Gionee M5 - MT6735 5,5" HD Amoled LTE 2GB Ram 16GB Rom dual Batterien 6020mah 5/13MP Cams
J
johndebur
Neues Handy von Gionee mit zwei Batterien, LTE und dem MT6735 chip.
Wird am 10.6. vorgestellt
竟然是全网通?金立M5更多内容曝光 mtksj
It turned out to be the entire network? Jin M5 more
Jin phone June seems ready a lot of new products, product currently only accurate information, there Jin Jin E8 and M5, as well as additional pre-F303 / M1 and other models of news, compared to the M5 Jin Time to market is more uncertain, this to be the main selling point of a long phone confirmed in the evening of 10 June, starting in Jingdong on sale.
At the same time, the new model GiONEE M5 has appeared in the Ministry of Industry Network database, more information surfaced M5.
And just out of the small hammer exposure phones, Jin M5 and there is not much clear information disclosure, however, is only part of the known sufficient shock. Above screenshot shows, Jin M5 with dual SIM card slot is a product that can be dual card dual standby, most importantly, its network compatibility is strong enough, M5 supports FDD-LTE / TD-LTE / WCDMA / CDMA2000,1X / TDS and the GSM standard, the entire network is a mobile phone!
Should the information is correct, then the M5 will be the Jinli Cheng Jin Li since the first all-networking products, and there are rumors that trail, Jin M5 and M1 / F303 and other products, also uses the MT6735 Quad-core full-mold solution!
The machine's design also exposed to the world, from the overall design style view, M5 and F303's design is quite similar to the former but also the popular visual borderless design, the back is also a three-stage layout, combined with one of the metal shell after shaped fuselage, but Jin M5 F303 squarer than the outline of some and less rounded sense of promise. Function part, Jin M5 known firm four days of normal use can not charging, dual battery design, and has a large-capacity battery, dimensions may surprise.
If Gionee M5 really use MTK6735 Quad-core processor and supports dual Netcom, then released to market in early June and green orange NX2 win a fight, and before the formal green orange NX2 time to market is not open, who is the real first full Netcom phone MTK surviving suspense.
http://www.cnmo.com/news/494089.html
http://mtksj.com/html/MTKshoujizixun/11385.html
Jin M5 pay more attention to life, the official news that has been published M5 will use a very rare 1 + 1 dual battery design will bring more robust endurance, propaganda figure,
According to preheat page shows Jin M5 will be June 10 at 7 pm the official starter, like friends long standby large capacity battery products can follow.
Brooklyn701
Kannst du uns vielleicht näher bringen was der Vorteil ist von zwei Batterien? Denn zwei 800mAh Akkus sind auch nichts wert :p
Das Chinenglisch ist nämlich grausig in dem Text. Kann kaum was wirklich erkennen daraus dieses Mal....
J
johndebur
Was verbaut ist weiß man ja nicht. Ich denke es wird klarer , wenn die es vorstellen. :grin:
Vielleicht wird es sowas wie das Innos D6000, das ja auch zwei Batterien hat. d.h. man kann eine Batterie tauschen ohne es ausmachen zu müssen. Was da der Vorteil ist weiß ich nicht :) Aber soll ja lange halten, wenn man 6000mah Batterie hat.
http://www.chinamobiles.org/threads/innos-d6000-snapdragon-615-5-2-fhd-lte-3gb-ram-32gb-rom-6000mah-5-16mp-cams-wolfson-audio.43776/#post-578472
Außerdem soll das Gionee Handy angeblich 4 Tage ohne Aufzuladen durchhalten können, ich denke mal unter Dauerlast?. Ob das so zu trifft und stimmt oder nur Werbepropaganda ist, weiß ich nicht.
http://news.mydrivers.com/1/431/431722.htm
Jin M5 The integration of the two batteries of a mobile phone, a full four days can be used in conjunction
J
johndebur
Angeblich kann das HAndy schnell aufgeladen werden. Versteh die Übersetzung nicht ganz, aber wenn man 5 Minuten auflädt kann man 2,5Std telefonieren oder so ähnlich.
不只是双电池设计 金立M5更多特色公布 cnmo
Not just dual-battery design Gionee M5
[ mobile phone in China News] Everyone is waiting for Jin when E8, the message from金立官micro display, in addition to Jin E8, Jin M5 also will soon officially debut. The phone is the main long battery life, a full four days without charging. Today, Jinli Guan Fang microblogging again exposed material, Jin M5 not only dual-circuit design, support fast charge and counter-charge.
