jpg s_ec416bb066084470a2a54490a720cd11.jpg 3c9a9447ff814beca74fb15dcaaec782.jpg 57173048771d45bcbd5b2af12a988660.jpg 2e5cd2ad664240c2ae0e4f6a481ad3bf.jpg ScreenShot007.jpg ScreenShot008.jpgdfe919fdae8182b.jpg
guesa
hier gibt es das K3 (ohne Note), aber die LTE Bänder für DE sind wieder nur light. Man muss bei Lenovo immer ziemlich acht geben, es gibt auch die Version mit chinesischem LTE, ist etwas günstiger. Aber wie , gesagt gelb ja, aber kein NOte
charly60
Das Music Lemon K3 ist ja schon seit Ende 2014 auf dem Markt
http://www.inside-handy.de/news/33661-k3-music-lemon-fuer-80-euro-lenovos-paradebeispiel-fuer-die-vernichtung-von-samsung-lg-und-co
Das mit der "Beule" oder ist das evtl. der Volumeregler aufm Akkudeckel soll dann das K3 Note werden[DOUBLEPOST=1427136090,1427135225][/DOUBLEPOST]
Das könnte aber auch ein neues Bedienkonzept für Musik- und Videoplayer werden, ala Dreh-Dück-Steller in den PKWs ;)
J
johndebur
Hier die Bänder: also es hat laut Zol B1, B3 und B7
http://www.lenovomobile.com/imodel-cn/zh/打开目录/手机/VIBE系列/联想乐檬K3-Note新品上市/p/k3_note
http://detail.zol.com.cn/399/398459/param.shtml
Legend Music lemon K3 Note (Teana version / mobile 4G)
Network type dual card, dual 4G
4G Network Mobile TD-LTE, China Unicom TD-LTE, FDD-LTE Unicom
3G network mobile 3G (TD-SCDMA), China Unicom 2G / mobile 2G (GSM), telecommunications 2G (CDMA)
Support band 2G: GSM B2 / 3/8
3G: WCDMA B1 / 2/5/8
3G: TD-SCDMA B34 / 39
4G: TD-LTE B38 / 39/40/41
4G: FDD-LTE B1 / 3 / 7MHz
http://mobile.zol.com.cn/512/5124694.html
Und noch ein paar Fotos:
Cg-4WVUPpPyIP40SAARSuwbRVrkAAAEhgFjJGQABFLT500.jpg Cg-4WlUPpPmIZAtNAALqIIAiXiQAAAEhgEBnpMAAuo4317.jpg Cg-4WlUPpPeIAwQkAAMAYpU7yTcAAAEhgDWVX8AAwB6568.jpg Cg-4WlUPpPaIBc6lAAT9B0nvbuEAAAEhgCVBuwABP0f057.jpg Cg-4WlUPpPWIaYn3AAPF5E_qE9UAAAEhgB6zO4AA8X8544.jpg Cg-4WlUPpPOIanu7AAWHg4PmF6wAAAEhgBDhmIABYeb883.jpg Cg-4WlUPpPOILITUAAQkY-pvJQQAAAEhgA4VXQABCR7576.jpg Cg-4WlUPpPKIB4rrAAV0_8iFPEUAAAEhgAAAAAABXUX004.jpg Cg-4WlUPpPyIXf1PAAR-vXPxv50AAAEhgFp634ABH7V493.jpg Cg-4WlUPpPWIZTO4AAQnTgQpMtoAAAEhgBf4ngABCdm333.jpg Cg-4WlUPpPuIEepiAAVKFGA6fXkAAAEhgFCbsMABUos349.jpg Cg-4WVUPpPaId4GJAAT9BxOHaJcAAAEhgCtfe8ABP0f184.jpg Cg-4WlUPsnuIf84bAAWabz5WXHYAAAEugO_jrgABZqH492.jpg Cg-4WVUPpPeIdkSwAALYYJa_UeAAAAEhgC7N_sAAth4720.jpg Cg-4WVUPpPeIeScpAAIzWeTPLsQAAAEhgDZcWUAAjNx805.jpg Cg-4WVUPpPiIKV1xAAKYptWrxxAAAAEhgDv7K0AApi-388.jpg Cg-4WVUPpPiIZq0sAAJJ4SNM-z0AAAEhgDkEjQAAkn5608.jpg Cg-4WVUPpPiINoVSAAMEzlAv4scAAAEhgDfasYAAwTm719.jpg Cg-4WVUPpPOIRRR9AAS94kAL6bcAAAEhgAzQeMABL36719.jpg Cg-4WVUPpPqIMsQxAAKQ10PKv5UAAAEhgEuyGgAApDv371.jpg Cg-4WVUPpPWIIva9AALPaXz0EsQAAAEhgCHQY0AAs-B854.jpg Cg-4WVUPpPSIdjDAAAPN7FKQyocAAAEhgBWjF0AA84E200.jpg Cg-4WVUPpPSIDKYKAARSEW_9RmMAAAEhgBbkE8ABFIp951.jpg
bei dem hier steht laut Google translate:
On the back of the machine uses more than a hundred channels of precision technology and professional color tuning division after testing hundreds of diffuse light, whether visual tone or texture performance all have a better performance.
