Nextbit Robin - Snapd 808 5,2" FHD 3GB Ram 32GB Rom 100GB Cloud NFC LTE B1,2,3,4,5,7,8,12,17,20,28
J
johndebur
Neues Handy von Nextbit, das durch Kickstarter finanziert wird. Das Handy soll 300$ kosten (266€)
http://nextbit.com/
https://www.kickstarter.com/projects/nextbit/robin-the-smarter-smartphone
前Google员工首款安卓机 :外观大亮 mydrivers
Former Google employees first Android machine: Appearance big bright
Nextbit by Google is a company founded by former employees, the company's CEO Tom Moss, former Google Android operational and strategic global partnerships team director, CTO Mike Chan, former senior software engineer Google Android project, and chief product officer Scott Croyle design and has HTC One series is a master designer.
Recently, the company's first mobile phone Robin has begun to raise the public. Robin looks a bit like Jolla, the overall style is very Founder, is also very simple and beautiful.
It is understood that, It will be based in Baton technology company previously, the main cloud storage. If you do not have long-term application, Robin will automatically frozen, will be re-enabled after downloading from the cloud application data backup and recovery, of course, support this feature turned off manually.
Configuration, Robin is equipped with 5.2-inch 1080P screen, equipped Xiaolong 808 processor, combined with 3GB of memory to run, 32GB memory, body, camera combination 5000000 +1300 million pixels. Run Android Lollipop customized system.
It is worth mentioning that, Robin fingerprint identification module on the side, the front has dual speakers, the back four flash, and supports NFC, and is equipped with USB Type-C interface, support for fast charging. And Mobile phone is not locked Bootloader, allows the user to brush machine,
The congregation now Robin has started to raise on Kickstarter, the congregation raised price of $ 299 (about 1901 yuan).
s_4aa6ed31acda4668b2aae1a45b92fa7f.jpg s_028a03193c7c4c59b09f22801594dfc5.jpg s_68fea1fa94ad46dba48c5d069e6a85c8.jpg s_120a14e56d174afbadb253f8710fdec6.jpg s_a23dbce57985491dbefb9890453e29d6.jpg s_d7fa551fbf7c4510b9149e645edd890d.jpg s_e2a8b3bef67549398fb761805c8578a0.jpg s_edd2417fcf9145e9b27ea432e224c6a4.jpg s_f1f7eb36407f4c43beb8202564393954.jpg
Schussi
Wird leider viel zu teuer. Habe mir das mal Gestern angeschaut, Lieferung nach Deutschland wurden dort bei entsprechender Auswahl mit 95,00 € veranschlagt. Dann kommt noch Einfuhrumsatzsteuer dazu. Das ist defenitv zu Teuer.
JensK
Wirklich sehr teuer. Und nach der Erfahrung mit dem Kingzone K1 mag ich, obwohl es mir optisch gefällt, keine eckigen, scharfkantigen Phones mehr. Ist einfach unpraktisch in der Hand.
Brooklyn701
Hat die Möhre denn Dual Sim? Wenn nicht ist es völlig übertrieben teuer. Auch mit Dual SIM wäre es noch sehr teuer aber eine Überlegung wert, je nach dem wie die Kamera Performance ausfällt, ob es eine Notification LED gibt, das OS customized genug ist oder man selber etwas flashen muss usw...
J
johndebur
Ich denke die Möhre hat nur Singel Sim.
  • Processor: Snapdragon 808
  • Memory: 3GB RAM / 32 GB onboard / 100 GB online
  • Screen: 5.2” IPS LCD 1080p
  • Rear Camera: 13MP with phase detection autofocus, dual tone flash
  • Front camera: 5MP
  • Battery: 2680 mAh
  • Dual front facing stereo speakers
  • Fingerprint sensor
  • NFC
  • Quick charging
  • Bluetooth 4.0 LE
  • WiFi A/B/G/N/AC
  • GSM 850/900/1800/1900
  • WCDMA 850/900/1800/1900/2100
  • LTE Bands 1/2/3/4/5/7/8/12/17/20/28
  • Dimensions: 149mm x 72mm x 7mm
  • GPS enabled
steht auch in den Kommentaren:
@Sikander Khan
1. No, this is not a dual sim phone.