Jin phone official micro " smartphone e-life "release micro-Bo said," wait until the charge is a gray often worry Sang thing, Jin M5 fast charge function solve your charging pain! charging five minutes, and chat 2.5 hours, charging Absolute speed burst table with wood there! M5 also backfilled function, can simultaneously charge the phone for two dual battery design + fast charge backfilled, M5 allow you to completely say goodbye and charging treasure! partners, together with fast charge it. " .
It is not difficult to see that this flagship long life of Xin Jin machine M5, not only dual-circuit design, and support the rapid charging function, "Charge 5 minutes, 2.5 hours and chat," a great extent, improve the charging efficiency. In addition, as many users expect, dubbed the "can call charging treasure" - Jin M5, also supports reverse charging function, and that "at the same time to the two mobile phone charging." For this phone, you like it?
In addition, it is noted that, after yesterday entertainment exposed, "Huang Xiaoming baby marriage" popular events, Jin phone official micro "smartphone e-life" rapid occasion to marketing, release micro-Bo said, "until finally you love, enough Persistent "can be described close to the M5 Jin long life selling point.
J
johndebur
Wurde ja auch heute vorgestellt, soll 2299 yuans kosten (330€)
Bänder: http://item.jd.com/1574334.html#product-detail
TDD-LTE :B38/B39/40/41
FDD-LTE:B1/B3/B7/ B8
WCDMA B1/B2/B5/B8
TD-SCDMA B34/B39
GSM B2/B3/B8
CDMA1X&EVDO BC0
首款MTK全网通手机诞生 金立发布M5与E8 mtksj
The first mobile phone MTK entire network was born Jin release M5 and E8
In "obsession forward" as the core theme in force until a long period of time in the field of gold thin stand in one fell swoop the evening of 10 released two new machines, each have two new prominent selling point, one of them Gionee M5, this product has a large capacity battery, to life as the core selling point, another is Jin flagship heavyweight this year - Jin E8, with emphasis on camera.
Before conference, Jin revealed a lot about M5 advance features, coupled with a steady stream of revelations, Jin M5 substantially specifications have not much suspense. Jin MTK platform M5 is the first to achieve a full Netcom standard take-end products, with the support of MT6735 fully modular solutions, M5 compatible mobile Unicom Telecom's 4G / 3G / 2G networks, and dual-slot machine available support 4G networks.
In addition to MediaTek latest 64 all-mode chip, Jin M5 is equipped with 5.5 inches HD resolution Super AMOLED screen with 2G + 16G memory and 5 million / 13 million pixel camera, the main camera is applied PDAF phase focusing technology and in the home-motor upgrade focus speed. M5 is also equipped with Android 5.1 custom Amigo OS3.1 version, built a series of private use (such as contacts, gallery, etc.) and voice wake, translation and other functions, enhanced sound quality, using the Smart PA technology that supports DTS sound.
Design, M5 white + silver and gold two fashion a more intense version, there are more business-oriented black models, the thickness of thin enough, about 8.5mm, back with a three-stage design, the battery cover and in boxes, etc. made of metal.
Jin M5 the most important selling point of course is life, M5 built two 3010mAh batteries with a total capacity of up to 6020 mA, with power-saving technology, M5 to achieve four days of normal use, two days heavy use, and support fast charge and reverse charging technology.
Market and price
Jin has been the center of gravity in the country are in the physical channel, so the price of these two products looks are not cheap, but Jin is the first MTK M5 not only the entire network phones, is currently the most expensive MT6735 phone, the aircraft sale price of 2299 yuan, June 25 listing, Jingdong will be the first to open an appointment. Flagship product E8 64G version priced as high as 3999, the time to market for July 15.
Brooklyn701
Hast du denn mal wieder was neues von dem Phone gehört? Würde es mir gerne zulegen. Angeblich unterstützt es aber nur 2600 Mhz LTE, ist das richtig? Wann ist denn der offizielle release?
Brooklyn701
Okay. Ist es denn in Shops mit englischer Sprache auch verfügbar bzw die ins Ausland liefern? Denn mein Chinesisch ist leider ziemlich mies ;)
closebor