(keine Ahnung was das heissen soll , zumindest soll irgendetwas besser funktionieren. :grin: )
und hier
That is what the machine and packaging in we saw a rounded bulge in the back of the fuselage design made wonderful sound effects section.
Auf jeden Fall ist da was.
Rosenklotz
Ich finde das Gerät auf dem Papier super. Die Beule auf der Rückseite scheint auch nicht mehr vorhanden zu sein, und der Preis ist heiß! Aber: Hat es LED Notification, ja oder nein? Bei einigen Shops heisst es ja, bei anderen nein, und "echte" Reviews habe ich noch nicht gefunden. Kann jemand LED Notification bestätigen?
J
johndebur
Die Beule hat auch nur eines der Geräte, die teureste Variante. Die anderen sind einfach flach.
Hab mal versucht nach Notification LED zu baiduen, aber weiss leider nicht wie das Wort auf chinesisch heißt. Es kamen nur Ergebnisse, daß es einen dual LED Blitz hat.
Aber bei FCT, kann man sehen, daß es unter den Display settings Einstellungsmöglichkeiten gibt, die ein benachrichtigen. Ich denke mal da geht dann nur das Display an? Die Knöpfe unten sind anscheinend auch nie beleuchtet, sind bei den ganzen youtube CLips immer aus?
Hmm FCT sagt im youtube Kommentar , daß es angeblich eine Notification LED hat. Keine Ahnung :grin:
Code:
https://youtu.be/3qfiSJpHcXQ?t=6m1s
Könnte mir vorstellen , daß wenn dann hier was leuchtet? Oder es ist irgendein Sensor?
http://shop.lenovo.com.cn/product/45012.html
Rosenklotz
Hmm, mixeshop sagt auch es hätte LED Notification, aber bei ganz vielen anderen Shops steht eindeutig nein. Naja, da bleibt nur Review abwarten.
Rosenklotz
Habe mir das Video von FCT bei youtube angesehen: Da ist im Displaymenü ein Unterpunkt "Light", da kann man Optionen auswählen für "missed calls", "messages" usw. - was sollte das anderes sein als LED Notification? Und sie bestätigen das ja auch in den Kommentaren. Also Antwort: Ja, das Lenovo K3 Note hat LED Notification. Für mich damit ein ganz heisses Eisen...wenn es doch nur ein schwarzes Backcover gäbe! Weiss und Gelb finde ich beide schlimm
wydan
Rosenklotz
es fehlt aber wie so oft das LTE band 20
p { margin-bottom: 0.25cm; line-height: 120%; }
es gibt mindestens zwei verschiedene ein T50 und T30 (und eins ohne zusatz?)
und die shops schlagen ordentlich drauf das teil kostet in china 899 yen das sind keine 70€
J
johndebur
ja war mir nicht sicher, ob das dann so ist. Schließlich waren diese Einstellungen unter Display settings und nicht in den notification settings, die es ja auch gibt. Nicht daß nur einfach der Bildschirm angeht , obwohl dafür bräuchte man ja keine settings? Naja egal.
Wird schon stimmen :)
Entscheidend wäre da dann die Unicom Version. Wobei das K50-T ja beides hat, China Mobile und CHina Unicom Bänder.
K30 ist ja nicht die Note Version, sondern das kleinere Handy? Wenn ich das richtig sehe.
http://shop.lenovo.com.cn/pm/productlist.html?code=0301
Gibt es bei alliexpress
http://de.aliexpress.com/item/Original-5-5-inch-lenovo-k3-note-battery-cover-case-K50-T5-back-case-yellow-white/32325154487.html
Rosenklotz
Da juckt es mir ja richtig in den Fingern: 5,5" Full HD, 64 Bit CPU etc. LED Notification auch dabei, Kamera soll gut sein UND dann sogar mit schwarzer Rückseite. Gibt es irgendetwas was dagegen spricht? LTE ist mit nicht so wichtig (vielleicht weil ich`s noch nie hatte?). Bei to2c gibt es das K3 Note gerade für 166$ mit diversen Gratis Beigaben, dann noch das Backcover für 8$ dazu, knapp 175$ = mehr als OK für die Leistung, oder?
J
johndebur
wydan
woher hast du die info?
denke bei dem preis eher nicht
willst du es wegen der musik kaufen? da wäre das blade s6 (kein wechselbarer akku) 255€ DE eine alternative oder die kingzone's
GV verlangt 184 € all inklusive
Rosenklotz
Es gibt ja schon Reviews mit Kamera Samples, die Bilder sehen gut aus und die Cam wird eigentlich nie kritisiert. Daher glaube ich dass die zumindest akzeptabel ist. GV = Geekvida?
