Meizu Meilan M2 - MT6735 5" HD 2GB Ram 16GB Rom 5/13MP Cams 2700mah LTE dual sim
J
johndebur
Angeblich kommt auch noch ein Meizu M2.
http://www.weibo.com/2528800602/Cme2VzlAE?ref=home&rid=9_0_1_2598655909346867389#_rnd1434117437379
魅蓝2配置曝光:2GB内存!mydrivers
Blue Charm 2 Exposure: 2GB RAM!
Recently, microblogging users @ Wu Bantu exposure a few Suspected blue phone charm 2 photos . Photos show Charm Blue Charm Blue phone 2 is compared to little change in appearance, but the power button at the top right side of the body to adjust to it.
Right now,I have run sub software We discovered the charm blue figure 2 in the data center, showing its configuration has been some improvement compared to the Blue Charm.
Specifically,Blue Charm 2 Commodore 5-inch 720p display, quad-core processor equipped with MT6735 (GPU to Mali-T720), built-in 2GB memory, providing a 500 megapixel front camera and a 13 million-pixel rear camera. The remaining specifications less clear.
As a comparison, the charm blue using a 5-inch 1280 × 768 resolution display, quad-core 1.5GHz processor equipped with MT6732 (GPU to Mali-T720), 1GB of RAM and 8GB of storage space body, providing a 5 megapixel front camera and a 13 million-pixel rear camera.
After comparison, We can see the charm compared to the Blue Charm Blue 2 is replaced The entire network processor (Performance degradation), while the memory capacity increased by 1 timesShould no longer Caton up.
This is the entry-level universal rhythm 2GB of memory?
J
johndebur
Angeblich soll das M2 ab 599 yuans (85€) kosten, wenn es stimmt.
魅族两款新机齐曝光 魅蓝2低至599元? mtksj
Meizu two new machines Sarkozy exposure as low as 599 yuan charm blue 2?
Charm Blue NOTE2 just the first round of the sale, Meizu subsequent product news has been ahead of fermentation time on a blue charm 2, Meizu MX5 / MX5 PRO heard rumors from Meizu recent actions to analyze these violent Perhaps appears not groundless, Meizu likely pushed new in a short time.
After disclosure of suspected insider charm blue after 2 spy case, re-transmission of news charm blue 2, the core specifications, the price probably were exposed at the same time, Meizu MX5 suspected spy photos also surfaced back in the network .
Previously exposed to charm blue NOTE2 Leaksfly advance publication of the second generation mobile phone charm blue configuration, news that charm blue screen, memory, network compatibility 2 has very significantly improved. Display, charm blue 2 5-inch high-definition screen FHD level, increase the memory to 2G + 16G mix, will be equipped with 5MP + 13MP camera, 2700mAh battery, will join mBack key. Processor does continue to use the MediaTek solution, charm Blue 2 will be powered by Quad-Core MT6735 full-mold SOC, but the network part only supports dual 4G, it will be the same as NOTE2 launch independent telecommunications version.
The most surprising is that the price of the second generation blue charm, informed sources said that the price of 2, or blue charm just 599 yuan, 699 yuan higher then, in such a strong hardware specifications support, charm blue 2 even at 699 yuan from the market, competitiveness is still strong generation of a lot of charm blue!
In addition to Blue Charm 2, a suspected Meizu back cover photo MX5 was "leaked" by the release of the Meizu @ Li Jialong new machine spy photos show, this mysterious new machine Meizu seems, after using all-metal shell, at the edge Meizu design exudes a strong flavor. Overall, this product and have the network, rumors of Meizu MX5 M575U / M575M back design consistent, the difference is not the main camera shell picture after this round, but need to understand is that - it's just not assembling After the case according to the finished lens four weeks should be circular metal ring decoration.
Although the above information has not been confirmed, but the charm blue NOTE2 listed 799 yuan, the charm blue 2 to a more juicy price below what makes sense. As for the legendary all-metal new machine, should also be present in the product line Meizu, Meizu MX5 eventually will debut as the only official know.
J
johndebur
So sieht es also aus:
好感人的窄边框!魅族魅蓝2证件照来了 mtksj
Interested in people's narrow border! Meizu charm blue 2
A code M578C Meizu recently passed new machine network authentication, 5-inch screen and other specifications indicates that the aircraft likely is the legendary Blue Charm 2 Generations, along with photographs of public networks, this speculation seems to be the fact that network "passport" and the spy had heard highly consistent design.
The following figure, real machine pictures show the charm of the Blue 2 still has strong Meizu style, large R angle, arc back shell, like a lot, it's still one-piece plastic body. But the power key charm as the Blue 2 as NOTE2 move the location, and this time the new Meizu's Power button, volume button design to the right side of the fuselage, with one hand switch / lock screen and other operations will be more in line with public habits. In addition, Blue Charm 2 confirms joined mBack key, touch the return can be achieved, press Back to main desktop functions.
