iNew L4 - MT6735 5,5" HD 5000mah LTE B1,B3,B7,B20 dual sim 1GB Ram 16GB Rom 2/8MP Cams
J
johndebur
neues inew Handy mit LTE dual sim , kostet 135€.
5000mAh电池 创新奇iNew L4上市 mtksj
http://www.inewphone.com/en/
5000mAh battery innovation odd iNew L4 listing
Innovation odd this year's iNew phone market began to force 4G, trailer recently appeared more clearly implied a new fingerprint recognition has coming soon, however, before the launch of the new film called L2, code of iNew L4 long standby mobile phone market first.
iNew L4 is an outstanding endurance 4G smart phone, the aircraft is equipped with 5.5-inch screen size is 148 * 78 * 9.5mm, such a "body" belongs to the same screen size of the product in normal type, but the machine The focus is on the battery capacity, L4 built with a capacity of 5000mAh large capacity battery, it can provide more long-term endurance of L4, officially known as the new machine can support up to 480 hours of standby.
Core processor part, the aircraft chosen MTK thousands of products more and more attention MT6735 Four nuclear program, processor clocked at 1GHz, inMediaTek Support under its own technology, MT6735 still have power-saving advantages, and performance is also impressive, primarily for the L4 to life, it is a very good choice. In addition, with network compatibility MT6735, the machine can support WCDMA / FDD-LTE and GSM network dual card dual standby. In addition to the processor, iNew L4 and the other has 1G RAM and 16G ROM Memory, 5.5 inches 720P screen and 2,000,000 +800 megapixel camera, running Android 5.1 system.
iNew L4 of the simple and elegant design, black, white color, the machine appears to have a greater proportion of the screen, and the rear shell with leather decorative patterns. Currently L4 has been officially listed, quoted AliExpress other platforms in is about $ 170.
Youngn
Hammer geiles Teil :p
Nur warum 1GB RAM?! Hätten sie wenigstens 2 verbaut...der Rest is Hammer, das Design schliesst drauf hin das der Home Button wieder dieses blaue Pulsierende Licht bekommt.
Weiss man denn schon wann es verfügbar sein soll??
StardustOne
Jetzt steht da lieferbar ab 30.6., aber das Phone ist auch wieder so ein typisches Lügenbaron Gerät, die 2.5 mm Rahmen, das kann heute jedes Phone, das geht bei guten dünner. Und dann dieser Beschiss mit den 80% Display Fläche, wo ein kurzer Blick bei devicespecification dann 72.47% rausschaut. Und aus 13MP sind real dann 8MP geworden. Auch wieder so ein Beschiss, dann das ganze noch kombiniert mit nur 1GB RAM und einem MTK6735M mit 4 x 1GHz, nein Danke. da ist ja ein Oukitel noch besser ausgestattet und kostet auch nicht mehr. Night Time wonderful than ever Fotos, ja ja wers glaubt. Ich habe bis jetzt noch keine Kamera gesehen, die in einem Phone verbaut wonderful than ever Night Time Fotos hätte machen können.
Und bei Comebuy wurden aus den 5000 mAh bereits schon mal 4700 mAh, würde mich auch nicht wundern wenn es am Schluss dann nur noch 3800 wären :).
Ich weiss ja nicht wie dämlich die Leute sind, welche sich diese Werbung für neue Phones ausdenken, aber als Kunde bin ich bestimmt nicht mehr so dämlich auf diese ganzen Stories von Super und ach so Toll reinzufallen.
Dracki
