MT6755 (Helio P10) - neuer Mediatek 8 Core chip
J
johndebur
Ende 2015 kommt der Nachfolger vom MT6752, MT6755.
强大!MTK MT6755更多规格揭晓 mtksj
Powerful! MTK MT6755 More Specifications Announced
+10 Architecture using 3 core design Helio X20 (MT6797) Not MediaTek All the rest of the year, code-named MT6755 The new solution will also debut in the second half, by supporting 21MP camera / LTE CAT.6 features such as easy to see that this is MediaTek tailored for high-end market, another "nuclear weapons."
MTK MT6755 some time ago has appeared in theMediaTek's latest product roadmap On the part of the specification to obtain exposure, industry analysts recentlyPan Jiutang Given that the solution is more detailedly described. MT6755 learned its flagship high-end market helio X10 The advantage, especially multimedia performance is very prominent.
First is the camera part, for the high market MT6755 can support 21MP single camera (rear), also support 8 million +1600 megapixel dual cameras (added depth of field camera), equipped with a dual ISP image signal processor to enhance image processing efficiency , using a new noise reduction algorithm, other support real-time video beauty, PIP, PDAF phase focusing technology. Audio part, MT6755 provides professional-grade solution HIFI SNR staggering 110dB.
More powerful camera and audio outside, MT6755 can support 1080P screen display, support 1080P 30fps video playback recording, specifically the integration of what a GPU temporarily not clear, but the use of a higher order than MALI T760 graphics processor is a certainty .
Another person, MT6755 has 8 A53 processor, main frequency after MT6595/MT6795 , Its CPU frequency up to 2GHz. Meanwhile MTK MT6755 is also strong in the network out MT6752.
It can support 2 × 20MHz dual-carrier aggregation (LTE Cat.6), downlink rate of up to 300Mbps, standard covering the world's major networks, including the FDD-LTE / TD-LTE / WCDMA / TDS / CDMA1x, EVDO / GSM.
Compare MT6752, MT6755 even better performance, but better in all aspects of power, former MT6752 enhance graphics performance compared to 120%, while 70% of the power consumption of only MT6752. Eye-catching performance in the mid-market MT6752 has allowed Qualcomm headache, early Q4 MT6755 a scabbard, and I believe in the high-end market will continue to put pressure on Qualcomm.
J
johndebur
erstes benchmark Bild vom neuen MT6755
联发科MT6755跑分首曝 八核也不给力 mydrivers
MediaTek MT6755 first exposure to run sub-eight-core is not to force
Prior to exposure of the official roadmap says MediaTek will be the end of the third quarter to the fourth quarter of this year launched the MT6755 processor First This is MediaTek second generation full Netcom SOC.
In accordance with the previous statement, MT6755 built eight Cortex-A53 core, clocked at up to 2GHz, while up to 21 million pixel camera and 1080p display. Meanwhile, in terms of the baseband, MediaTek will be the first to support LTE Cat.6, while supporting SRLTE also means baseband support the entire network.
Recently, a system equipped with MT6755 processor products coming out GeekBench database, page display is equipped with its 2GB of memory, a single-threaded score of 882, multithreading is 3371.
Comparison with the same eight-core Cortex-A53 architecture MT6752 and MT6795 view, then, MT6755's obviously been better to run sub should be less frequent causes. It is said, MT6755 eight-core A53 can not reach 2GHz frequency, but only two can reach, So multi-threaded performance is poor.
s_5bc0f1f363894bf58fb613a829a0ba70.jpg s_42315c7c4cbc44f886de14fa94053d2e.jpg
Reflexion
Und das schön(ste)e mit Helio X20 wird es bessere Audio Qualität (Einheit) geben. ...einfache 4K Settings sollte ja schon der x10 können...
wydan
ich hab da was ausgegraben
in dem benchmark steht das der x10 schneller ist wie P10
edit ich sollt noch dazu sagen das der P10 ein vorserien modell ist.
der P10 des Gionee W909 (vorserien) mit 1,81 GHz macht singel 820 multi 3102
http://wccftech.com/helio-p10-benchmarks-impressive-performance-midranged-soc/
hier eine auflistung der chips
http://www.anandtech.com/show/9308/mediatek-helio-p10
https://www.droidwiki.de/MediaTek
und es wird wider was laufen den es gibt den P10 in 1.1GHz und 2.0GHz und was meint ihr wird passieren. .....
gerade läuft ja die werbetrommel zum P9000 an und da will man den P10 als besseren chip darstellen, ich bin ja mal gespannt ob er das wirklich schaft noch dazu hat der X10 2,2 GHz gegenüber 2 GHz
J
johndebur
Ob der nun besser ist oder nicht, weiß ich nicht. Soll aber den Akku nicht so belasten im Vergleich zum MT6752. Wurde irgendwo mal gepostet.
Also was die nun an benchmark Punkten machen interessiert ja eh nicht mehr wirklich. Bei jeder Antutu Version, werden die Punkte ja auch verändert. Da blickt man ja eh nicht durch :grin:
Hier wäre auch ne Vergleichsseite von Mediatek:
http://mediatek-helio.com/
Ach ja hier:
http://mobile.pconline.com.cn/740/7406840.html
Xi slim handset into the new darling of MTK greatly reduced power consumption P10
wydan
beim redmi note 2 sind das 2000 punkte, wenn man bedenkt, das eine SD karte schon 1000 punkte frisst, ist das zumindest von antutu 5 auf 6 nicht so wild. außerdem nur anhaltspunkte und meiner meinung sind die werte auch nicht liniar addier bar, sprich doppelte punkte ist nicht doppelt schneller
closebor