Another eye-catching at the border where the aircraft, according to the network Charm Blue 2 has a super narrow border design impressive, the same screen size, the charm blue 2 width of only about 68.9mm, and charm blue generation reached a 70mm head, with thinner gauges, progress charm blue 2 the design is obvious.
"Charm Blue 2 equipped MT6735 Quad-core "also have a more direct evidence, Meizu M578C with a main frequency of 1.3GHz quad-core processor, frequency and MT6735 consistent support Telecom's CDMA network, and FDD-LTE / TD-LTE / GSM network, dual card dual to be followed by the memory, new use of 2G memory to run, but ROM But did not reach 16G, as 8GB, with 500 million / 13 million pixel camera and Android 5.0 system, the battery capacity is 2450mAh.
Meizu rumors that on the 30th of this month there will be a new conference, the Meizu MX5, charm blue 2 are in the column conjecture, as there is already sold 599 yuan charm blue 2 rumors, many users naturally Meizu released a new machine It will be full of hope.
MTK
das wäre die erste "richtige" mt6735 (ohne P, I, M) mit wirklich 1,3 GHz,
6735 ???
Hast du dich verschrieben ??
In deinem Testlink wird aber gezeigt das das Meizu M2 einen MT6753 Prozessor hat .
Das ist der etwas "kleinere" zum MT6752 mit 1.3 HGz und schwächerer Grafikeinheit .
wydan
MTK
EDIT seh gerade das ist mehr oder weniger ein anderes handy ein M2 Note, ups
J
johndebur
Das Handy soll in China anscheinend 599 yuans (87€) kosten. Es wird morgen vorgestellt.
魅蓝2售价进一步确认:599元! mtksj
Charm Blue 2 Price further confirmation: $ 599!
This time, Li Nan did not "lie." Blue charm of its latest series of products Charm Blue 2, Li Nan had said under the premise of the price of the machine to ensure quality at least "to 600 yuan," In the new Lynx charm blue warm-up propaganda figure 2 (deleted), charm Blue 2 prices formal exposure.
One of the most important channels as Meizu online sales, the first appointment will be synchronized Lynx charm blue two generations of new machines sold preheated page is early release, charm few blue size 2, priced overall exposure.
Screenshots below, there has been part of the core selling charm blue 2, this product uses a 1.3GHz quad-core A53 main frequency processor, apparently is MT6735 A. And to disclose the information before Li Nan consistent charm blue memory specifications 2 compared to the previous generation blue charm upgraded with 16GB of storage space, the use of high-speed Flash technology eMMC5.0 read faster. Another person charm blue phone 2 will fit with a 5-inch full-screen and 2500mAh battery, as in the past charm blue products, after use of polycarbonate shell and integrally molding process.
Not difficult to see from the official selling point of this series, charm Blue 2 is still stressed parameters, so that more mainstream base configuration at a lower price, in fact, the specifications of the machine no longer a secret, to remove these, charm blue 2 have HD resolution and 2GB memory and run Android 5.0 system, will launch multiple network standard version.
Price Emerging also confirms earlier rumors, 16G version priced at 599 yuan charm blue 2, according to the pricing model charm blue NOTE2 speculated charm blue 2 Telecom Edition / Unicom version and a mobile version should be able to maintain the price of 599 yuan. Another need mentioning that there are anecdotal signs that charm blue 8G version 2, will use 1GB memory on pass priced as low as 499 yuan.
Brooklyn701
2700mAh, 2450mAh, 2500mAh... und die Überraschung was es wirklich wird (vielleicht 2200 mAh wie die anderen auch). Also grundsätzlich sehr interessant aber ich fürchte da wieder Schwindelei beim Akku....
Slo
Beim M2 kann ich keine Schwindelei feststellen....knapp 6std Display on schon geschafft
Nach 1 mal Accu laden...!!!
Ich habe gerade gesehen auf der Englischen Seite sind die Daten auch schon online http://www.meizu.com/en/products/m2/spec.html
So ein sehr interessantes Smartphone was eigentlich gut auf auf meine Bedürfnisse passen würde. Mich stört nur diese SIM-Schiene mit entweder oder Mentalität - entweder Dual-SIM oder ne TF Card - hätte lieber beides gleichzeitig.
Ich bin gespannt wann es wohl veröffentlicht wird und auch auf die ersten Tests - ob die angegebenen Specs eingehalten werden.
Brooklyn701
Kann mich der Meinung nur anschließen. Will mindestens 2 SIM und eine TF Karte betreiben. Darunter geht bei mir nichts.
